Old Jan 11, 2010, 02:57 PM
Mel Harley is offline
Find More Posts by Mel Harley
Joined Jan 2010
Help!
Multiplex Easy Star – PAINT JOB
I have an Easy Star which has given me a lot of enjoyment
I have added brushless motor which is very good
I am ordering another Easy Star which I shall modify to have ailerons
I want to paint the models to improve their looks
WHAT DO YOU PAINT AN EASY STAR WITH ??
What do you rub it down with ?
I have melted other foam models with paint and I don’t want to
melt an Easy Star
Mel
Mel Harley is offline Find More Posts by Mel Harley
Old Jan 11, 2010, 07:15 PM
philba is offline
Find More Posts by philba
Prop Buster Extraordinaire
philba's Avatar
Seattle
Joined Aug 2009
use water based paints. acrylics work quite well. I prime with a water based varnish - polyurethane or polycrylic. foam safe.
You can find some foam safe paint in spray (aka "rattle") cans. or, you can use a brush but it will leave brush marks. The best way is with an airbrush which is surprisingly more affordable than you might think, especially if you have a source of compressed air.
You might also use something called "lightweight spackle" to fill any holes or rough spots. It's sold at home imprevement stores and is used for patching walls. You can tell if it's LWS by picking it up. If the jar feels empty, that's it. foam safe.
philba is offline Find More Posts by philba
Old Jan 12, 2010, 04:11 AM
Joined Jan 2010
Thanks Phil
If they have that stuff this side of the pond. Probably been banned by the EU ??????
Best wishes
Mel
Old Jan 12, 2010, 05:10 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
After cleaning down a repaired ez i used jiffy pressure pack enamel and its held up pretty darn good.
olmod is offline Find More Posts by olmod
Old Jan 12, 2010, 11:40 AM
philba is offline
philba's Avatar
Seattle
Joined Aug 2009
Originally Posted by Mel Harley View Post
Thanks Phil
Best wishes
Mel
I'm pretty sure water based acrylics are available in the EU. Don't know about the spackle but it's not toxic. In fact all those products are pretty safe.
Old Jan 17, 2010, 06:50 PM
cgoffa is offline
Find More Posts by cgoffa
cgoffa's Avatar
Joined Dec 2009
elapor painting
for what its worth you can paint Elapor with pretty much any automotive paint elapor is appx 90% epp and 10% styrene, so its pretty good around solvents, I regulary paint mine with automotive spray cans, just use several light coats to avoid runs and you should be fine . Or you can start using iron on covering, low to medium temp films work great, look good and it can then be sealed around the edges with thinned goop, or even straight goop if you spread it around with your fingers,
cgoffa is offline Find More Posts by cgoffa
Old Jan 25, 2010, 04:14 AM
Easterbunny is offline
Find More Posts by Easterbunny
Joined Jun 2006
Thanks Phil
Best wishes
Mel
It's easier to find Acrylic or waterbased paints in Europe than Oil based. Most of the DIY shops now a days sell more environmental proof / green products.
Don't know where your from but try Hornbach.
Easterbunny is offline Find More Posts by Easterbunny
For Sale relisted bah7566 Aircraft - Electric - Power Systems (FS/W) 1 Dec 06, 2009 03:30 PM
Sold Multiplex Easy Star NIB with 2 canopies and 2 motor/props $90 shipped USPS ground be69ar Aircraft - Sailplanes (FS/W) 4 Dec 03, 2009 08:23 AM
Sold Multiplex Easy Star Kit 54" fritzdecat Aircraft - Electric - Airplanes (FS/W) 2 Nov 29, 2009 01:52 PM
Gallery Maidened new AP Easy Star. Third Flight Crashed. New Paint Job. rbmaze Aerial Photography 5 Jun 18, 2009 03:31 PM
