16" KFm4 wing, David (+ Free Plans)
Well, I have posted this little wing in a couple of different threads, but have decided to give it a thread of it's own. I have included the single letter sized page of 1/2 of the wing plan below. If there are any suggestions on how I can clean up or improve the plan please let me know and I'll make the changes. This thread will also allow for a place to do a build log for when I build another one just as soon as I have some more 3mm depron.
A few weeks ago I drew and built a little 14" wing, my first wing. It was a handful but I got it flying and then decided to retire it as it was a little too much to handle. Inspired by the Goliath from Sylvanaircraft I drew this little 16" wing. Wing Span: 16" Wing Area: ~86sq Inches Weight: ~66grams (~2.32oz) Wing Loading: ~3.9oz/sqft KFm4 Airfoil, 50% steps top and bottom (Entire wing consists of 3 layers of 3mm depron) Motor: 5g Turnigy 1400 4500Kv from HobbyKing with GWS 3x3 prop (possibly a little too much for this motor and the battery but have not had any issues yet, am trying to track down a 3x2) ESC: Pentium/Turnigy 6A Battery: 230mAh 2s lipo Sevos: 2x "3.7gram" RX: Berg 4l This wing is truly a pleasure to fly. It feels very stable and it slows down nicely, the 2nd video below I tried to slow it down some to give an idea. It has no tip plates and I have not had any surprise stalls. Power off it glides reasonably gently down. I had no idea what color scheme to go with so I decided the copy someones. Well at least attempt to copy it. Since Laine's SRT-10 13ft wing saga was what first drew my attention to and got me interested in trying flying wings, I decided to do a rough Sharpie approximation of his SRT-10 color scheme (Hope you don't mind Laine, thanks for the inspiration) Maiden:
After some coloring:
Thanks for the comments Daddy-O.
I found a couple of pictures I took during construction, not a lot but gives a rough idea of the build.
Hey Daddy-O Sorry I have not been very responsive on this thread as of late. I am honored that you would build this wing, thank you! Post some pics and a flight report when/if you get a chance. I am interested to hear how scaling it up but keeping the thickness the same works out. All the best with the maiden!
jdmtech, I am truly sorry I completely missed your comment. From HobbyKing, you could possibly get 2 of these and then solder up your own 2s pack. Otherwise, perhaps one of these or these might work but they are slightly heavier and will most likely need to be place further back from the nose to get the correct balance. I have finished cutting the 20" version (scaled up by hand) and need to get it done. I plan on using a 10gram motor on it. I have been taking pictures of the process to post here, but seem to have misplaced my memory card with them on... I have also since I last posted purchased for myself a GWS 3x2 prop and if flies very similarly to the 3x3 on the vertical but a teeny bit slower in a level pass. The current draw is significantly lower though so I think the battery and motor are both a little happier. bob |
| Thread Tools | |
| Discussion Divinity, 42" KFm4 Slowfying wing. | ApachePilot | Foamies (Scratchbuilt) | 2094 | May 04, 2013 04:40 PM |
| Discussion KFm4-Epp-Swift-Like (KESL) 32" Wing | rdjay | Foamies (Scratchbuilt) | 1056 | Apr 15, 2013 10:34 AM |
| Discussion SpaFFFnutz 48" KFm4 Flying Wing - Electric FFF/Coroplast Hybrid | jackerbes | SPAD - Simple Plastic Airplane Designs | 10 | Nov 25, 2009 02:41 PM |
