Old Jan 11, 2010, 06:42 AM
areis81 is offline
Find More Posts by areis81
RC Wannabe!
areis81's Avatar
vercelli, ITALY
Joined Dec 2009
Work in Progress...
After crashing a few planes in the attempt of building my first FPV aircraft i decided to scratchbuild a suitable plane for FPV and stop going by intuition changing the project as i go on building!
so i decided to post here the progresses of my work, in this way i know that if i do some crap somebody would tell me!
it will be a foamy, i need a lot of room in the inside because i'm pretty messy with my electronics and stuff, plus i want to be able to easily move the CG moving the battery back and forward as i desire. i want it to be calm and capable of slow flying, but i need it to be controlled with 3ch: rudder, elevon and throttle, since my radio has 4ch+ a switch channel. so i will mount a tilt only camera in the front and use the switch, in future, for ballistic recovery (connected to programmable fail safe). over this issue i would have liked to make it tractor prop in order not to take the chance to get the chute in to the prop but i love pushers (used to flying wing!) so i will study some trick about it!
i will put the servos in the back close to the tail in order not to need any mechanical extension, and i will let the RX antenna out of the tip of a wing, and put the VTx at the tip of the other wing. since it's a 1.6m wingspan i think it will be fine.
i'm very concerned about plane lacalizing in case of crash but i'll think about it later, since for now i got a cheap ebay VTx and RX so i won't get too far (cheap 800mw 1.2g, will make a patch antenna for RX and extend Tx antenna at full wavelength, 25cm)
so here i am, starting planning it! i saw a pic in some thread once and i liked so i'm scratching it really similar, but i don't remember the name and can't find the post, if someone recognize it please tell me the name!
i'll post progresses as i go on!
p.s.: i called it GOTCHA!
areis81 is offline Find More Posts by areis81
Old Jan 11, 2010, 06:59 AM
areis81 is offline
RC Wannabe!
areis81's Avatar
vercelli, ITALY
Joined Dec 2009
an image just to check it without unzipping
Old Jan 11, 2010, 07:36 AM
areis81 is offline
RC Wannabe!
areis81's Avatar
vercelli, ITALY
Joined Dec 2009
one more
Old Jan 11, 2010, 08:35 AM
areis81 is offline
RC Wannabe!
areis81's Avatar
vercelli, ITALY
Joined Dec 2009
and with the top opened
Discussion mSR TX Setups, Tweaks, Mods Tips, and Upgrades (a work in progress) Flying-Monkey Micro Helis 1143 Feb 26, 2014 03:40 AM
Discussion Parkzone Micro Mustang TX Setups, Tweaks, Mods Tips, and Upgrades (work in progress) Flying-Monkey Micro Ready-to-Fly 417 Mar 25, 2013 09:28 PM
Build Log LRF Comp. Work in progress. gtrScotty Scratchbuilt Indoor and Micro Models 13 Nov 16, 2009 07:14 AM
RBC Beaufighter (work in progress!, long progress) Stuart Warne Scale Kit/Scratch Built 10 Apr 13, 2003 09:33 AM
