n/a Posts
Re: Heating a workshop/garage
In article <7r5mo4Fb4pU1@mid.individual.net>, Donwill
<Donwill.seesig@invalid.invalid> writes >It's far too cold to go and play with my newly aquired mill in the >wksp, I've started insulating it but heat is required to create a >decent environment. >To minimise the risk of condensation on machines the temperature should >be kept reasonably constant but that's expensive if you heat to a >comfortable working temperature. What do experienced wksp engineers do? >and what type of heating do you reccomend? >Don Don, When I expanded from my small workshop a year or so ago to annexe the garage, I had the same issue. The workshop is not heated but is open to the house and reasonably warm; the garage was unusable in winter as it was. I decided the first need was to insulate. I fitted fibreglass insulation and plasterboard to the roof. An estimate of heat loss (Googling "heat loss calculator" will show up dozens of pro-formas, though not many cover steel doors) showed that most was lost through the steel un-and-over door, but the manufacturer did not supply insulation panels for it (sidebar - should it not be a requirement to make these available? - the heat lost through these things can be enormous). I am still working on this, something cobbled up from polystyrene or polyurethane sheets seems probable. Then I fitted heaters. It seemed to me that electrical heating was the only sensible option, and I fitted a couple of ceramic panel heaters from Machine Mart: http://www.machinemart.co.uk/shop/ca.../panel-heaters and wired them up through a cheap wall-mounted thermostat from Screwfix. A little experimentation is required to get the desired temperature, as (certainly in my experience) the temperature achieved fell rather short of the marked figures. My experience is that I need to improve the insulation or crank up the heat to make the garage habitable first thing in the current weather - it improves once I have opened the door connecting it to the house for a couple of hours, though still a bit nippy. However, it has, so far, meant that I have seen no signs of corrosion on the machinery and tooling stored there. David -- David Littlewood |
n/a Posts
David Littlewood wrote:
> In article <7r5mo4Fb4pU1@mid.individual.net>, Donwill > <Donwill.seesig@invalid.invalid> writes >> It's far too cold to go and play with my newly aquired mill in the >> wksp, I've started insulating it but heat is required to create a >> decent environment. >> To minimise the risk of condensation on machines the temperature >> should be kept reasonably constant but that's expensive if you heat >> to a comfortable working temperature. What do experienced wksp >> engineers do? and what type of heating do you reccomend? >> Don > > Don, > > When I expanded from my small workshop a year or so ago to annexe the > garage, I had the same issue. The workshop is not heated but is open > to the house and reasonably warm; the garage was unusable in winter as > it was. > > I decided the first need was to insulate. I fitted fibreglass > insulation and plasterboard to the roof. An estimate of heat loss > (Googling "heat loss calculator" will show up dozens of pro-formas, > though not many cover steel doors) showed that most was lost through > the steel un-and-over door, but the manufacturer did not supply > insulation panels for it (sidebar - should it not be a requirement to > make these available? - the heat lost through these things can be > enormous). I am still working on this, something cobbled up from > polystyrene or polyurethane sheets seems probable. > > Then I fitted heaters. It seemed to me that electrical heating was the > only sensible option, and I fitted a couple of ceramic panel heaters > from Machine Mart: > > http://www.machinemart.co.uk/shop/ca.../panel-heaters > > and wired them up through a cheap wall-mounted thermostat from > Screwfix. A little experimentation is required to get the desired > temperature, as (certainly in my experience) the temperature achieved > fell rather short of the marked figures. > > My experience is that I need to improve the insulation or crank up the > heat to make the garage habitable first thing in the current weather - > it improves once I have opened the door connecting it to the house for > a couple of hours, though still a bit nippy. However, it has, so far, > meant that I have seen no signs of corrosion on the machinery and > tooling stored there. > > David Thanks for that David, I'm thinking of removing the garage door and replacing with an insulated stud wall and an used pedestrian access 3ft wide fire door which I picked up cheaply for £10. I have a car port which abuts directly on to the existing garage door and I have another 2 off road parking places so I don't think that planning will be interested "I hope". A friend told me about a method of keeping the dreaded rust away by attaching low voltage power resistors to the machines which seems to be quite successful in his case. I haven't done it myself yet but the time will come as I am collecting resistors to put it into practice. Don |
n/a Posts
> In article <7r5mo4Fb4pU1@mid.individual.net>, Donwill > <Donwill.seesig@invalid.invalid> writes >> It's far too cold to go and play with my newly aquired mill in the >> wksp, I've started insulating it but heat is required to create a >> decent environment. >> To minimise the risk of condensation on machines the temperature >> should be kept reasonably constant but that's expensive if you heat to >> a comfortable working temperature. What do experienced wksp engineers >> do? and what type of heating do you reccomend? >> Don > > Don, > > When I expanded from my small workshop a year or so ago to annexe the > garage, I had the same issue. The workshop is not heated but is open to > the house and reasonably warm; the garage was unusable in winter as it was. > > I decided the first need was to insulate. I fitted fibreglass insulation > and plasterboard to the roof. An estimate of heat loss (Googling "heat > loss calculator" will show up dozens of pro-formas, though not many > cover steel doors) showed that most was lost through the steel > un-and-over door, but the manufacturer did not supply insulation panels > for it (sidebar - should it not be a requirement to make these > available? - the heat lost through these things can be enormous). I am > still working on this, something cobbled up from polystyrene or > polyurethane sheets seems probable. > > Then I fitted heaters. It seemed to me that electrical heating was the > only sensible option, and I fitted a couple of ceramic panel heaters > from Machine Mart: > > http://www.machinemart.co.uk/shop/ca.../panel-heaters > > and wired them up through a cheap wall-mounted thermostat from Screwfix. > A little experimentation is required to get the desired temperature, as > (certainly in my experience) the temperature achieved fell rather short > of the marked figures. > > My experience is that I need to improve the insulation or crank up the > heat to make the garage habitable first thing in the current weather - > it improves once I have opened the door connecting it to the house for a > couple of hours, though still a bit nippy. However, it has, so far, > meant that I have seen no signs of corrosion on the machinery and > tooling stored there. > > David erm - you may as well extend your domestic heating system into the workshop and use a controller/timer/thermostat device to operate a motorised valve and leave the door through to the house closed. That way you can apply a bit of background heat to the garage without venting all of the cold air into your house. The ceramic heaterrs can operate via a cheap mechanical timer and your screfix thermostat to provide a bit of heat when your CH isn't running - in the middle of the night for example. just my 10p worth regards dudley |
n/a Posts
Donwill wrote:
> Snip > A friend told me about a method of keeping the dreaded rust > away by attaching low voltage power resistors to the machines which > seems to be quite successful in his case. I haven't done it myself yet > but the time will come as I am collecting resistors to put it into > practice. > Don As Don's "friend" I've taken some pictures of my machine heaters Myford ML7R Lathe 2 x 5 ohm in series on 16v http://i115.photobucket.com/albums/n...s/IMG_0982.jpg Myford VMC Mill 4 x 39 ohm in parallel also on 16 v http://i115.photobucket.com/albums/n...s/IMG_0981.jpg http://i115.photobucket.com/albums/n...s/IMG_0979.jpg About 25 watts into each machine. Has kept rust away for 30 years in an unheated single skin brick workshop. The only other 'precaution' is not cleaning up any oil splashes from normal use. Bob |
n/a Posts
On Thu, 14 Jan 2010 08:19:43 +0000, Donwill
<Donwill.seesig@invalid.invalid> wrote: >Generally speaking, the air passing through the unit needs to be cooled >to remove moisture, how does the unit apply heat to warm it up to >working temp, is this where the so called "split" system comes in? The split is simply the two units, external and internal which are separated by the refrigerant pipes (compared with the old window fitting combined unit where the two were in the same big box). The one I have when operated in dehumidifier mode the unit is switched automatically so the indoor unit alternates between having hot pipes for heating and short periods where the refrigerant is reversed to cool them to condense moisture out. If the room temperature is at the temperature set on the thermostat it runs in dehumidifier mode. Most have timer functions built in so you can have them turn on and off by themselves - they often can't easily be controlled by a separate time switch. http://global-cooling.co.uk is a company specialising in DIY units. There are some useful documents on installation at http://global-cooling.co.uk/aircondi...ing/#section-2 I've used them a few years ago and they were very helpful when I talked to them about what was needed. Many units meant for DIY now come with "easy fit" sealed pipe runs with snap fit connectors which makes installation easier. |
| Thread Tools | |
| Garage/workshop temprature control... | kepople | Electric Plane Talk | 13 | Apr 30, 2004 11:51 AM |
