Old Apr 06, 2010, 02:03 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Does it have kerf compensation?
Adam
wyowindworks is offline Find More Posts by wyowindworks
Old Apr 06, 2010, 02:17 PM
grc159 is offline
Find More Posts by grc159
Joined Apr 2010
Adam,
Wings have kerf compensation. There is a configuration for the diameter of the wire cut. Fuselage parts currently do not have it.
Fredy
grc159 is offline Find More Posts by grc159
Old Apr 06, 2010, 02:26 PM
Just fly it!
Cody, WY
Joined Nov 2007
Are you able to have an seperate/different kerf compensation for the tip and the root?
Can .dxf formats be imported?
Adam
Old Apr 06, 2010, 02:36 PM
grc159 is offline
Joined Apr 2010
No. It is the same across. However, there is an option when designing the wing that allows you to keep the same thickness from root to tip, by proportionally deforming the airfoil at the wingtip. I use this when cutting small wings, or highly tapered wings.
Old Apr 06, 2010, 06:31 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Nice work. The program works pretty good. Pm me with typical pricing on your software.
Cheers,
Eric B.
AirX is offline Find More Posts by AirX
Old May 06, 2010, 09:57 PM
mscho1 is offline
Find More Posts by mscho1
mscho1's Avatar
United States, MI, New Baltimore
Joined Feb 2006
Please let me know what the price is of this program.
mscho1 is offline Find More Posts by mscho1
Old May 09, 2010, 01:11 AM
mlmcquiggjr is offline
Find More Posts by mlmcquiggjr
Joined Dec 2005
Upper tower support
GRC159(Freddy) In your video cutting out the x29 section you quickly panned over the upper support of the cnc foam cutting machine, I happen to have a similar machine built from pdf plans bought online. Could you photograph the top of your support structure for us? Your software is very good.
mlmcquiggjr is offline Find More Posts by mlmcquiggjr
Old May 09, 2010, 01:45 AM
Arbo is offline
Find More Posts by Arbo
Joined May 2000
Arbo is offline Find More Posts by Arbo
Reply With Quote  (Disabled)
Old May 09, 2010, 05:54 PM
dc3t_driver is offline
Find More Posts by dc3t_driver
dc3t_driver's Avatar
Joined Nov 2006
Just had a quick look at an e-bay listing for TJzoide from Fredy and it lists for $39. Not bad for what seems to be a fairly easy to use program.
dc3t_driver is offline Find More Posts by dc3t_driver
Old May 10, 2010, 08:45 AM
mscho1 is offline
mscho1's Avatar
Joined Feb 2006
I can't find TJzoid on Ebay, what Ebay are you using?
Old May 10, 2010, 09:48 AM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Try doing a google search for TJoide. It will bring up an auction from another country.
http://cgi.ebay.pl/TJZOIDE-CNC-CAD-C...item4a9f489021
SteveC68 is offline Find More Posts by SteveC68
Old May 10, 2010, 02:51 PM
jcyr1 is offline
Find More Posts by jcyr1
United States, AZ, Surprise
Joined Jul 2002
Fredy, Interesting software........Which boards will it drive? I have the MM2001 board that works with GMFC, but also have CNCHobby board. Some of your tutorials have volumn problems....The price is very reasonable.
John
jcyr1 is offline Find More Posts by jcyr1
Old May 11, 2010, 09:16 AM
SteveC68 is offline
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Eric,
Did you ever try the Foamcutter software from Stealthplane works?
Steve
Old May 11, 2010, 12:12 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Hi Steve,
Not yet, have not had the funds to do much other than work with the projects on hand at the moment. When I started this thread i was looking for software that would be a little more intuitive than GMFC and the one that i have been able to look at that is a little easier to work with is CeNeCe, I only have a downloaded version that is limited in time which has expired but during the time I played with it I was impressed in its feedback for wire path. Nice graphics, cutting requires a liscensed version IIRC.
I have an X32 that is just about ready to cut and will use GMFC to cut it. I have a thread on it in my blog and the scratchbuild forum. The outlines will be PDF so others can hand cut it if they want one.
Eric B.
Old May 14, 2010, 08:39 AM
vampire67 is offline
Find More Posts by vampire67
Charged up and buzzing
vampire67's Avatar
Germany
Joined Aug 2005
Originally Posted by grc159 View Post
The software drives 4 axis, 200 step/revolution motors, 1/2 step boards, 20 threads/inch leadscrews, using step/direction/enable signals. A 5th axis can be used to control temperature - picture a 5th stepper motor turning a knob for temperature.
The program drives the parallel port directly. At this time only windows XP for driving the machine, and XP or Vista for making the design.
I would suggest adding an intermediate step to export cut data as G-code. This would multiply the potential customer base by not being bound to OS and specific maschines.
I will not start cluttering this thread about discussing Windows as a controller software
I'm personally using a non-karthesian foam cutter maschine (hotwinch based on 4 ceiling mounted winches) and would NEED intermediate G-code to work with.
P.S. as for other usable programs don't forget ProfiliPro v2.
Also it seems DevFuse from the same author can output 4-achsis G-code.
vampire67 is offline Find More Posts by vampire67
Discussion Cutting foam cores - how to improve? jaron The Builders Workshop 28 Jan 18, 2010 07:39 PM
Discussion cutting foam van.dallas Foamy EDFs 27 Sep 22, 2009 06:29 PM
Discussion [Question] : Foam cutting correct sequence FlyDave Foamies (Scratchbuilt) 0 Sep 19, 2009 05:17 AM
For Sale A Beginner's Guide to Cutting and Bagging Foam Wings Curtis Suter Aircraft - Electric - Airplanes (FS/W) 0 Sep 03, 2009 09:31 AM
Discussion New to foam cutting ... not happy with my rig richg99 The Builders Workshop 16 Aug 27, 2009 08:58 AM
