This thread is privately moderated by jodini, who may elect to delete unwanted replies.
Old Jan 10, 2010, 08:15 PM
jodini is offline
Find More Posts by jodini
Trader Rating: 30
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
Trader Rating: 30
Off Site
Magnum xls 61a rc airplane engine nib
http://cgi.ebay.com/ws/eBayISAPI.dll...STRK:MESELX:IT
This is the .61 cu in (9.9cc) 2-Stroke XLS .61A
Aircraft Engine from Magnum Engines.
FEATURES: ABC cylinder construction, "A"luminum piston with a "B"rass liner
that is "C"hrome plated
Dual ball bearing-supported crankshaft
Dual needle valve carburetor with remote High Speed Needle Valve
Dual bushing-supported connecting rod
Three year limited warranty
INCLUDES: .61 cu in (9.9cc) 2-Stroke XLS .61A Magnum engine w/ high flow
muffler, carb with remote needle assembly, and instruction manual
REQUIRES: Glow Fuel: break-in, 15% nitro with at least 18% lubricant content
after break-in, 15 - 30% nitro with at least 18% lubricant content
Glow Plug: Hot heat range plug designed for Two-Stroke engines
Propeller: 11x7 for break-in,
after break in, 11x8, 12x7, 12x6, 13x4
Misc Items: Plug wrench, starter and field equipment
SPECS: Displacement: .607 cu in (9.94cc)
Bore: 24mm
Stroke: 22mm
Practical RPM: 2,000 - 16,000rpm
Weight with Muffler: 22.5oz (638g)
Distance Between Mounting Holes Same Side: 1.02" (26mm)
Distance Between Mounting Holes Opposite Side: 2" (51mm)
Width at Mounting Tabs: 2.4" (61mm)
Height/bottom of Mounting Tabs/top of Cylinder Head: 2.4" (60.5mm)
Height/bottom of Crankcase/top of Cylinder Head: 4" (101mm)
Distance/Backplate to outer edge of Drive Washer: 3.7" (93.4mm)
Distance/Backplate to end of Crankcase: 3.1" (80mm)
jodini is offline Find More Posts by jodini
Help! Magnum .91 XLS FS muffler gemyrae Engines 5 Nov 30, 2009 10:59 AM
Sold Magnum XLS 15 (Near New) Sofa King Aircraft - Fuel - Engines and Accessories (FS/W) 4 Nov 29, 2009 03:42 PM
Sold Cox Giles 202 ARF & Magnum XLS .46A both NIB foxflier Aircraft - Fuel - Airplanes (FS/W) 1 Sep 28, 2009 05:11 PM
Found Looking for NIB Magnum XLS 46 bverwolf Aircraft - Fuel - Engines and Accessories (FS/W) 2 Sep 18, 2009 03:50 PM
Sold Magnum XLS .15 New in Box bverwolf Aircraft - Fuel - Engines and Accessories (FS/W) 2 Sep 15, 2009 09:38 PM
