Old Apr 21, 2011, 11:49 PM
FXG is offline
FXG
Find More Posts by FXG
FXG
Joined Nov 2010
Dihedral Wing Tips?
Hi,
This would be my first attempt to scratch built a foamy. Just wanted to know how do you guys make dihedral wing tips?
Do you cut the wings where angle starts and paste both parts together after making taper edges like done when making hinges?
Thanks.
FXG is offline Find More Posts by FXG
Old Apr 22, 2011, 12:35 AM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
On the kits I use a dremel router with a 1/8" bit to cut a channel in the top of the wing. Glue is put in the channel and then you bend the wing to close the gap. Cutting an angle and gluing back together will also work.
motorhead is offline Find More Posts by motorhead
Old Apr 22, 2011, 05:50 PM
FXG is offline
FXG
FXG
Joined Nov 2010
Please show some pics or video
Hi motorhead, thanks for the reply, can you please post some pictures or better a video of process you mentioned above, thanks.
Old Apr 24, 2011, 12:08 AM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Kids EZGlider
Wanted to do something different for my boy and his classmates for their last class . Looked around for a good chuck glider , the dollar store had a bunch of cheap ones but i didnt really like them
This dragon looked like a great base for a glider so i copied a pic of the PDF into sketchup , resized and traced it and came up with this Name: EZglidepic.png
Description: It's made out of dollar store foam .
Description: I used my last 2 cents in the nose to balance
I ended up making 10 of them so far and they've been a hit and are really durable . I was able to get 6 out of 2 sheets of foam .
Description:
Ive attached PDF's for the plane and dragon
Thanx Mike for the great design i hope i did it justice
Chris
Wilfor is offline Find More Posts by Wilfor
Old Apr 24, 2011, 01:38 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Looks good.
Old Apr 24, 2011, 09:44 PM
FXG is offline
FXG
FXG
Joined Nov 2010
Where Is The Plan To Cut This Way?
Hello Motorhead,
Thanks for the great plane you designed, I can't find the plan where parts of the plane can be cut as shown in the attached images ... or am I missing something?
Old Apr 25, 2011, 12:31 PM
Buckeye95 is offline
Find More Posts by Buckeye95
United States, OH, Columbus
Joined Oct 2002
Chris,
Just out of curiosity, did you de-paper the dollar-store foam first? Looking to make some of these for my son and nephew.
Pete
Buckeye95 is offline Find More Posts by Buckeye95
Old Apr 25, 2011, 12:42 PM
Wilfor is offline
RC Adddict
Wilfor's Avatar
Joined Jan 2010
Yes pete no paper on the foam . i dont think it would glide as well . Ive got alot more flights in on them aswell and right around 36 mm for the COG seems to be a nice spot .
I glued one of the Fuse sides to the main fuselage piece , slid the wing in the groove once that setup then just taped the other fuse side on . This way i could check COG and see how it glides and add a little weight or remove some if needed , once its good then go ahead and glue the other fuse side and then the wing in place . My son has thrown his a few hundred time by now , its been on the roof of the house twice and finally broke the eye ball off last night
Ive been surprised how well they've held up .
Old Apr 25, 2011, 05:34 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Originally Posted by FXG View Post
Hello Motorhead,
I will have to look to see it I use a normal sheet size for this one if so I will try to post a layout pdf.
Old Apr 27, 2011, 08:15 AM
Runnikee is offline
Find More Posts by Runnikee
Crash and burn, huh Mav?
Runnikee's Avatar
USA, IN, Fort Wayne
Joined Aug 2010
That's a good idea, Mike. If mine doesn't fly right, my next build will use that method. Been wanting to maiden for about 2 weeks now, but between the wind, monsoon rains, and tornadoes, I haven't had the chance yet.
Runnikee is offline Find More Posts by Runnikee
Old Apr 28, 2011, 08:14 PM
FXG is offline
FXG
FXG
Joined Nov 2010
Waiting
Great, waiting for the right plan, thanks.
Old Apr 29, 2011, 02:02 PM
Runnikee is offline
Runnikee's Avatar
USA, IN, Fort Wayne
Joined Aug 2010
What do you guys think would be the result if the wingspan was increased on this plane? Would it just make it more floaty, or would it completely botch up all of its flight characteristics?
Old Apr 29, 2011, 10:07 PM
Wilfor is offline
RC Adddict
Wilfor's Avatar
Joined Jan 2010
Carl went to a 64 " span
and Don went to a 39 " span and extended the fuselage
Here
i believe they both had no issues
Old May 10, 2011, 09:46 PM
metasim is offline
Find More Posts by metasim
metasim's Avatar
USA, VA, Charlottesville
Joined Apr 2010
Wilfor, thanks so much for sharing your variation. I was looking for something to make for some friends kids, and this is perfect!
metasim is offline Find More Posts by metasim
Old May 11, 2011, 01:08 PM
Runnikee is offline
Runnikee's Avatar
USA, IN, Fort Wayne
Joined Aug 2010
OK, I'm probably being nuts here, but I just destroyed an EDF jet last night (still don't know what went wrong) but all the electrics are fine. Any thoughts on throwing my edf on this airframe? What would happen? Is this a huge no-no? The motor I already have on my plane is way overpowered and it flies great with the speed. Would the fan just throw everything off?
Discussion 3D Batix Extra 330 Free plans Great plane Ben-Rod 3D Flying 980 Mar 28, 2015 02:06 PM
For Sale Christmas gift,Trainer Hobbico Electristar RTF + Free Gift, Great Value !!! the-cat007 Aircraft - Electric - Airplanes (FS/W) 0 Dec 11, 2009 12:24 AM
For Sale Christmas gift,Trainer Hobbico Electristar RTF + Free Gift, Great Value !!! the-cat007 Aircraft - Electric - Airplanes (FS/W) 10 Dec 08, 2009 05:13 PM
Discussion Free Plans for 60" ish plane mt_100 Electric Plane Talk 11 Sep 14, 2009 09:28 AM
Discussion Telemaster 400 - Great trainer from free plans! cam777cam Beginner Training Area (Aircraft-Electric) 7 May 04, 2008 08:04 PM
