Old Jan 12, 2010, 08:39 AM
flimnar's Avatar
Joined Oct 2007
Best 70mm Ducted Fan Unit
I was looking to buy a Wemotec 70mm Ducated Fan unit for my F-117, but they have been out of stock everywhere for quite a while. I'm looking for recommendations for a 3s 70mm Ducted Fan. I have not found anything helpful on this topic using the search engine. Recommendations?
Thanks!
flimnar is offline Find More Posts by flimnar
Old Jan 12, 2010, 09:41 AM
hklagges's Avatar
Munich
Joined Dec 2008
Originally Posted by flimnar View Post
I was looking to buy a Wemotec 70mm Ducated Fan unit for my F-117, but they have been out of stock everywhere for quite a while. Recommendations?
Thanks!
Just an idea: Why not buy them directly from the man at www.wemotec.com? That's where I bought 2 sets of 2 fans each from, including HET engines, all balanced by Mr. Wemotec himself.
Cheers,
Henrik
hklagges is offline Find More Posts by hklagges
Old Jan 12, 2010, 10:04 AM
Team White Llama!
gundamnitpete's Avatar
The shipping charges make it come out to alot more than you would pay from a vendor.
The HET 6904 is a good alternative, aswell as the wm400 mk2.
If you are using 3S, a HET 2W motor is a good choice. Around 400-500 watts depending on batteries.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Jan 12, 2010, 10:25 AM
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
everyone recomended the HET 6904 to me
and I'm super happy with it.. silky smooth and has a nice sound
great performance! I'm running the 1112 1y neu motor on 4s 35c 4200
for 1300 watts
Ron101 is offline Find More Posts by Ron101
Old Jan 12, 2010, 10:29 AM
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
If you don't already have batteries, opt for 4S, The WM400/HET3W is a good economical system on 4S ~ 450 watts at 32 amps for less expensive ESC, longer flight times.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Jan 12, 2010, 01:26 PM
Vault-Tech Approved
Racebelly's Avatar
Simi Valley, CA
Joined Apr 2003
I've used the Wemo and HET's. Both are great fans. But, the new MF Pro impellers are very smooth and quite right out of the box. I think the power is a little less than the HET's. But, there's no balancing and they just sound so good.
As mentioned, on 3s the HET 2W or Mega 2T's are great motors.
Racebelly is offline Find More Posts by Racebelly
Old Jan 12, 2010, 03:20 PM
I make bad look so good.
SteveC68's Avatar
League City, Texas
Joined Sep 2006
The HET is dynamically balanced out of the box. No balance necessary.
SteveC68 is offline Find More Posts by SteveC68
Old Jan 12, 2010, 03:37 PM
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
If you want a little flexability in cell counts, any of the fans mentioned, and the ARC 28-47-1. 650-700W on a 3000 3s. Or 1200-1400W on a 4000 4s. Get a cool clamp for the 4s.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Jan 12, 2010, 04:12 PM
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
I've not been so happy with them, all 3 I have needed quite a bit of work to run smoothly.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Jan 12, 2010, 04:15 PM
Vault-Tech Approved
Racebelly's Avatar
Simi Valley, CA
Joined Apr 2003
I haven't bought an HET in awhile. I didn't know they came pre-balanced now. That's great.
The only problem I did have once with the HET was the collet adapter came loose on me. Luckily it was on a test run-up and not in-flight. In fact that was the HET fan I put a Wemo Pro rotor in. In my Hawk it is so quite and smooth.
-Mark
Old Jan 12, 2010, 05:37 PM
Team Horizon/ BVM jets
Joined Apr 2006
We also have a pretty decent 70mm fan and motor combo.
Sapacamerica.com
pbusa1400 is offline Find More Posts by pbusa1400
Old Jan 12, 2010, 05:58 PM
Vault-Tech Approved
Racebelly's Avatar
Simi Valley, CA
Joined Apr 2003
Originally Posted by pbusa1400 View Post
Were also have a pretty decent 70mm fan and motor combo.
Sapacamerica.com
Good point.
Old Jan 12, 2010, 08:32 PM
Team White Llama!
All my HET's ran smooth out of the box.
Old Jan 12, 2010, 10:26 PM
designer,builder,flyer
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
Just beware of your motor purchase and the shaft size requirement of your fan choice.
I chose the Het 6904/ARC 28-47-1
best bang for the buck imho
ApexAero is offline Find More Posts by ApexAero
Old Jan 13, 2010, 07:01 AM
killickb
The Villages. Florida
Joined Jan 2005
I haven't seen any votes for the Lander/Fury metal housing fans? Are there any obvious performance negatives versus the Wemo, WM, HET units? I am running three of the 70mm Lander units (4-cell) and am quite satisfied but am I missing something (Also have some Wemo and Sapac units)? I do not look for Mach 2 performance in any of my models but might not have the optimum fan/motor combo.
killickb is offline Find More Posts by killickb
Sold WeMoTec Mini 480 Ducted Fan Unit!! xtremeRCpilot Aircraft - Electric - Jets (FS/W) 2 Nov 12, 2009 10:53 AM
Wanted 70mm fan unit with or without motor gotboostedvr6 Aircraft - Electric - Jets (FS/W) 9 Nov 10, 2009 01:31 AM
For Sale brushless 70mm fan unit hobby lobby f-16 abapitcher712 Aircraft - Electric - Jets (FS/W) 3 Nov 04, 2009 12:47 PM
Sold Aveox brushless motor, Aveox 48amp ESC & Wemotec HW609 ducted fan unit smokeytbear Aircraft - Electric - Power Systems (FS/W) 1 Oct 25, 2009 10:40 AM
New Product New !! 70mm Electric Ducted Fan Unit AirPower RC Electric Ducted Fan Jet Talk 25 Jun 29, 2006 01:51 PM
