Old Jan 12, 2010, 03:19 PM
hawaiianspork226 is offline
Find More Posts by hawaiianspork226
hawaiianspork226's Avatar
Orlando Int, Florida, United States
Build Log
CNC router table build
yay for the new forum!
strange timing too, as we (my roomate and i) have set out to build a CNC router table. it will be our first CNC machine.
the specified cutting envelope SHOULD be 24"x48"x5", rack and pinion x and y, leadscrew z with highest speeds around 450ipm, if we ever use that. this machine will be mainly for foam cutting so if we can find a good ratio of RPM to feed rate then we may be able to cut foam really fast; convenient for us as we build mainly in foam.
the rough table is finished but we are still working on the gantry and z carriage. we are currently at a lull in the build while we wait for funding to become available again. in the mean time though there are a few things we can be doing before taking the next big steps, which are:
order the rest of the bearings
order racks and pinions, and z leadscrew / leadnut
choose / buy router and bits
order electronics outfit (if the steppers at skycraft dont fit the description)
choose / get software... still need to learn a lot about that but we will deal with that as it gets closer
im leaving work now. ill take a few pictures of our progress and problems and post them later
-david
hawaiianspork226 is offline Find More Posts by hawaiianspork226
Old Jan 12, 2010, 05:43 PM
philba is offline
Find More Posts by philba
Prop Buster Extraordinaire
philba's Avatar
Seattle
Joined Aug 2009
You probably know this but cnczone has a pretty extensive section of DIY router tables. There are several free designs and lots of variants. Good advice to be had there.
philba is offline Find More Posts by philba
Old Jan 13, 2010, 10:23 PM
theothers is offline
Find More Posts by theothers
theothers's Avatar
Joined Aug 2009
Not sure if you are aware but the Phlatprinter was specially designed for cutting sheets of foam. You can check it out at www.phlatboyz.com.
theothers is offline Find More Posts by theothers
Old Jan 13, 2010, 11:52 PM
ThermalThief is offline
Find More Posts by ThermalThief
Do it AGAIN! This time BETTER!
ThermalThief's Avatar
WA
Joined Jan 2005
David,
I am on the same mission.
Linear rails from China
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
1/2" Acme screws from Florida
http://www.precisiontechmachining.com/id1.html
All received this week.
Table construction starts Friday!
Additionals
Hobby CNC 3-axis EZ with 305oz steppers
Bobcad v23 for my cad/cam
I have Mach3 for my CNC foam cutter so I'm good there
Hitachi KM12VC Router
Ken
ThermalThief is offline Find More Posts by ThermalThief
Old Jan 14, 2010, 02:51 PM
definately heard of the phlatprinter! its on my to do list, believe me! for 2d cutting a limited 3d relief it would be fantastic to have. what i want right now though is the ability to carve whole fuselage halves, wings, tails, cowl plugs, canopy plugs, etc and i need more Z motion than the phlatprinter can give me. as i said before though, i definately still want one eventually... maybe when i get my tax returns...
good luck on your build Ken, are you going to do a build thread too?
heres a few pics of where we are with ours. i took them kinda quickly and while it was off the workbench so the photos arent great. i needed the bench space for a quick build this week. when we get it back up there and working on it ill take progress pictures as we go.
-david
Old Jan 15, 2010, 08:12 AM
salty9 is offline
Find More Posts by salty9
Joined Aug 2009
this is our z carriage so far. it may end up just a mockup because of the way this "plywood" is behaving. very poor quality plywood. nice veneer finish though. deceptive, dissapointed.
67.0 KB
Have you considered using tempered Masonite? I used to test the stuff and its properties should meet your requirements. I know it's too thin but 1/4 inch stock could be laminated screen side to screen side with a good contact cement.
salty9 is offline Find More Posts by salty9
Old Jan 15, 2010, 04:07 PM
maybe... if i could get a strong enough bond out of 2 layers of that stuff to be able to drill and tap for 1/4-20 studs into the ends of it, then theres a solution!
im leaning towards MDF more now though, just b/c its literally around the corner at lowes...
-david
Old Jan 15, 2010, 09:10 PM
salty9 is offline
Joined Aug 2009
A problem I've found with MDF is that you need hardware designed for MDF to make reliable connections.
Old Jan 16, 2010, 08:22 AM
not sure i follow... you mean fasteners and such? like the screws are different? ive never really built a whole lot from MDF aside from the typical prefab desk / cabinet type setup. they usually have those cool rotating anchors though; where a slotted peg justting from one part is inserted into the end of another part through a hole, where it meets a circular metallic anchor that has a slot 180degrees around its circumference, which gets turned to "lock" into the peg... is that what you are talking about?
-david
Old Jan 16, 2010, 11:35 AM
salty9 is offline
Joined Aug 2009
Thats the type of hardware I'm talking about but I've found that with hard usage the MDF tends to split away from them.
Another good substitute would be Baltic or Russian Plywood. It is very stable with thin veneers and few voids but tends to be expensive.
Old Jan 19, 2010, 12:52 PM
DeadTom is offline
Find More Posts by DeadTom
Team of ONE....or...Team Me
DeadTom's Avatar
Reno, Nevada
Joined Oct 2006
On my JGRO machine I used regular bolts/nuts and screws to hold it all together, it is alot of work but you first drill the mdf then tap it to the correct size, then you put a little amount of CA glue in to the hole let it cure then re-tap it and you should be ready to go. Just don't overtighten the hardware and you will be fine. I have not had any failures with any of my connections/joints where I have joined the mdf with hardware.
The problem that I have with mdf is that it was not made for this type of abuse and it will start to split at certain points, like at all the adjustment blocks that hold the linear rails and the router mount.
The next machine I build will be a mix of aluminum, steel and stronger linear bearings.
DT
DeadTom is offline Find More Posts by DeadTom
Old Jan 19, 2010, 04:11 PM
philba is offline
philba's Avatar
Seattle
Joined Aug 2009
A number of people are using HDPE for the adjustment blocks. I think that would last pretty well.
If I were to build a JGRO machine, it would mainly be to cut the parts for a joe2006 so longevity isn't super important. I'm still not 100% sure what I'm going to do, though.
Old Jan 19, 2010, 07:55 PM
salty9 is offline
Joined Aug 2009
HDPE cutting boards hold up very well and could be a material source for adjustment blocks.
Old Jan 20, 2010, 12:02 AM
DeadTom is offline
DeadTom's Avatar
Reno, Nevada
Joined Oct 2006
I have ordered and recieved from McMaster-Carr a 12" x 24" x "1/2" sheet of HDPE and I have already designed my new router mounts and adjustment blocks for my JGRO and all I need to do is cut them and install them.
HDPE is fairly inexpensive as compared to Delrin and the HDPE cuts really easy, best to mill it when it is colder.
DT
Old Jan 20, 2010, 07:10 AM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
This place is a little cheaper than McMaster-Carr for HDPE.
http://www.interstateplastics.com/pl...php?sku=HDPNEC
Steve
SteveC68 is offline Find More Posts by SteveC68
For Sale Cyber NC CNC router table Mike Hall Non R/C Items (FS/W) 0 Nov 25, 2007 09:09 PM
For Sale CNC router table and vacuum former Mike Hall Non R/C Items (FS/W) 2 Aug 22, 2006 10:09 AM
For Sale CNC 3 axis router table topforce Non R/C Items (FS/W) 0 Jul 02, 2006 01:34 PM
Looking for CNC router table FHHOBBIES The Builders Workshop 13 Jul 19, 2005 08:39 AM
WTB CNC Router table corey Aircraft - Electric - Airplanes (FS/W) 2 Dec 10, 2003 08:16 PM
