This is th e originator: http://www.cnc-hotwire.de/ (german only too). The original idea of an absolute low cost CNC was a little spoiled by me by using the alu-profile framing and pretty good Nema 23 motors (0.9°) and microstepping control. The table can be stowed away by swinging it down, the frame is savely above my head. So it don't steal to much workspace when not being used. Control uses EMC2 with custom kinematics. Disadvantage is the low lateral stability. The two wires can move sidewards. There had been some proposals to add a lateral guide that seems to fix this pretty well. But I did not yet installed it on my machine. For the critics, the wires are Dyneema fishing line. Extremly durable with almost no elasticity, great material. The acuracy is as precise as you can measure the geometry. The beauty is the absense of any linear bearings and spindles. I even simplified the wiches by using the motor axles directly. regards Peter |
For the precise value you would need to make test cuts with different speed and measure it. Usually you take a foam piece and measure the total thickness before and after slicing it a number of times. I'm to lasy to measure it and usually just enter estimations
Adam |
Joined Apr 2010
A few more features added to TJZOIDE
A quick update, since last post I've added the following features:
1. Kerf compensation for fuselage parts, per cross section, per cut id, per projection (forward or back). You enter the values as needed. 2. Import .DAT files for cross sections. 3. Full, 1/2, 1/4, 1/8, 1/16 resolution steps in conjunction with 20, 10, and 5 TPI lead screws. 4. Rotate objects 90 degrees. |
Joined Mar 2009
Do you plan to provide a free evaluation copy? Is it possible to switch to metric units and can the thread pitch of the lead screw also be set to any free value, except the 20, 10 and 5 TPI ? Phil |
Joined Apr 2010
Fredy |
I use mastertcam & mach, technology tetris.
http://bukvorez.ru/blog/_su-27.htm |
Qwerty1000,
Very nice work on the Su27. Can you explain where to get the programs you use? Eric B. |
Latest blog entry: T/A 37 Tweet/Dragonfly
| Thread Tools | |
| Discussion Cutting foam cores - how to improve? | jaron | The Builders Workshop | 28 | Jan 18, 2010 07:39 PM |
| Discussion cutting foam | van.dallas | Foamy EDFs | 27 | Sep 22, 2009 06:29 PM |
| Discussion [Question] : Foam cutting correct sequence | FlyDave | Foamies (Scratchbuilt) | 0 | Sep 19, 2009 05:17 AM |
| For Sale A Beginner's Guide to Cutting and Bagging Foam Wings | Curtis Suter | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 03, 2009 09:31 AM |
| Discussion New to foam cutting ... not happy with my rig | richg99 | The Builders Workshop | 16 | Aug 27, 2009 08:58 AM |
