Oshkosh, WI
Joined Nov 2002
Wow! Anybody still using ModelCad? I was spoiled at work when just had to hand sketch design ideas for our draftsmen/designers to execute in AutoCad or Catia. Bought a ModelCAD package for home use many moons ago & been proficient on it after retirement. How much learning do I need to upgrade to AutoCad or other pkg this forum comes up with?
Phil |
IF you've used ModelCAD, you're ALL SET for DesignCAD...!
Dear PhilLin:
The PIPE here again... ...and, IF you've used ModelCAD in the past, you SHOULD be all set to "step up" to using DesignCAD...! The latest version I'd recommend of it is DesignCAD 3DMax v.17.2, available for as low as $30 before postage, at http://www.amazon.com/IMSI-00D3MX17C.../dp/B000HLT5IU ...! ModelCAD is basically a "sub-set" of the DesignCAD 2D program that Upperspace used to publish...now that IMSI (the TurboCAD people) publishes DC (my abbreviation for "DesignCAD"), you should be able to bring in your ModelCAD drawings into the v.17.2 edition of DC with no problems...! I was using DC 3DMax v.17.2, this MLK Day morning, to start to draft up an "uprated" version of Gordon Whitehead's small, 42" wingspan Bücker Jungmeister (at http://www.rcmplans.com/index.php?ma...oducts_id=1670 for your reference) that I'm planning on powering with a Saito .30 or .40 four stroke, for "sparklingly small" aerobatic performance. I built one from the original RCM plans almost 30 years ago, for HB.25 two stroke power, and now that great design's getting a Carl Goldberg Falcon 56 airfoil (with the chord reduced to 6 inches, and suitably scaled down, ALL thanks to the magic of DesignCAD) and a MUCH closer-to-scale-accuracy 5/32nd inch (4 mm) OD fiberglass tubing fuselage structure, thanks to the NINE PAGES of great photos that can be found at http://www.buecker-museum.de/modellb...l01/133_01.htm ...! Think about getting DC 3DMax v.17.2 at that bargain price... ...best of luck in trying it! Yours Sincerely, The PIPE!
Microstation. I used it a long time ago. It's big in the DOT world. I know they've tried to stay competative with Autodesk but I'm not sure where there at with regards to comparable products to Inventor.
Also, may want to update AutoCAD 2000-2009 to 2010. 2011 will be released in April most likely. |
Oops, missed the second page where the pole has been created oh well.
BTW, not that it matters now but a good way to organized AutoCAD versions is by file format. they change it every three years and name it after the first year. Example 2004 format works for '04, '05 & '06, 2007 format works for '07, '08 & '09. The current release is 2010 which, if history repeats, should be the standard format through the 2012 release. |
Maryland, USA
Joined May 2004
Why ask why? Well, if you must ask, then I can only offer you one outcome other then seeing the many cads I never knew exsisted. From the poll created from this info, there is a pretty clear trend. One that I did not know. The most used cad software seem to be autocad, rhino, sketchup and solid works ( in about equal proportions).
-Kwok |
| Thread Tools | |
| Question What do you recommend as a good CAD program for model design | Warthog_Fan | CAD/CAM | 31 | Feb 24, 2011 10:31 AM |
| Discussion Which goggles are you using or have you tried? | vic20owner | Video Piloting (FPV/RPV) | 18 | Dec 30, 2009 10:12 PM |
| Discussion have a thought for others(what is the nastiest thing you have ever said to someone?) | POWERGROOVES | Life, The Universe, and Politics | 37 | Nov 29, 2009 10:44 AM |
| Rant OK DIYers, Have you tried fixing a tube/tire lately? | 56S | Life, The Universe, and Politics | 28 | Oct 19, 2009 04:56 PM |
| Have you ever tried to solder something and..... | Spencer J | Electric Plane Talk | 42 | Jun 19, 2005 11:20 AM |
