Old Jan 15, 2010, 11:49 AM
DJ Campbell is offline
Find More Posts by DJ Campbell
Joined Sep 2003
Originally Posted by Chinewalker View Post
Thinking out loud, and having Googled around a bit on building RC outboard hydros, I am now wondering if I should be building this in wood over foam construction? I really don't have a whole lot of time or money into it so far, so it wouldn't be hard to backtrack and start from scratch. Coming from a 1:1 boating background, my first thought was to build it plank over frame like a real boat, but now I'm having second thoughts.... Any input?
Thanks!
- Scott
Scott, I've built both ways, and I prefer wood over a frame-just my 2c.
DJ Campbell is offline Find More Posts by DJ Campbell
Old Jan 18, 2010, 08:47 AM
Chinewalker is offline
Find More Posts by Chinewalker
Chinewalker's Avatar
1000 Islands, NY
Joined Dec 2009
Framing Done!
Didn't do a whole lot to the hydro this weekend, but I did finish off the skeleton for the most part with the last of the battens in. Will probably have to back-burner this for a little while to work on a few other non-model related projects...
Chinewalker is offline Find More Posts by Chinewalker
Old Feb 22, 2010, 12:03 PM
1000 Islands, NY
Joined Dec 2009
Getting a little work done again after taking a few weeks off from this project. Got the chines glued in place last night...
Old Dec 06, 2010, 02:15 PM
1000 Islands, NY
Joined Dec 2009
I've stretched my summer out as long as I could. Time to hunker down and get back to the basement. Looking forward to finishing off this hydro and I have several other projects in the works. I haven't done much of anything on the building side since early last Spring and am anxious to make some sawdust!
I'm now thinking I will get one of the ProBoat outboards for this boat and go brushless. At 28 inches, I think this hull will be too big to do much with the Graupner 650 on it. 28-inches is closer in size to the Stilletto that the PB outboard runs on. The Graupner works okay on the 24-inch Bud Light tunnel, but it isn't a speed demon. The PB would give me a lot more flexibility for parts, motor selection, etc.
Old Dec 09, 2010, 12:03 AM
Rusty Old Fart is offline
Find More Posts by Rusty Old Fart
Zombie Apocalypse
Rusty Old Fart's Avatar
Newcastle, Australia
Joined Nov 2010
No mention of running gear just yet ?
Rusty Old Fart is offline Find More Posts by Rusty Old Fart
Old Dec 09, 2010, 01:10 PM
1000 Islands, NY
Joined Dec 2009
I am going to get one of the Pro Boat outboards for it. Had originally thought I'd use the old-tech Graupner GTX 650, but having run up against its limitations this summer running it on my MRP Bud Light tunnel, I am thinking I'll get something a bit more current with more prop options. The Pro Boat outboard is beefy, made for brushless systems, and has a wider prop array to play with. I'll probably start more or less stock, with basically the same motor & ESC combo used in the Stiletto tunnel and go from there as the learning curve improves...
Old May 29, 2015, 07:03 AM
flyguy017 is offline
Find More Posts by flyguy017
Joined Nov 2006
Hi there, i sent you a PM Chinewalker. I know this is an old thread but curious for an update.
Would you or anybody else have some shovel nose kneeler plans that could be shared.
Thanks.
flyguy017 is offline Find More Posts by flyguy017
Build Log Hedlund Class B Outboard Hydroplane Chinewalker Scale Boats 35 Jan 20, 2014 10:59 PM
Sold Have a Mugen MBX6 KIT 4 Trade 4 1.9 Scale Truck rcdirtslinger Cars - Trucks and Parts (FS/W) 1 Jan 04, 2010 05:16 AM
Sold 1/4 scale Duncan Hutson Hanriot H.D.1 kit ryan_m Aircraft - Fuel - Airplanes (FS/W) 0 Dec 14, 2009 09:07 AM
Discussion 1/12th scale fiberglass t-plus hydro for FE. maverick pro Racing Boats - Electric 28 Nov 13, 2009 08:49 AM
For Sale DPI 1/4 Scale Seabold Tunnel Hull Brand New! With K&B 13.3cc outboard! FrankW Boats (FS/W) 6 Dec 06, 2008 08:50 PM
