Old Oct 24, 2012, 11:00 AM
stuntflyr is offline
Find More Posts by stuntflyr
stuntflyr's Avatar
United States, AZ, Tucson
Joined Jun 2010
Nice job!
You'll find this model pretty easy to fly compared to sport ships and trainers.
Chris...
stuntflyr is offline Find More Posts by stuntflyr
Old Oct 28, 2012, 09:34 AM
Neko is offline
Find More Posts by Neko
United States, IL, Chicago
Joined Nov 2007
Well, that's good to hear. I just crashed a sport plane from losing orientation and will be pretty nervous when I maiden the Osiris, which is basically now done.
What is the recommended protocol for connecting the motor at these high currents? My motor distributor said to skip the bullet connectors and solder with motor and ESC wires directly. I've done that but then there are fewer options for feeding the ESC into the fuse unless you solder the wires with the ESC and motor already installed.
Neko is offline Find More Posts by Neko
Old Oct 28, 2012, 10:28 AM
stuntflyr's Avatar
Joined Jun 2010
Well,
If you're still having trouble with orientation I'd fix the Trainer and keep flying it. The Osiris is a model that needs a pilot that is secure in orientation, take offs and landings.
The Osiris is a "neutrally stable" design, this means it stays going where it is pointed.
Trainers are "positively stable" which is it tends to right itself. When in a bank it levels it's wings, in a dive it raises it's nose, etc.
My suggestion is to epoxy that trainer back together and and fly it every day that you can. Practice flying in a straight line parallel to the runway 100 yards out and reversing your direction by doing a vertical maneuver like a reverse half cuban eight or a half cuban eight and coming straight back over that same line you flew, over and over and over until you can nail that thing.
If that is too boring, spice it up with a loop in the center of one pass, roll the next. This will help in the discipline of orientation and teach you to use all controls including the rudder to keep the model going where you want it. Mostly!
I didn't solder my motor leads to my ESC, I used the bullets. They're very low resistance and like you've determined it makes mounting a lot easier. I use an arming plug mounted externally between the ESC and the battery, and deans connectors to connect the battery.
Do you have a Pattern pilot to help you? Even if you don't intend to compete, the discipline of handling the model precisely is worth a lot in general flying.
Chris...
Old Oct 28, 2012, 02:33 PM
Neko is offline
Joined Nov 2007
Will do, Chris. Thanks for the advice.
David
Old Oct 28, 2012, 02:58 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Also, once you do get ready.....don't forget that there's a 47" size that's much less investment...if you want to start with something less pricy after the trainer.
Bivens is offline Find More Posts by Bivens
Old Nov 01, 2012, 02:12 PM
Neko is offline
Joined Nov 2007
Two nice flights on my new Osiris 47" today! What a difference from the sport plane (Pulse). Hit the rudder and the plane doesn't dive and roll. I think I'll stay the 47 for a bit before moving to the 62.
I have the blue, and at times it was hard to see, but the sky was cloudy- white and I probably need to keep it closer in.
Hacker A30-14L
Hacker X70 (from the dear departed Pulse)
4S 3300
Old Nov 01, 2012, 03:00 PM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
That's true of almost all good aerobatic planes with a solid and easy-to-fly design...ALL 3dhs planes for sure have low or zero coupling...but pattern planes for sure.
Old Nov 02, 2012, 07:00 PM
HouseOf4Doors is offline
Find More Posts by HouseOf4Doors
HouseOf4Doors's Avatar
United States, CA, Richmond
Joined Dec 2007
CA Hinges
Plane's OK after an unplanned arrival but tore my rudder off. Any idea where to get CA hinges to reattach the rudder?
bp
HouseOf4Doors is offline Find More Posts by HouseOf4Doors
Old Nov 03, 2012, 08:56 AM
joshet89 is offline
Find More Posts by joshet89
MD1 HACK
joshet89's Avatar
United States, OH, Wadsworth
Joined Jan 2010
LHS usually has that sort of thing if not http://www3.towerhobbies.com/cgi-bin...P?I=LXK110&P=8
joshet89 is offline Find More Posts by joshet89
Old Nov 05, 2012, 02:41 PM
stuntflyr's Avatar
Joined Jun 2010
Hacker A30-14L
4S 3300
Wow Neko,
You're a go getter. Good plan with the 47", you'll notice red and white or red and yellow models are more visible. Best of luck.
Chris...
Old Nov 05, 2012, 09:10 PM
Neko is offline
Joined Nov 2007
Wow Neko,
Chris...
Thanks, Chris. I'm still in the manic phase. I've only been back in the sport for 6 weeks (had only a few weeks of flying 5 years ago). Trying to make up for lost time before the weather closes in, so I'm lurking on the forums, trying to build up the hangar and practicing every day on the simulator. Having a blast.
David
Old Nov 07, 2012, 01:32 AM
Husafreak is offline
Find More Posts by Husafreak
Husafreak's Avatar
United States, CA, Livermore
Anyone have numbers for the F3A braking for this Osiris? I am using a CC ESC but if anyone has a braking percentage they are happy with I could start there, thanks. Maiden tomorrow, should be a piece of cake.
Husafreak is offline Find More Posts by Husafreak
Old Nov 07, 2012, 01:36 AM
PatternFlyer is offline
Find More Posts by PatternFlyer
Frontenac, KS
Joined Jan 2003
about 15 ~ 30% depending on the weight and personal preference on Hacker outrunners
PatternFlyer is offline Find More Posts by PatternFlyer
Old Nov 07, 2012, 10:18 AM
Husafreak's Avatar
Thanks, its light so I'll start at 15.
Old Nov 08, 2012, 03:33 PM
R.A.P. is offline
Find More Posts by R.A.P.
Canard Driver
R.A.P.'s Avatar
san diego, ca.
Joined Nov 2002
3dHS Pattern plane
I hope some one who is knowledgeable can help me with this A/C ? I got this as an estate liquidation It's a gorgeous plane well prepared but missing the bottom pan!
I have spent quite a bit of time looking for the Manufacture in hopes of
ordering a replacement pan but no luck.
R.A.P. is offline Find More Posts by R.A.P.
Whoops! Totaled pattern plane lucasavaitor Fuel Plane Talk 17 Dec 29, 2009 01:19 PM
Discussion Washout for sport/pattern plane? Taktas Modeling Science 22 Dec 24, 2009 06:31 AM
For Sale pattern plane john howard Aircraft - Fuel - Airplanes (FS/W) 4 Dec 11, 2009 06:48 AM
For Sale 3DHS Asprea Pattern Plane Andrew Jesky Aircraft - Electric - Airplanes (FS/W) 3 Feb 21, 2009 08:51 PM
Discussion Talon 62 pattern plane plans fomieforme Foamies (Scratchbuilt) 4 Feb 14, 2007 11:42 AM
