This thread is privately moderated by Santoneski, who may elect to delete unwanted replies.
Old Jan 13, 2010, 09:29 PM
Santoneski is offline
Find More Posts by Santoneski
Santoneski's Avatar
Canada, ON, Hamilton
Joined Feb 2009
Guillows Hurricane Build
Here is my Guillows build. It was my first Balsa build so its kind of sloppy, Instead of using the elevator pieces that came in the kit i just made a one piece solid balsa tail, but i used the rudder that was included. Surprisingly the covering whats that bad. there are quite a few wrinkles tho, but it was IMO the funnest part of the build. Instead of using Dope i used half water half white glue it apply the tissue. For painting i used acrylic paints with an airbrush and brushed the camo on. I still need to make the bottom white and add the decals. Feel free to ask any questions.
Santoneski is offline Find More Posts by Santoneski
Old Jan 14, 2010, 10:30 AM
MPP is offline
MPP
Find More Posts by MPP
MPP
In Unusual Attitude Recovery
MPP's Avatar
Danbury CT (DXR)
Joined Oct 2005
Looks nice. Good job on your first Guillows build. Are you planning on electrifying it? Looks light.
Cheers -M
MPP is offline Find More Posts by MPP
Old Jan 14, 2010, 04:21 PM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Cheers -M
Ditto...
Is it a conversion or free flight?
Nice job for #1
phil
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Old Jan 14, 2010, 05:23 PM
Santoneski's Avatar
Joined Feb 2009
At first i was going to make it electric i even put carbon rod spars in the wings (you can see it in one of the pics). Then i realized i dont really know what im doing when it comes to purchasing electronics. So i just made it a static build. I just weighed it on my cruddy scale and its about 50 grams. I didn't do anything to lighten it just straight up followed the instructions. I have an ME-109 and a P-40, Im going to make the 109 static so i can have a battle of Britain hanging from my ceiling. ill attempt to make the p-40 an electric, maybe my building skills will improve by then
Old Jan 16, 2010, 10:29 AM
WTFLYR is offline
Find More Posts by WTFLYR
WTFLYR's Avatar
West Central PA
Joined Dec 2008
I'll give credit to anyone who uses tissue. Looks fine. I know what it would look like if I did it. Iron-on makes us look good.
These Guillows planes from this series are difficult to convert, so it's probably better to display it, unless you've used light wood with redesigned tail surfaces. The built up series with the P51 and Skyraider will come out lighter. I even built a second 16" FW190 from this series, and gave up on it when realizing the nose weight needed. I had it flying, but was too heavy to be controllable. The plane also had started at around 50gms without gear, as I wanted a sheeted fuse look. Even with feather light balsa, it was still horribly tail heavy. The thought has crossed my mind to bash it into a FW190D, with a longer nose and span. Even with tissue, it's difficult to not end up tailheavy, unless you build very light tail surfaces, definitely without the Guillows parts or wood.
WTFLYR is offline Find More Posts by WTFLYR
Old Jan 16, 2010, 11:13 AM
Santoneski's Avatar
Joined Feb 2009
I thought about sheeting it as well. Working with tissue wasn't that bad. Not sure how well it works with dope, but with half water half glue it was pretty easy. You defiantly learn as you go along.
Old Feb 01, 2011, 06:29 PM
ZEROSKIN76 is offline
Find More Posts by ZEROSKIN76
kill your idols
ZEROSKIN76's Avatar
utica new york
Joined May 2009
i used to use hairspray and alcohol!
worked great
ZEROSKIN76 is offline Find More Posts by ZEROSKIN76
Old Feb 01, 2011, 07:23 PM
Santoneski's Avatar
Joined Feb 2009
Do explain lol
Old Feb 01, 2011, 07:38 PM
kill your idols
ZEROSKIN76's Avatar
utica new york
Joined May 2009
older hairspray was made from laq a derivative of the lacquer beetle (very gross)
but it works excellent for adding tissue to models and sealing the tissue from being porous ., much lighter than white glue ps real nice guillows
Old Feb 01, 2011, 08:17 PM
Santoneski's Avatar
Joined Feb 2009
Ahh i assume they dont sell that anymore. I just used the glue along the edges and then just sprayed water all over the tissue and let it dry and it tightened up. Thanks i should post pics with the decals on it.
Old Feb 01, 2011, 08:19 PM
kill your idols
ZEROSKIN76's Avatar
utica new york
Joined May 2009
with the modern equipment available this would be one great rc plane
Old Feb 01, 2011, 08:25 PM
Santoneski's Avatar
Joined Feb 2009
Well i just got a DX6i so i could use the micro stuff, i also have a half built bf-109 and a nib p-40 of the same size.
Old Feb 02, 2011, 12:03 PM
kill your idols
ZEROSKIN76's Avatar
utica new york
Joined May 2009
id turn one into a 25 dollar hobbyking special
orange rx without case (4g) 8$
tiny 10 gram motor 60 watts(10g) 7$
5 amp esc (10 gram wired) 6
battery might be tough but id consider using
http://www.hobbyking.com/hobbyking/s...idProduct=6520
it is a rx battery but light and with such a small system would last a few minutes
Old Feb 02, 2011, 12:05 PM
kill your idols
ZEROSKIN76's Avatar
utica new york
Joined May 2009
whoops sorry that is 27.98 but worth every penny to see these birds fly
for a first balsa build that one turned out well
i still have not mastered small string wood kits(hate stringers )
Help! Stahl Hurricane build help j_begs Scale Kit/Scratch Built 29 Jan 11, 2010 11:04 PM
Discussion Guillows Hellcat build scigs30 Free Flight 40 Jan 11, 2010 09:04 PM
Discussion Guillows Zero build scigs30 Free Flight 22 Jan 09, 2010 07:32 PM
Discussion Guillows Hawker Hurricane build scigs30 Free Flight 8 Aug 24, 2008 11:34 AM
