Old Jan 11, 2010, 05:05 AM
Chinewalker is offline
Find More Posts by Chinewalker
Chinewalker's Avatar
1000 Islands, NY
Joined Dec 2009
Build Log
Outboard Kneeler Hydro - Hedlund 1/4 Scale
I have a build thread going in the scale boats section for my 1/8 scale version, but I figured this was a better spot for the 1/4 scale hydro. This is my first full R/C build. I will be running a Graupner GTX 650 on it to start with.
I started cutting this weekend, getting the main coaming girders cut and shaped, and then joining them with the transom and crossmembers. I've never built a model this large! This should be fun!
Chinewalker is offline Find More Posts by Chinewalker
Old Jan 11, 2010, 08:18 AM
1000 Islands, NY
Joined Dec 2009
Framing coming together...
I got all the main frames in last night...
Old Jan 11, 2010, 01:27 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Nice!
Kmot is offline Find More Posts by Kmot
Old Jan 11, 2010, 07:32 PM
MarcRacer18 is offline
Find More Posts by MarcRacer18
Studying Engineer
MarcRacer18's Avatar
United States, CA, Santa Barbara
Joined Jun 2009
Nice strart!
MarcRacer18 is offline Find More Posts by MarcRacer18
Old Jan 13, 2010, 11:33 AM
Capt.Crash is offline
Find More Posts by Capt.Crash
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
Ah...nice simple clean lines...maybe I should have done something like this.
Looks good so far.
Capt.Crash is offline Find More Posts by Capt.Crash
Old Jan 13, 2010, 03:15 PM
1000 Islands, NY
Joined Dec 2009
1:1 Boat
Awhile back someone asked me what the real boat looked like underway. I found a pic of my Dad driving it with my 1952 Mercury KG-7H Hurricane on it. This was the first motor I ran on the boat when I got it. It did about 45-48 mph with that motor. It wasn't a bad set-up but the boat really came alive when I put a 1980 Mercury 25SS on it and it would nudge 60mph. The boat really likes to fly and doesn't pack enough air under it to float it until it hits the mid 50s. It's kinda like riding an elevator - your gut gets that sinking feeling as the boat just lifts up about 6-inches off the water and just hangs.
Old Jan 14, 2010, 01:59 AM
Amp Abuser is online now
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
Where was the CG? Looks like it was back quite a bit base on the picture.
Amp Abuser is online now Find More Posts by Amp Abuser
Old Jan 14, 2010, 05:31 AM
1000 Islands, NY
Joined Dec 2009
The CG in an outboard hydro is considerably different than that of an inboard hydro. With the driver and motor the center is well back of the sponsons.
Old Jan 14, 2010, 12:24 PM
785boats is offline
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Looks good . Great subject for a model.
Are you going to fill the spaces between the bulkheads with foam before you put the skin on? Certainly makes for a stronger hull & it won't sink if you have a serious crash.
Cheers.
Paul.
785boats is offline Find More Posts by 785boats
Old Jan 14, 2010, 12:54 PM
1000 Islands, NY
Joined Dec 2009
Would I use a pour-in foam? I have some 8 lb. density 2-part left over from a 1:1 project.
Old Jan 14, 2010, 04:33 PM
mxz70017 is offline
Find More Posts by mxz70017
mxz70017's Avatar
Joined May 2006
chinewalker
I would not use a commercial grade 2 part foam.They make one for models.Its a low E ok.The stuff you use for a real boat or home.Will expand way to much per volume an will blow that frame apart.What most do an I would do on that balsa frame.Is use a closed cell Ridgid foam board. An cut an shape It. To fit between the bulkheads.Make sure It Is a closed cell foam!!!If not the open cell absorbes water an that's not good...
Hey also looking good...See you put In some cross members to stiffen It up.
mxz70017 is offline Find More Posts by mxz70017
Old Jan 14, 2010, 04:46 PM
1000 Islands, NY
Joined Dec 2009
Thanks! I have some closed cell foam board I can use....
Old Jan 15, 2010, 09:15 AM
1000 Islands, NY
Joined Dec 2009
Thinking out loud, and having Googled around a bit on building RC outboard hydros, I am now wondering if I should be building this in wood over foam construction? I really don't have a whole lot of time or money into it so far, so it wouldn't be hard to backtrack and start from scratch. Coming from a 1:1 boating background, my first thought was to build it plank over frame like a real boat, but now I'm having second thoughts.... Any input?
Thanks!
- Scott
Old Jan 15, 2010, 12:46 PM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
No need to change what you've done so far.
Just put the bottom & side skins on, as you were going to do. Then cut & fit the blocks of foam to each section & glue them in, leaving them a bit proud of the deck bulkheads & frames. Then carve & sand to shape. Then glue on the deck skin. That's the way I do it anyway.
All the best.
Paul.
Build Log Hedlund Class B Outboard Hydroplane Chinewalker Scale Boats 35 Jan 20, 2014 11:59 PM
Sold Have a Mugen MBX6 KIT 4 Trade 4 1.9 Scale Truck rcdirtslinger Cars - Trucks and Parts (FS/W) 1 Jan 04, 2010 06:16 AM
Sold 1/4 scale Duncan Hutson Hanriot H.D.1 kit ryan_m Aircraft - Fuel - Airplanes (FS/W) 0 Dec 14, 2009 10:07 AM
Discussion 1/12th scale fiberglass t-plus hydro for FE. maverick pro Racing Boats - Electric 28 Nov 13, 2009 09:49 AM
For Sale DPI 1/4 Scale Seabold Tunnel Hull Brand New! With K&B 13.3cc outboard! FrankW Boats (FS/W) 6 Dec 06, 2008 09:50 PM
