Old Jan 25, 2013, 09:47 AM
starcad is offline
Find More Posts by starcad
AMA 667982 KG7NKY
starcad's Avatar
United States, AZ, Tucson
Joined Sep 2000
Originally Posted by joshgluck View Post
Well apparently I did order the pack with a JST instead of JR plug. Here it is:
So, do I remove the JST and put in a JR servo plug? Is anyone charging their lifepo4 rx packs in the plane? If so are you only charging through the balance plug?
Thx
Just be careful when you remove it. One wire at a time so you don't accidentally short the battery. ( Don't ask me how I know )
starcad is offline Find More Posts by starcad
Old Jan 25, 2013, 11:58 AM
TonyF is offline
Find More Posts by TonyF
United States, CA, Rosamond
Joined Feb 2004
Actually a JST will plug right into a JR plug. Just make sure of the polarity.
TonyF is offline Find More Posts by TonyF
Old Jan 25, 2013, 11:50 PM
joshgluck is offline
Find More Posts by joshgluck
joshgluck's Avatar
United States, NJ, Middletown
Joined May 2012
I tried, wouldn't fit into my spectrum.. can try again i guess
joshgluck is offline Find More Posts by joshgluck
Old Mar 12, 2013, 03:06 PM
zztinker is offline
Find More Posts by zztinker
zztinker's Avatar
United States, CA, Bakersfield
Joined Feb 2007
I just ordered the 62 Osiris with the Castle 100A ESC. Should I have gotten the Castle ICE 100A ESC instead?
zztinker is offline Find More Posts by zztinker
Old Mar 12, 2013, 09:47 PM
joshgluck's Avatar
Joined May 2012
Do you mean ice 100 vs ice lite 100?
Only difference is the heat sink and covering as far as I know. A little less weight. I went ice lite but in a plane like this I'm hoping it doesn't matter.
Old Mar 12, 2013, 11:45 PM
zztinker is offline
zztinker's Avatar
Joined Feb 2007
Thanks for the reply, I ordered the correct esc, just got confussed .....
Old Mar 13, 2013, 07:29 AM
cmoulder is offline
Find More Posts by cmoulder
Pullin' G's Man
cmoulder's Avatar
Ossining, NY
Joined Dec 2005
The built-in BEC in the Ice controller is solid, therefore no need for the Rx battery. 249 flights on mine without a glitch, and before that 40 flights with the 80HV (a lot heavier!).
However, if you feel it absolutely necessary, 1600 mAh is waaaaayyyy overkill. Even 2-meter electric pattern models consume only about 25-40 mAh per flight, so a 400 mAh Rx battery is sufficient, although it is always a good idea to regularly check the Rx battery with a volt meter that puts a .5 or 1-amp load when testing.
This model flies GREAT on the 5S set-up, but it needs to be kept light-light-light!
Welcome to D1 Pattern. There are several Pattern pilots not far from you in central-south NJ and a few of us up here in Westchester County, NY. PM me if you want to come up and fly with us.
Bob
cmoulder is offline Find More Posts by cmoulder
Old Mar 19, 2013, 09:22 PM
zztinker is offline
zztinker's Avatar
Joined Feb 2007
Just got my 62 Osiris from UPS, wow, very nice and it included the wing covers. Can't wait to get started on it........
Old Mar 22, 2013, 11:50 AM
HouseOf4Doors is offline
Find More Posts by HouseOf4Doors
HouseOf4Doors's Avatar
United States, CA, Richmond
Joined Dec 2007
Props
I have been using APC 16 x 10e on 5s with Hacker A50-12s. Have been quite happy with it. Ordered a new prop, but what I got was APC 16 x 10 PATTERN prop. This baby is huge! 110 g vs 60 for the e-version.
Does anyone have experience with the APC Pattern props vs. the normal e-props? Wondering if it's worth it because of the weight and needing to get a spinner that will handle the beefy blades of this monster prop.
Bill
HouseOf4Doors is offline Find More Posts by HouseOf4Doors
Old Mar 23, 2013, 12:36 PM
aerobear is offline
Find More Posts by aerobear
United States, UT, Sandy
Joined Dec 2003
I'm guessing you will get better flight time with the E prop. It has a more efficient blade shape and its lighter weight means less battery power is used spinning up the prop.
aerobear is offline Find More Posts by aerobear
Old Mar 23, 2013, 01:34 PM
Gadget99 is offline
Find More Posts by Gadget99
Missouri
Joined May 2010
Bill
Looking at the APC site it looks like the pattern prop is for IC engines. I see similar differences when I compare my APC electric props v my APC props for IC engines. The prop for IC needs extra "meat" because of the vibration.
The extra weight may hinder throttle response and make your Hacker work harder.
Gadget
Gadget99 is offline Find More Posts by Gadget99
Old Mar 28, 2013, 10:23 AM
joshgluck's Avatar
Joined May 2012
Gadget
I ordered some XOARs 16x10 and 15x10 for my A50-12s setup on the ICE 100 lite running 5s 5000mah. Hope to have it up and running in a week now that I have my slick and edge built.
Gadget have you thought of a wood prop instead of the APC-E props?
bob - thanks for the offers, I will definitely take you up on it. I have joined NSRCA too.
Old Mar 28, 2013, 12:16 PM
cmoulder is offline
Pullin' G's Man
cmoulder's Avatar
Ossining, NY
Joined Dec 2005
The best prop I have tried thus far is the PT Models 16x10 (carbon fiber).
They are a bit hard to find, but available on a spotty basis at Esprit model here.
In fact, they're in stock now and I'm going to order another spare.
Bob
Old Mar 28, 2013, 05:56 PM
Gadget99 is offline
Missouri
Joined May 2010
Josh,
I just mounted a Xoar 16X10 electric prop. It weighs only 50 g. I gave up on the PT carbon fiber 16X10 because it has been "out of stock" for months. Two days after my Xoar props arrived I received the "in stock" notification of the PT props.
How much does the PT prop weigh? Is is better than a wood Xoar.
Old Mar 28, 2013, 06:53 PM
172AMD is offline
Find More Posts by 172AMD
Richmond B.C. Canada
Joined Aug 2006
Gadget99, here you go. 16x10 APC, Xoar, and PT.
To be honest, in flight I don't notice much difference between them. But, what do I know!
172AMD is offline Find More Posts by 172AMD
Whoops! Totaled pattern plane lucasavaitor Fuel Plane Talk 17 Dec 29, 2009 01:19 PM
Discussion Washout for sport/pattern plane? Taktas Modeling Science 22 Dec 24, 2009 06:31 AM
For Sale pattern plane john howard Aircraft - Fuel - Airplanes (FS/W) 4 Dec 11, 2009 06:48 AM
For Sale 3DHS Asprea Pattern Plane Andrew Jesky Aircraft - Electric - Airplanes (FS/W) 3 Feb 21, 2009 08:51 PM
Discussion Talon 62 pattern plane plans fomieforme Foamies (Scratchbuilt) 4 Feb 14, 2007 11:42 AM
