Old Feb 26, 2013, 09:12 AM
Julspower is offline
Find More Posts by Julspower
Canada, QC, Granby
Joined Feb 2013
Originally Posted by perdification View Post
Yup, in my original post I mentioned that I'm using compressed foam. I was thinking, why isn't there any 9mm compressed foam that I can find? The thickest they have, I believe, is 5mm. They have it in 3mm too. Compressed foam is the kind which melts when UHU glue is applied.
Any suggestions for foam thickness if I'm using compressed foam instead of EPP?
I did use blue FFF from home depot.
I still dont have my tx so cannot test but plane without electronic is 114g and look tough enough
Julspower is offline Find More Posts by Julspower
Old Feb 26, 2013, 09:31 AM
BrownEyedFool is online now
Find More Posts by BrownEyedFool
You're killin' me Smalls
BrownEyedFool's Avatar
United States, NJ, Hillsborough Township
Joined Sep 2011
Motor/ESC choices on the shelf as candidates for one or more of these planes, for indoor use or training children on the buddy box. 9mm EPP build.
1- Suppo 2208/8 2600kv with a 30A esc
2- No-name B2212/13 1000Kv with a 20A ESC,
3- No-name 2208-14 1450kv with the 18A ESC,
4- Blue wonder 1700kv with a 10A ESC (might be a 12A).
Which motors preferred and what order? Prop selections?
BrownEyedFool is online now Find More Posts by BrownEyedFool
Old Feb 26, 2013, 09:48 AM
perdification is offline
Find More Posts by perdification
Joined Dec 2012
How thick is the blue foam used?
perdification is offline Find More Posts by perdification
Old Feb 26, 2013, 02:09 PM
roo_ster is online now
Find More Posts by roo_ster
Standing Athwart History
roo_ster's Avatar
United States, TX, Dallas
Joined Mar 2011
The blue FFF is 5 or 6mm.
roo_ster is online now Find More Posts by roo_ster
Old Feb 26, 2013, 07:11 PM
Joined Dec 2012
Just found out that the compressed foam I have locally is very similar to depron. I've heard that Depron foam is more rigid compared to EPP, and maybe a thinner foam would do the job? In which case, would 6mm depron foam work for building the EzFly?
Thanks for all the help so far.
Old Feb 26, 2013, 08:08 PM
roo_ster's Avatar
Joined Mar 2011
Check out page1 or so. I recall some folks building with depron or fff. But, yes, depron and fff being more rigid, you will not need as thick a foam. Still might want to reinforce with carbon fiber or wooden dowels, esp leading edge and at the step and around the prop slot.
Old Feb 26, 2013, 08:26 PM
Joined Dec 2012
Oh right, searching this thread for "depron" yielded all the answers I needed. As quoted by motorhead himself, 6mm depron is similar in weight to 9mm EPP. Although I recall someone telling me that EPP is heavier. Oh well, doesn't matter, I'll stick with 6mm compressed foam or depron or whatever they call it.
Old Feb 26, 2013, 09:42 PM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
1- Blue wonder 1700kv with a 10A ESC (might be a 12A).
7X6 prop
You can check the site for recommended gear here
Wilfor is offline Find More Posts by Wilfor
Old Feb 27, 2013, 01:52 AM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
I've been happy wth a Blue wonder 1500kv, with a 10A ESC, so I might start with #4.
6x4 prop, I think that's the largest that fits into the slot as I've got it built.
marhar is offline Find More Posts by marhar
Old Feb 27, 2013, 03:52 AM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
I would use #4. As for prop you can probably run what ever you have been running on that motor as long as it is 8" or smaller. It depends on what battery you will be using.
motorhead is offline Find More Posts by motorhead
Old Feb 27, 2013, 07:21 AM
Joined Sep 2011
All 4 motors are still in packaging, the first one will likely end up in a prop in slot F22, the BW will have it's choice of homes (and I've got a ton of orange 7x6 props for it) and the middle two were impulse buys and now I debate what sort of home to build for them.
Batteries I have a number of 3s 450s, two 2s 800s, then it goes up to the 3s 1300s, 1800s, 2200s.
Kind of excited I should have foam on the porch today or tomorrow, hot wire same time frame.
Old Feb 27, 2013, 12:20 PM
Canada, QC, Granby
Joined Feb 2013
it was 2inch thick but I cut it myself to around 6mm
Old Mar 03, 2013, 08:57 AM
Peteriaseda is offline
Find More Posts by Peteriaseda
Joined Jan 2013
Made pair of skies to be able to fly from the frozen lake
Peteriaseda is offline Find More Posts by Peteriaseda
Old Mar 03, 2013, 11:30 AM
maurice076 is offline
Find More Posts by maurice076
maurice076's Avatar
United States, MI, Warren
Joined Aug 2011
Excellent idea,more flight time!
maurice076 is offline Find More Posts by maurice076
Old Mar 05, 2013, 06:26 PM
roo_ster's Avatar
Joined Mar 2011
WInds finally let off to 5-10mph, so I gave my EZFly a go.
The guy wires worked quite well. Much more controllable and much better flying. I might install two short ones from the top of the vert stab to the horiz stabs. I already have the bbl swivel installed.
I will have to grind some of my stick mount away, though, to get some up-aft angle on the motor. At full throttle, it can do a loop with the elevator trimmed level. Kind like some of those pusher motor gliders:
Discussion Telemaster 400 - Great trainer from free plans! cam777cam Beginner Training Area (Aircraft-Electric) 13 May 16, 2016 12:29 AM
Discussion 3D Batix Extra 330 Free plans Great plane Ben-Rod 3D Flying 980 Mar 28, 2015 01:06 PM
For Sale Christmas gift,Trainer Hobbico Electristar RTF + Free Gift, Great Value !!! the-cat007 Aircraft - Electric - Airplanes (FS/W) 0 Dec 10, 2009 11:24 PM
For Sale Christmas gift,Trainer Hobbico Electristar RTF + Free Gift, Great Value !!! the-cat007 Aircraft - Electric - Airplanes (FS/W) 10 Dec 08, 2009 04:13 PM
Discussion Free Plans for 60" ish plane mt_100 Electric Plane Talk 11 Sep 14, 2009 08:28 AM
