Old Jan 12, 2010, 12:26 AM
Eric-cn is offline
Find More Posts by Eric-cn
Joined Jan 2010
manufacturer of key chain help you solve the problem for you
manufacturer of key chain help you solve the problem for you.
any questions for key chain.i will try my best to solve the problem.
also i sell the product.
Eric
Eric-cn is offline Find More Posts by Eric-cn
Old Jul 26, 2010, 09:04 AM
Markrel is offline
Find More Posts by Markrel
Joined Jul 2010
Q's
I have the 808 & I have charged it and the light does NOT go out? should I worry about this??
Now PC is telling me USB device Not Recognized ?? I tried rebooting, I tried removing power even from wall, tried removing tick in USB Root Hub power managment setting, But keeps coming up as Unknown Device & properties on it says "No Drivers installed for this device" Of course I try to load a Driver but it says could not find a better match. So what can I do?
Thanx
Markrel
Markrel is offline Find More Posts by Markrel
Old Jul 26, 2010, 09:55 AM
guild1979 is offline
Find More Posts by guild1979
Joined Jan 2010
Having the same problem as Markel with two new 808 's
I purchased two 808 key chain cameras and both have the same problem that Markel noted. Contacted China vendor & he has promised to send two new ones. Anyone out there who has had same experience and can amplify on this problem or provide a solution? Any help would be appreciated.
guild1979
guild1979 is offline Find More Posts by guild1979
Old Nov 09, 2010, 05:09 AM
temporaer is offline
Find More Posts by temporaer
Joined Nov 2010
Ahoyhoy!
Just found this thread via google, i had the same problem as mentioned above.
What helped for ME was, that i resetted this little bugger, i.e. i poke a needle in the little hole between the memory card and the USB-port.
Good luck !!!
temporaer is offline Find More Posts by temporaer
Old Nov 10, 2010, 05:47 AM
randall1959 is offline
Find More Posts by randall1959
Joined Feb 2004
We ALL have this problem. Why can't you guys make one that doesn't have the time and date stamp?
randall1959 is offline Find More Posts by randall1959
Reply With Quote  (Disabled)
Old Feb 01, 2011, 06:29 AM
jjyy2006 is offline
Find More Posts by jjyy2006
Joined Feb 2011
i solve this problem , at left side that key spy cam got small hole , use pen or needle press once that will reset that cam. Now u can off the light and can use as normal.
jjyy2006 is offline Find More Posts by jjyy2006
Old Feb 06, 2016, 06:45 PM
AirDOGGe is online now
Find More Posts by AirDOGGe
Just Plane Nutts
AirDOGGe's Avatar
United States, CA, Mountain View
Joined Dec 2011
Originally Posted by Markrel View Post
... PC is telling me USB device Not Recognized ?? I tried rebooting, I tried removing power even from wall, tried removing tick in USB Root Hub power managment setting, But keeps coming up as Unknown Device & properties on it says "No Drivers installed for this device" Of course I try to load a Driver but it says could not find a better match. So what can I do?
Ive experienced this problem from the start. I just got the cam today, but cannot view files on my PC via the USB. I can only access video files by popping out the SD micro card and plugging it into my PC directly. Setting the reset button with a needle did nothing to fix this particular issue.
I wonder if they even have a Windows-7 32bit driver for it at this price? Anyone see the cam as a hard drive on their Windows machines?
AirDOGGe is online now Find More Posts by AirDOGGe
Old Feb 07, 2016, 03:00 AM
Mtz is online now
Mtz
Find More Posts by Mtz
Mtz
Mtz's Avatar
Romania, PH, Ploiesti
Joined Mar 2012
After 5 years of no reply, I don't think Eric-cn will reply to you.
Mtz is online now Find More Posts by Mtz
Discussion Flight with the Key Chain Spy Cam EQMOD Micro Helis 46 Jan 05, 2010 12:41 AM
Discussion key chain cam rnorth Aerial Photography 2 Dec 22, 2009 01:49 PM
Discussion Key chain camera battery Crist Rigotti Batteries and Chargers 6 Nov 25, 2009 10:50 AM
Discussion 4kW Motorsetup not giveing full power. Help me solve the problem henke Power Systems 5 Sep 04, 2009 03:18 PM
