Old May 13, 2003, 08:24 PM
Lv2Fly is offline
Find More Posts by Lv2Fly
RC-Nut-Job!
Lv2Fly's Avatar
New York
Joined Jul 2001
High or Low Gov mode on CCP-10 controller
Hello All:
My Question is:
I have a B20-36S on my Pic-Pro and I'm using the CC-P-10 controller.
Should I run the controller at Low Governer or High Governer setting on the P-10?
Any suggestion would be great.
I'll probaly try both, but just want to know if high or low is better from others.
James
Lv2Fly is offline Find More Posts by Lv2Fly
Old May 14, 2003, 04:49 AM
sao_bilious is offline
Find More Posts by sao_bilious
Smoke me a Kipper
sao_bilious's Avatar
UK, Beds
Joined Jan 2003
Low speed Governor for a Pro
You may find that motor a little underpowered
A B20 31s is better
Alternative is the Model Motors AC1215/20
Mega power from the B20 18L (but chews thru batteries)
Make sure ALL cutoffs are disabled or at lowest setting on the Phoenix if you are to use in a heli.
sao_bilious is offline Find More Posts by sao_bilious
Old May 14, 2003, 08:54 AM
andyhu is offline
Find More Posts by andyhu
houston texas
Joined Dec 2002
Everyone recomends using the low mode becasue it gives better resolution, but I couldn't get above 1100 rpms with mine so I switched to the high mode, it seems to be working fine???
andy
andyhu is offline Find More Posts by andyhu
Old May 14, 2003, 04:45 PM
Lv2Fly is offline
RC-Nut-Job!
Lv2Fly's Avatar
New York
Joined Jul 2001
Low Gov
Thanks for the input .
I have it set for Low Gov. Seems to be working just fine.
Dont know exact rpm as I don't have anyone to Tach the head for me.
But it sure fly's with plenty of power...
Thanks again...
James
Old May 16, 2003, 07:12 AM
Smoke me a Kipper
UK, Beds
Joined Jan 2003
The Phoenix does seem to behave differently depending on the software versions.
Glad you got it up and running, I only suggested it might be a bit underpowered as i had previously tried that motor but it did'nt have enough guts for my liking.
Well as a rough guide you could strap the heli down and tach it at 0 pitch. this should give you an indication of what it is.
Or if your brave (stupid enough) you can hold it in your hand and tach it that way. I have used this method before but it IS better if you have a friedn who can hold the tach and read off the numbers as you fiddle with the throttel curves.
Hacker B20-18L, High or Low Gov Mode? Brill 1 Mini Helis 3 Oct 31, 2004 03:57 PM
Phx45 low rpm in Gov mode on heli, what up? JoeR Castle Creations 23 Aug 20, 2004 02:59 PM
Schulze 45Ho mode on Logo 10 Steph280 Electric Heli Talk 0 Apr 04, 2002 10:26 PM
Setting up gov mode on smile 40-6-12 ALVES Electric Heli Talk 7 Apr 03, 2002 07:48 AM
ESC switching frequency... high or low? paulaac Power Systems 22 Feb 27, 2002 11:14 AM
