Old Feb 18, 2013, 06:38 AM
BJ64 is offline
Find More Posts by BJ64
The wheels touch down FIRST??
BJ64's Avatar
Australia, VIC, Melbourne
Joined Jun 2009
Um... could you repeat that?
You mean that no matter where your axes are, if you punch in G0 X0 Y0 Z(home height) in the MDI screen, it will always go home automatically?
If so, how does it know exactly where 'home' is?
Is that something you have preset somewhere first?
Forgive me for sounding dumb - but setting home and getting it to always go there regardless of where each axis is when I turn the machine on is exactly what I'm trying to do...
BJ
BJ64 is offline Find More Posts by BJ64
Old Feb 18, 2013, 10:48 PM
EINA is offline
Find More Posts by EINA
South - Africa
Joined Nov 2007
Are you trying to get the machine to home on start up without home switches? Usually you can only initiate a homing sequence if you have home switches on your machine, other wise you have to jog the machine manually to where you want home and set that position as home. the machine can then be returned to that set home while it has not been switched of.
My machine usually returns to home after a cut, I makes sure its home before i switch it of so I could just set home and continue work on next start up.
EINA is offline Find More Posts by EINA
Old Feb 19, 2013, 05:50 AM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Ahhhh.... thanks!
That's what I've been trying to work out - if it needs switches to be able to "go home" when you start the machine up the next time.
I was hoping that there was some way to set some kind of reference point that the axes would all be able to go back to by hitting "ref all home" - in between turning the machine on and off.
I kinda makes sense that it can't (without switches) - in a way - I guess.
Coz you could always bump/move any axis while the machine was turned off, and it would have no way of knowing that you had done that.
Still - it would be good if you could do a "ref all home", and the software would write that info away to a file somewhere. And when you shut-down properly, it could also write the co-ords of where everything was at that point in time off to another file somwhere.
Next time you start it all up, the software could assume that the axes are at exactly the same position they were when you shut it down last time. Hence, it would still know where 'home' was relative to where it is right now.
The two basic assumptions here are:
1. Nothing has manually moved an axis from where it was at shut-down.
2. You haven't had any lost steps between the 'ref all home' calibration and where it was at shut-down.
After all, the whole CNC things works by internally counting the number of steps on any axis in any given direction, no?
Hmmm... food for thought...
BJ
Old Feb 24, 2013, 05:52 AM
cncworkbench is offline
Find More Posts by cncworkbench
White Hat and Proud
cncworkbench's Avatar
Joined Nov 2009
BJ
Correct ever time you use the machine you need to define 0,0,0. Which is normally where you switched it off. Ie when you finish send the machine home. Its not really a big deal to reset the origin on start up. The only other option is home switches.
cncworkbench is offline Find More Posts by cncworkbench
Old Feb 24, 2013, 06:40 AM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Yah...but on a 4-axis, it'd be nice to know that X/Y & A/B all go back nice and square for the next time you power-up...
BJ
Old Feb 26, 2013, 06:33 AM
White Hat and Proud
Joined Nov 2009
so mdi g0 x0 y0 z0 a0
or if you have used a/b
g0 x0 y0 a0 b0
Old Feb 26, 2013, 09:08 PM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Yes...
But if I issue mdi g0 x0 a0 b0 a0, where exactly is it going to go to?
From what I understand so far, it won't know where "0" is once I turn the machine off - unless I have limiting stwitches... ?
BJ
Old Feb 26, 2013, 10:40 PM
p901P901 is offline
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
All the CNC machines I used you need the machine to find x,y and z limits. And they all have limit switches. This was done every time you turned the machine on. This verifys machines health and the amount of travel the machine has.
You can select where the tool starts and stops. So is this the zero you want?
If so, this is what you need to figure out where your tool start and stop should be and forget about the limit switches. The starts and stops are nearby the work. So keep your work within the limits of the machine.
p901P901 is offline Find More Posts by p901P901
Old Feb 27, 2013, 04:03 AM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Thx P901 - but it's a bit different on a 4-axis foam-cutter.
I need the wire to be square and level in '4' dimensions - X&Y + A&B - if that makes any sense i.e. wherever X&Y are in finite space, A&B have to be exactly parallel and start/end at exactly the same spot.
I'm thinking that without limit switches, I'll probably make a little 'template' right-angled block and have some aluminium strips on the base board where I can ensure the block will always locate into the exact same position when I place it there.
Then all I'd need to do is jog the X/Y & A/B axes until my hot-wire is parallel to the top near edge in both length and height and I should have a common right-angled and square starting point +/- half a mm or or so...
BJ
Old Feb 27, 2013, 11:14 AM
michaelghammer is online now
Find More Posts by michaelghammer
michaelghammer's Avatar
Denmark
Joined Dec 2004
Hi BJ64
My Foam cutter doesn´t have limit switches or homing switches either. Works fine without them because of the slow speeds (100-200mm/minute). My CNC Router has limit switches and they have saved the machine several times. Things happen very fast when jogging at 8000mm/minute!!!
Here´s how I do it:
You only have to set up your machine once. When you´re satisfied with the position of the wire, zero all axis. I use the 4 axis Foam screen set for Mach 3 and then use the jog both axis buttons to jog the x-axis/a-axis simultaniously. Same with y-axis and b-axis. I then jog the wire to the starting position based on the G-code generated by DevFusFoam and the block of foam. I then hit Ref-all and the DRO´s all reset to zero. Now I´m ready to cut.
After the cutting is done I hit Goto-Z and all the axis´ return to the position where I pressed Ref-all. That´s it. No need to have a fixed home. Just make sure you jog the axis´ together or use the command line to enter G-code commands like G00 X100 Y0 A100 B0 etc.
Happy CNC cutting, BJ
- Michael Hammer
michaelghammer is online now Find More Posts by michaelghammer
Old Apr 02, 2013, 07:35 PM
durone is online now
Find More Posts by durone
Italy
Joined Jan 2003
Second that!
Stefano (author of Dev*, Profili etc.) is without doubt a genius. If only he could explain in easy-to-understand English how his software works, his products would be much more of a pleasure to use. Que sera...
I'm the devXXX series and Profili developer, but really not a genius
It isn't so easy to write a good help file for devFus (foam) for me.
Every different shape requires different tricks.
Generally I give some hint to the users that contact me by email.
If some of you has the time-will to write more about the use of devFus, I can then add those text to the official help file as Users Hints.
To make it possible I should get a TXT or doc file for each help page where you like to add your comments.
May be that could help a lot new users...
Actually I'm very busy with releasing the first release of devWing, for ribbed wings (take a look at it the www.devcad.com web site if you like)
But may be we can do something to improve the devFus Help file (I'm italian mother tongue, so not very fluent with english )
Anyway I'm very happy when I see users able to get the best from my applications. I really don't get rich with them, so this is part of the fun...
durone is online now Find More Posts by durone
Old Apr 02, 2013, 08:59 PM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Hi Stefano
Maybe we could start a Wiki on it?
BJ
Old Apr 03, 2013, 03:21 AM
Italy
Joined Jan 2003
Hi Stefano
BJ
Yes, if you know the way it works!
Edit: I took a look at wikipedia rules, and they doesn't like article about manuals, FAQ and so on.
I think I could open a new forum about my main products:
- Profili
- devCad
- devFus
- devFus Foam
- devWing
- devFoam
With different topics grouped by application.
This is not to try to make a big forum and and fight against RCGroup or RCUniverse, but to help the users of my application to find evaluable info and skilled users.
The forum will be somehow moderated to keep spammers away.
Some of you can then be the moderator of some Topic
The Forum will be linked to my web pages www.profili2.com and www.devcad.com
What do you think about this idea?
Old Apr 03, 2013, 06:38 AM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Stefano,
I like Devfusefoam, it is a great product and you have done us a great service. Thank you.
I look forward to aquiring Devwing in the next month or so. I downloaded it last night and learned how it worked to a point and am happy with its abilities. I have not explored what the options of plotting and cutting yet but will eventually when I buy the software.
I will participate in the forum and add what I know to the wiki when you get it up and running.
Cheers,
Eric B.
AirX is offline Find More Posts by AirX
Old Apr 03, 2013, 06:51 AM
Italy
Joined Jan 2003
Originally Posted by AirX View Post
Stefano,
Cheers,
Eric B.
You can find here the forum: http://devcad.forumfree.it/
It's also listed in Profili and devCad web site main menu now.
Discussion Cutting foam cores - how to improve? jaron The Builders Workshop 28 Jan 18, 2010 07:39 PM
Discussion cutting foam van.dallas Foamy EDFs 27 Sep 22, 2009 06:29 PM
Discussion [Question] : Foam cutting correct sequence FlyDave Foamies (Scratchbuilt) 0 Sep 19, 2009 05:17 AM
For Sale A Beginner's Guide to Cutting and Bagging Foam Wings Curtis Suter Aircraft - Electric - Airplanes (FS/W) 0 Sep 03, 2009 09:31 AM
Discussion New to foam cutting ... not happy with my rig richg99 The Builders Workshop 16 Aug 27, 2009 08:58 AM
