This thread is privately moderated by matwelli, who may elect to delete unwanted replies.
Old Jan 14, 2010, 03:05 AM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
Ritewing Lightning 48" AP platform
Did this one a bit different, no PU glue (used hotglue) no rite weave - using laminating film, and a large cutout on CG to hold a camera
matwelli is offline Find More Posts by matwelli
Old Jan 14, 2010, 03:06 AM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
AP platform... with an MD speed... Easystars are for pansies.
jackosmeister is online now Find More Posts by jackosmeister
Old Jan 14, 2010, 03:09 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
heh, yep , launch, get to target, take photo, get back, all at 70 mph, no rrrrrrrrrrrrrrrrrrrrr for 1/2 an hour to climb 200 ft easy star style :-)
Old Jan 14, 2010, 08:41 AM
pefozzy is offline
Find More Posts by pefozzy
Plymouth, MN
Joined Sep 2009
Is this your own design? If so, would you be willing to e-mail a PDF of your dimensions and airfoil sections? I've been working on my own design- my first "from scratch" airplane- and it would be helpful to have something to benchmark it against.
Also, what is your power system to achieve 70 mph?
thanks!
-Andy
pefozzy is offline Find More Posts by pefozzy
Old Jan 14, 2010, 11:46 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Hey Andy,
Not my own design, this is a Ritewing from www.ritewingrc.com
http://www.ritewingrc.com/store/index.php?productID=136
The powertrain is a 3S 2650 mah 30C turnigy lipo and a Microdan 2505 Speed 2900kv motor on a 6 by 4 sport prop http://www.gobrushless.com/shop/inde...ef=MD2505-2900
Old Jan 14, 2010, 12:50 PM
pefozzy is offline
Plymouth, MN
Joined Sep 2009
Cool, thanks! Ritewing looks like they have some great product. I'm going to try and build this wing from scratch, but depending upon how the flight characteristics turn out I might be ordering a kit!
Old Jan 14, 2010, 05:01 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Ready to laminate
All done, ready to apply the laminating film 75micron stuff
Old Jan 14, 2010, 09:14 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Just finished laminating the wing, single layer top and bottow, second layer wraped around LE, back 4 inches top and bottom, third layer on bottom centre 12 inches wide.
Weighed before and afterwards, 90 grams total added weight, feels like a board
Old Jan 16, 2010, 01:08 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Servo locations
Old Jan 17, 2010, 02:08 PM
tekrunner is offline
Find More Posts by tekrunner
Joined Jan 2009
How do you plan on triggering the camera?
tekrunner is offline Find More Posts by tekrunner
Old Jan 17, 2010, 02:10 PM
Joined Jan 2009
nice project, got any pics of the lamination job?
Old Jan 18, 2010, 03:47 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Camera trigger will probably be by a micro servo pushing the shutter button, will post pics when I sort it.
Will get some photos of the lam film buildup for you, its a sweet deal, I enjoyed doing it and results in a really solid wing
Old Jan 25, 2010, 09:36 AM
pefozzy is offline
Plymouth, MN
Joined Sep 2009
Do wings fly better with the split aileron / elevator vs. elevon? The wing I'm building I'm planning on initially using elevon mixing, but it seems like with the DX6i + 6110 receiver you really don't get the control surface travel you'd get with seperate servos.
Old Jan 25, 2010, 10:59 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Hey Pefozy,
With the DX6i there is a trick to fix that, as the standard DX6i mix for elevons is not rite at all
heres what I do
Put right elevon servo into aileron channel, put left elevon servo into flap channel
Select "dual Aileron" on the DX6i, not elevon mixing.
Then assign mix one Elevator>Flaps 100% in both direction, and enable trim
Now you have an awesome amount of throws, and will need to reduce your travel :-)
Here is a link to a better description http://www.rcgroups.com/forums/showp...35&postcount=8 its a fair way down the post in "green" text
I might get a chance to take some shots of the DX5i screen if the above dosent make sense
Old Feb 01, 2010, 02:11 PM
pefozzy is offline
Plymouth, MN
Joined Sep 2009
Thanks for the tip, I'll give it a try!
Originally Posted by matwelli View Post
Hey Pefozy,
heres what I do
Discussion The Conrad 450 ARF Quadrocopter Joshbb Multirotor Talk 1309 Aug 24, 2014 02:35 PM
Sold ***** Ritewing ***** 36 Inch Lightning ***** Ritewing ***** 36 Inch Lightning **** PaulVi Aircraft - Electric - Airplanes (FS/W) 5 Mar 02, 2010 05:44 PM
Sold ***** Ritewing ***** 36 Inch Lightning ***** Ritewing ***** PaulVi Aircraft - Sailplanes (FS/W) 4 Sep 08, 2009 02:27 AM
