Old Sep 20, 2011, 06:58 PM
hankg is offline
Find More Posts by hankg
Lost but making good time
Joined Nov 2008
That's awfully low...What size battery and prop?
7volts x 3.5 amps = 24.5 watts
Is the prop on correctly i.e. prop specs pointing toward the nose of the plane.
Regards,
Hankg
hankg is offline Find More Posts by hankg
Old Sep 20, 2011, 07:29 PM
blackboots1337 is offline
Find More Posts by blackboots1337
blackboots1337's Avatar
United States, WA, Mukilteo
Joined Dec 2010
Regards,
Hankg
Yeah its on correctly, 2 amp meters confirmed that. So ? Is my ESC damaged or broken?
blackboots1337 is offline Find More Posts by blackboots1337
Old Sep 20, 2011, 07:46 PM
Wilfor is online now
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Did you calibrate your throttle Black ? you may not be getting full throttle
Wilfor is online now Find More Posts by Wilfor
Old Sep 20, 2011, 07:47 PM
hankg is offline
Joined Nov 2008
blackboots,
No, I doubt it. Some ESCs need to be programmed. Just don't want to suggest something that will destroy your ESC. I have that motor on a 9oz foamie and run an 8 inch prop and a 3S 690 milliamp battery to power it. Plenty of power for 3D flying without burning up a 10 amp ESC...puts out about 75 watts.
Regards,
Hankg
Old Sep 20, 2011, 08:16 PM
Joined Dec 2010
blackboots,
Regards,
Hankg
Next charge here Ill reconnect the amp meter and see what its pulling again after I reprogram my ESC. Let you know what I get!
Its not like it doesn't have power it just has trouble lifting an extra 100g, when empty I can do some 3D stuff, its actually really fun. But when I slap the camera on there I can only do those kinds of things after a dive.
Old Sep 20, 2011, 08:22 PM
hankg is offline
Joined Nov 2008
OK...I see where your coming from now.
Regards,
Hankg
Old Sep 20, 2011, 08:31 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Originally Posted by blackboots1337 View Post
Thanks, my current amp draw is 3.5 amps at full throttle. On my 2S. Thanks for the info though.
You may have already answered this (but I cannot find):
what motor and what propeller do you have?
3.5 amps at full throttle can also be a symptom of a combination of
a low kv (revolutions/volt) motor and
a small propeller
flying-llama is offline Find More Posts by flying-llama
Old Sep 20, 2011, 09:42 PM
Joined Dec 2010
a small propeller
I am using the default motor and prop that was recommended with the kit.
To be more specific:
http://www.fancyfoam.com/index.php?m...g35m6gip9ouuj3
and
Old Sep 20, 2011, 10:28 PM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
100 grams is 3.5 oz and is probably close to a 50% increase in weight. Also on 2s with the recommended 7x6 prop it will already be low on power. There may not be anything wrong.
If you want more thrust you can go to 3s.
motorhead is offline Find More Posts by motorhead
Old Sep 21, 2011, 08:04 AM
smiley007 is offline
Find More Posts by smiley007
Joined Aug 2005
hi
You use a special propeller ?
thx
smiley007 is offline Find More Posts by smiley007
Old Sep 21, 2011, 08:17 AM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
I have taken an 8x4.3 and cut it down to 7". You just need to make sure to balance it before you use it. Cut a 1/2" from each tip and then sand the long tip until it is balanced. Yes it has less pitch but the blade is almost twice as wide. You get more thrust but not necessarly more speed.
Old Sep 21, 2011, 02:05 PM
Joined Aug 2005
hi
The left propeller pitch?
thx
Old Sep 26, 2011, 05:21 PM
Joined Mar 2006
Originally Posted by smiley007 View Post
...The left propeller pitch?
Hello. You may want to rephrase this question.
I know that I am not sure of what you are trying to ask.
Old Oct 03, 2011, 03:21 PM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Mine's ready for equipment. I needed something to fly during the standard round & round sessions at the indoor fly-ins this year. I cut 5 deg of downthrust into the foam for the motor mount to negate some of the climbing under power tendencies that make it a good trainer. Not sure about the motor yet. Will probably go with the 1700Kv BW on 2S with the 7 x 6 prop.
Azarr
Azarr is offline Find More Posts by Azarr
Old Oct 03, 2011, 04:22 PM
hankg is offline
Joined Nov 2008
Azarr,
Go into the downthrust a little more...if I look at your second picture, do you mean that the motor mount points downward toward the nose of the plane at a 5 degree angle?
Regards,
Hankg
Discussion Telemaster 400 - Great trainer from free plans! cam777cam Beginner Training Area (Aircraft-Electric) 13 May 16, 2016 12:29 AM
Discussion 3D Batix Extra 330 Free plans Great plane Ben-Rod 3D Flying 980 Mar 28, 2015 01:06 PM
For Sale Christmas gift,Trainer Hobbico Electristar RTF + Free Gift, Great Value !!! the-cat007 Aircraft - Electric - Airplanes (FS/W) 0 Dec 10, 2009 11:24 PM
For Sale Christmas gift,Trainer Hobbico Electristar RTF + Free Gift, Great Value !!! the-cat007 Aircraft - Electric - Airplanes (FS/W) 10 Dec 08, 2009 04:13 PM
Discussion Free Plans for 60" ish plane mt_100 Electric Plane Talk 11 Sep 14, 2009 08:28 AM
