Old Jan 13, 2010, 07:36 AM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Mini-Review
Building the St. Lawrence River Skiff from M.A.C.K. Products
Had the oppertunity to review the M.A.C.K. Products St. Lawrence River Skiff, so thought I'd post it up here as well.
The kit is excellant, primarily of bass wood construction. Plans and Instructions are good, and the laser cutting is first class. Overall, this is a really nice kit. So, lets get started.
P. Tritle is offline Find More Posts by P. Tritle
Old Jan 13, 2010, 07:39 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Setting Up the Hull Framing Jig
The hull is cold molded over the laser cut framing jig supplied with the kit. The jig is assembled and tack glued to the building board, and is where the hull planks will be shaped and glued in place in the keel assembly.
The keel assembly is then built up and tacked to the jig. From there, the planks are glued in place one at a time, starting at the keel.
Old Jan 13, 2010, 07:54 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Fitting the Planks
The laser cut planks are fitted one at a time, working from side to side to keep the loads symmetrical until all the planks are in place. There are 7 planks per side.
Generally speaking, the planks fit really well. There was a bit off pulling and tugging involved, but none needed trimming to fit. Then once the planks were in place, the hull was removed from the jig and the final gluing done to join the planks down the length of the hull. The stem and stearn caps were added and the hull sanded to final shape. A coat of thinned West Systems epoxy brushed on to seal the wood.
Old Jan 13, 2010, 08:00 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Adding the Hull Ribs
Once cured, the jig formers were taped back into the hull to hold its shape while the ribs are fitted and glued in place. Spacers are used to mark the location of each rib.
Old Jan 13, 2010, 08:11 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Gluing the Ribs in Place
The ribs are added one at a time working toward both ends from center center. As the process progresses, the next former in line was removed untill all the frames had been removed.
Old Jan 13, 2010, 08:32 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Finishing Up the Ribs
After all the frames were removed the ribs were added all the way out to both ends.
To aid in forming the wetted bass wood strips for the ribs a piece of 1" dowel was used to form the basic shape, then once glued in the ends were trimmed with a fingernail clipper. Once it was all finished and sanded, 2 coats of spar varnish were brushed on the inside of the hull.
Old Jan 13, 2010, 08:48 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Fitting the Floorboards
With all the ribs in place, the hull was now completely rigid, and much easier to work with then before when it had a real mushy feel about it. The laser cut floor boards were fitted and glued in place. Again, the fit was near perfect, with no trimming required. Then once the floor boards were in, the speaders were added at both ends and the deck added.
Old Jan 13, 2010, 08:53 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Fitting the Deck
The deck was glued in place next. The parts are cut a bit oversize, so there's plenty of room for alignment. Once the parts are aligned and glued in place the edges were trimmed and sanded into the edge of the top plank.
Old Jan 13, 2010, 09:08 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Adding the Cockpit Combing
The cockpit combing was added next. The front and rear sections were wetted and preformed around the wood dowl, then glued in place. The mid sections were then added.
Then the rub rails were fitted and glued in place, sealed with thin Cya, and the belt line between the rails was painted blck. Planned to leave the planks natural, so wanted a little color for contrast.
Old Jan 13, 2010, 09:30 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Fitting the Seats
The seats were trimmed to fit, then the seperation lines scribed into the boards with a home made tool. The wood was then stained and two coats of varnish applied.
Old Jan 13, 2010, 09:47 AM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Very nice, you make this look like an afternoon build.
Cool model.
woodybob is offline Find More Posts by woodybob
Old Jan 13, 2010, 09:52 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Woodybob, Oh no, been working on this one for several weeks. It's a great kit, but is also a challenging build.
PAT
Old Jan 13, 2010, 10:31 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Building the Oar Locks
The oar lock pins were fitted into a cutting jig and cut to length, then removed from the jig and glued into the laser cut plywood brackets.
Old Jan 13, 2010, 10:39 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Finishing the Inside
Got the last of the interior details in and painted. From here, it's on to the oars.
Old Jan 13, 2010, 10:54 AM
Brooks is offline
Find More Posts by Brooks
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
Beautiful, thanks for the thread!
Brooks is offline Find More Posts by Brooks
Alert M.A.C.K. PRODUCTS raises PRICES on MIDWEST R/C MODELS frankg Scale Boats 2 Nov 04, 2009 07:37 AM
New Product Legend Model Boats, new kit release "ST. LAWRENCE River Skiff frankg Scale Boats 14 Sep 09, 2009 11:52 AM
Mini-Review Jersey Speed Skiff from M. A.C.K. Products P. Tritle Scale Boats 66 Aug 26, 2009 07:21 AM
Alert Notice To Customers Ordering Imex Model Boats From M.A.C.K. Products frankg Scale Boats 3 Aug 06, 2008 06:55 PM
Discussion M.A.C.K. products 2400 motor empirebuilder Dock Talk 2 Jul 16, 2006 09:50 AM
