Old Feb 23, 2010, 11:41 PM
xplaneguy is online now
Find More Posts by xplaneguy
Clear Skies & Contrails
xplaneguy's Avatar
Edwards AFB, CA
Joined May 2009
Airframe Only
Just found the Airframe Only" kit available now at Banana Hobby:
http://www.bananahobby.com/2015.html
Tony
xplaneguy is online now Find More Posts by xplaneguy
Latest blog entry: Freewing / Sebart 90mm F-104
Old Feb 24, 2010, 12:25 AM
xplaneguy's Avatar
Edwards AFB, CA
Joined May 2009
Video
Here's a video I found on You Tube of some guy flying his A380:
A380 Maiden Flight (3 min 33 sec)
Tony
Old Feb 24, 2010, 12:38 AM
xplaneguy's Avatar
Edwards AFB, CA
Joined May 2009
Another video:
A380 Airbus RC Jet.mov (3 min 1 sec)
Old Feb 24, 2010, 11:57 AM
RCP is offline
RCP
Find More Posts by RCP
RCP
RC Product Buyer
US
Joined Jun 2009
Both of the video's above from valleyjets.com are mine. I fly with a bunch of other guys who own airliners and fly at the Valley Flyers Club in the San Fernando Valley, California.
One of the guys has a Eflite 777 with an AWAC disc mounted to the top of the fuselage. The AWAC disc spins 360 degrees and has two cameras mounted within the disc. One camera is for video replay and the other is live time that sends video back to a laptop computer back in the pits. Both cameras have functional servo's that allow pan and tilt from a separate radio. We will have some new video posted up from the AWAC camera, shortly.
RCP is offline Find More Posts by RCP
Old Feb 24, 2010, 01:39 PM
xplaneguy's Avatar
Edwards AFB, CA
Joined May 2009
Very cool! I'm looking forward to more videos.
Tony
Old Feb 25, 2010, 01:56 AM
Lithonion is offline
Find More Posts by Lithonion
Have you seen my nut?
Lithonion's Avatar
Omaha, Nebraska
Joined Mar 2006
RCP are you flying yours with the supplied electronics?? I am tempted to get this plane. Also it looks like in one video it took alot to rotate, and in the second it was airborn it what to me looked like about 200 feet.
Airframe only is nice, but when you price out the RxR plane its not a bad price if the gear is ok. I usually try and stay clear of RxR planes and just get airframes but this one could get spendy with the equipment I like to use. ...lol
Lithonion is offline Find More Posts by Lithonion
Old Feb 25, 2010, 09:07 AM
RCP is offline
RCP
RCP
RC Product Buyer
US
Joined Jun 2009
Yes, I have the receiver ready kit. I have not had any problems with the electronics other than one motor shaft that snapped in flight. I heard it go while in flight, but really couldn't notice a difference in flight characteristics. The other 3 motors kept the plane flying fine. I replaced the one motor with a Kyosho brushless motor from their F-16.
I made one change to my plane from the start. I added a Castle external bec and disconnected all the receiver power wires from the 4 esc's. I just wasn't sure about the bec's from the plane and had no information from the manufacturer on them, so I added the external bec just as a added safety feature.
You can turn the plane quicker than the video, if needed. I like to fly somewhat scale, so I usually take the plane up high and wide when turning. I didn't wire the plane with elevon mixing, like the instructions show, but only use the ailerons to turn the plane.
I plan on adding some flaps to try and slow the plane down a little on landings to try and get a more scale like flight. You can also add a rudder to gain even more flight control.
Old Feb 25, 2010, 09:27 AM
RCP is offline
RCP
RCP
RC Product Buyer
US
Joined Jun 2009
Deleted post.
Old Feb 25, 2010, 09:38 AM
Lithonion's Avatar
Omaha, Nebraska
Joined Mar 2006
Thanks for the info. Your right, I wouldn't trust 4 ESC's all with the BEC wire intact either. Great info and if I get this plane I will do the same. You probably saved yourself potential problems. Where I fly we have a short strip, finally found out its 275 feet so I will be rotating as soon as I can.
Ok, I had to edit. I was bad and I just ordered one from BH PnP.
I know BH has a bad BBB rating and tons of complaints but I have never had any issues and even had a plane busted in shipping and Pete took care of me ASAP.
I have a couple BEC's still unopened so one will be going in this bird. Great heads up
Old Feb 25, 2010, 02:38 PM
mike93 is offline
Find More Posts by mike93
Santa Barbara/Roseville, California
Joined Dec 2001
Riddle me this. (may have been addressed already) could one use a similar motor/esc/battery setup as the Eflight 777? And have two dummy engines for the sake of $$$$ and complexity of battery capacity and malfunctions? Money is my biggest motivator when it comes to my rc (toy) fund on paypal.
Thanks for your help,
Mike.
p.s. How do you compare it overall to the Eflight Super Airliner. They are now both close in price for the airframe.
mike93 is offline Find More Posts by mike93
Old Feb 25, 2010, 05:18 PM
RCP is offline
RCP
RCP
RC Product Buyer
US
Joined Jun 2009
Mike.
Yes, I guess you could do it with two 70mm motors and have two dummy fan housings. If your comparing the two airframe kits, I would say the Airbus is levels ahead of the 777 kit. The foam is better quality, it is sprayed with a coating so it wipes down easy, the quality of the landing gear is much better and the plane just looks more impressive with four motors housings.
Old Feb 28, 2010, 12:24 PM
boom is offline
Find More Posts by boom
NiCd + Mabuchi 550 was da bomb
NY USA
Joined Apr 1999
Can someone kindly measure the stock motors and see if the following motor would be a good alternative?
http://hobbyking.com/hobbyking/store...dproduct=10930
boom is offline Find More Posts by boom
Old Feb 28, 2010, 10:03 PM
Lithonion's Avatar
Omaha, Nebraska
Joined Mar 2006
Did some research for ya boom and found this little tidbit. This is a quote from a post I found on hobbykings thread on this plane.
The A380 is powered by 4x 6-bladed 55mm fans, each running their own 2826 Brushless outrunner (3200KV) and 25A ESC. I have now measured and compared these EDF's to the GWS 55 EDF units and they are the same, except the inlet lip has been removed.
So, whatever fits in the GWS fans, will fit in these as they probably are GWS fans.
Old Mar 01, 2010, 11:03 PM
Lithonion's Avatar
Omaha, Nebraska
Joined Mar 2006
My A380 has been shipped. Now I just have to not freak and hide in the bushes waiting for the UPS truck.
Old Mar 02, 2010, 07:50 PM
klenker is offline
Find More Posts by klenker
Joined Jul 2003
[snip]
We just got ours from PW-RC. Great service, it was here in 4 days!
Can you confirm that you set your's up with conventional controls, i.e., elevators just as elevators and ailerons just as ailerons? Why do you suppose that they recommend that you do it otherwise?
I'm thinking of adding a working rudder... oh, and lots and lots of lights...
Bob
klenker is offline Find More Posts by klenker
Discussion A380 Airbus _Sergey_ Foamy EDFs 8 Jan 07, 2010 07:19 PM
Discussion My A380 Airbus with On Board camera and (3) 777's RCP Foamy EDFs 16 Jan 07, 2010 06:44 AM
Video Airbus A380 maiden flight _Sergey_ Electric Plane Talk 31 Jan 01, 2010 05:13 PM
Discussion Hobbyking Airbus A380 KIT jaskel Foamies (Kits) 10 Dec 05, 2009 05:16 AM
Question A380 Airbus Mixing question RCP Electric Ducted Fan Jet Talk 10 Nov 26, 2009 01:41 PM
