Old Jan 10, 2010, 06:38 AM
arukum17 is offline
Find More Posts by arukum17
London, UK
Joined Aug 2005
Astro 05 brushed motor seizes, sizzles & frys
Running an Astro 05 with a 3.3 Astro Superbox
Max trottle drawing 17 amps as shown on wattmeter
Ran it for more than 5 min
I could see a small spark inside the motor every 2 or 3 min but did not think this was a problem
After 7 min of running it suddenly seized, there was a bit of smoke.
When I opened the motor the main spindle where the brushes make contact with the spindle this part had been totally chewed up. One of the black "ears" appeared to have its glue melted and had move position causing the carbon brushes to eat into the spindle. This motor had seized on a previous bench test at a lower throttle but I thought I had fixed the problem by regluing the ears. I am glad this happened on the bench rather than in the air.
Diagnoses - black ear glue mechanical failure
Result - one 05 Astro destroyed
I continue to be a fan of Astro brushed. But this was frustrating.
arukum17 is offline Find More Posts by arukum17
Old Jan 10, 2010, 06:56 AM
FlyingW is offline
Find More Posts by FlyingW
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
Sorry for the loss of the motor. The failure seems unusual; however in all fairness a five-minute bench run may have allowed the system to heat up too much.
There's probably a high temp epoxy that works best for the brush holders.
FlyingW is offline Find More Posts by FlyingW
Old Jan 10, 2010, 05:01 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Don't give up hope. I have full sets of spares. What is needed to get it back up?
Amature, fully wound? Casing? Brushes? Endbell?
Old Jan 11, 2010, 04:35 AM
arukum17 is offline
London, UK
Joined Aug 2005
I believe the part where the carbon bushing makes contact with the spinning shaft have been wrenched out from the shaft along with one of the black ears along with the part of the front golden housing. The only thing left intact is the black casing, the Astro superbox (3.69:1) including the 13T helical pinion, which was undamaged.
I have a replacement motor (never flown Astro 15 cobalt challenger) in my parts bin and will be using this after replacing the stock 2:1 gearbox with my 3.69 SuperBox. However what I need is to borrow a gear puller that will remove the existing factory fitted pinion from the Astro 15. The shaft size is 5/32 inch. The pinion is very tight though. I have tried with a standard GWS after heating the pinion with a blow torch and it still will not budge... the GWS puller jaws broke in the attempt!!
If there is anyone who can lend me / recommend a strong gear puller; or will pull this pinion gear out themselves (at my risk) please let me know. I am also in the process of contacting Kurt at New Creations in Texas to see if he has any ideas for a tight pinion gear.
Old Jan 11, 2010, 04:58 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Fairly sure I simply put a small spanner under the pinion and tapped one off with a drift..no that was the BIG gear, not the pinion..
I must have replaced a pinion tho. Hmm.
15 is an 05 with low KV armature. Needs 4s to wake up, really.
Old Jan 11, 2010, 08:22 AM
arukum17 is offline
London, UK
Joined Aug 2005
Thanks for pointing that out... I am "long" 3s, so i would be better of fixing or finding another Astro 05. You'll meet me in the classifieds.
Old Jan 17, 2010, 02:26 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Cripes, that commutator had exploded..
you have mail..its repaired..
Discussion Question about an Astro Cobalt 15 brushed motor viva_peru Power Systems 20 Dec 16, 2009 12:05 PM
Sold Astro flite cobalt 05 airplane motor magkat Aircraft - Electric - Power Systems (FS/W) 1 Dec 11, 2009 03:59 AM
Sold **SOLD***Astro 05 FAI racing motor USED FredM Aircraft - Electric - Power Systems (FS/W) 1 Dec 06, 2009 10:57 AM
Help! Astro 05 cobalt seizes up... arukum17 Beginner Training Area (Aircraft-Electric) 0 Apr 26, 2009 05:26 PM
05 astro brushed motor magnet came loose dave morris Electric Plane Talk 1 Jul 24, 2001 10:31 PM
