Old Jul 01, 2010, 07:21 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Thanks Qwerty.
Eric B.
AirX is offline Find More Posts by AirX
Old Jul 08, 2010, 05:36 PM
grc159 is offline
Find More Posts by grc159
Joined Apr 2010
TJZOIDE update - metric, hpgl, more tpi and pitch available
Originally Posted by heliinferno View Post
Looks like a very interesting program - good job!
Do you plan to provide a free evaluation copy?
Is it possible to switch to metric units and can the thread pitch of the lead screw also be set to any free value, except the 20, 10 and 5 TPI ?
Phil
Phil,
Another update, metric units are now available. Also HPGL import. Back end now support more TPI/pitch, 20,16,12,10,5 TPI and 1.5mm and 1.25mm pitch. It is now easy in the backend to add more TPI/pitch, so if you don't see it here, PM me for specific value needed. Is easy to add now, but requires me to add it. Also a few ither minor features for re-centering cross sections and fuselage have been added.
Fredy
grc159 is offline Find More Posts by grc159
Old Jul 08, 2010, 08:20 PM
arnoud is offline
Find More Posts by arnoud
Joined Jul 2010
Grasshopper for Rhino
I use Grashopper for Rhino to generate g-code when cutting complex geometry and run the code with mach3. Grasshopper is a parametric plug-in which is embedded in the Rhino 3d modelling environment. The complete four axis g-code updates in real time as the geometry is changed which reduces the time spent on preparing the cutting big time!
http://www.youtube.com/watch?v=Wh9dCQtWLm8
regards, Arnoud
arnoud is offline Find More Posts by arnoud
Old Jul 23, 2010, 10:02 PM
mscho1 is offline
Find More Posts by mscho1
mscho1's Avatar
United States, MI, New Baltimore
Joined Feb 2006
I have TJZOIDE and it works great! I plan on doing a giant Hellcat with it.
mscho1 is offline Find More Posts by mscho1
Old Jul 30, 2010, 09:09 AM
cncworkbench is offline
Find More Posts by cncworkbench
White Hat and Proud
cncworkbench's Avatar
Australia, VIC, Melbourne
Joined Nov 2009
cncworkbench
If you are after a 4 axis Gcode generator designed for foam wing cutters then cncworkbench maybe an option.
You can download a free demo version from www.rcplans.com.au
For a overview have a look at......
Overview.avi (5 min 27 sec)
Regards
Andy
cncworkbench is offline Find More Posts by cncworkbench
Old Jul 30, 2010, 09:19 AM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Mine.. DIY
The first scripting attempts on Rhinocam for HWC
Proposal is cut in discrete parts
http://www.rcgroups.com/forums/attac...mentid=2500190
...virtual parts
http://www.rcgroups.com/forums/attac...mentid=2500737
wich are placd in virtual machinespace to create NC Code
http://www.rcgroups.com/forums/attac...mentid=2505177
and will be physically manufacturable
Program is rather Machine related and still someway buggy but as I know how the weak points its just handy for me ( still far from being able to be published or shared....)
http://www.rcgroups.com/forums/attac...mentid=2543166
Final
http://www.rcgroups.com/forums/attac...mentid=2663375
and Video..
typhoon 0001 (1 min 50 sec)
Harpye is offline Find More Posts by Harpye
Old Oct 10, 2010, 01:12 AM
EINA is offline
Find More Posts by EINA
South - Africa
Joined Nov 2007
Any one knows if CeNeCe is still available? Their website is still up.
EINA is offline Find More Posts by EINA
Old Oct 15, 2010, 07:16 PM
Smoke7 is offline
Find More Posts by Smoke7
Smoke7's Avatar
Springboro
Joined Sep 2004
Eric, I am thinking to build hot wire CNC with
TB6560 4 Axis CNC Stepper Motor Driver Board Controller and there are so many different motors available on e-bay, but I kind of like this ones http://cgi.ebay.com/ws/eBayISAPI.dll...STRK:MESELX:IT
Will you recommend them?
Smoke7 is offline Find More Posts by Smoke7
Old Oct 16, 2010, 01:25 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Try HobbyCNC, thier smallest motor is more than adequatre for wire cut and half the price of the one you pointed to.
http://www.hobbycnc.com/products/stepper-motors/
Wire cut machines have very little drag on the wire if any as the wire burns away the foam and there is nothing to hold the wire. So low power motors work well with them.
Eric B.
Old Oct 17, 2010, 09:31 PM
Smoke7 is offline
Smoke7's Avatar
Springboro
Joined Sep 2004
Eric, Thanks for the link, but the motors they have is twice bigger and much more expensive that I found on e-bay. Thanks anyway.
Old Oct 18, 2010, 12:20 AM
Ward Hagaman is offline
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
Have you seen this site? http://www.alltronics.com/cgi-bin/ca...ry=55&start=20
They seem to have good prices in case Ebay doesn't have exactly what you want.....
Ward
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Oct 18, 2010, 11:44 AM
Devine is offline
Find More Posts by Devine
Devine's Avatar
Netherlands
Joined Feb 2002
Bought the TB6560 and everything works fine with Mach3 and the Nema23 steppers. I want to use GMFC and therefore you need a timer. Thats no problem to make.
Just need some help how to assemble this timer to the parallel cable and how the pin layout should be.
Someone experience with this combination??
i use the timer from the GMFC site
http://gm.cnc.free.fr/CNC/timer_quartz.zip
Devine is offline Find More Posts by Devine
Old Oct 18, 2010, 07:20 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
The #23-130-DS8 motor at Hobby CNC is a little more than half the price of the one your link pointed to. If you find motors that cost less then that is what I would get.
Eric B.
Old Oct 19, 2010, 02:34 AM
dpot is offline
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
i have built 3 of the hobbycnc kits and can recommend them not only do you get a bullet proof board but you get very good backup at a good price
dpot is offline Find More Posts by dpot
Old Oct 19, 2010, 09:55 AM
EINA is offline
South - Africa
Joined Nov 2007
Except that they've never answered my e-mail, with a question or two about theur products
Discussion Cutting foam cores - how to improve? jaron The Builders Workshop 28 Jan 18, 2010 07:39 PM
Discussion cutting foam van.dallas Foamy EDFs 27 Sep 22, 2009 06:29 PM
Discussion [Question] : Foam cutting correct sequence FlyDave Foamies (Scratchbuilt) 0 Sep 19, 2009 05:17 AM
For Sale A Beginner's Guide to Cutting and Bagging Foam Wings Curtis Suter Aircraft - Electric - Airplanes (FS/W) 0 Sep 03, 2009 09:31 AM
Discussion New to foam cutting ... not happy with my rig richg99 The Builders Workshop 16 Aug 27, 2009 08:58 AM
