This thread is privately moderated by all4smallrc, who may elect to delete unwanted replies.
Old Feb 19, 2013, 10:16 PM
all4smallrc is offline
Find More Posts by all4smallrc
Founder of the EDF20 club!
all4smallrc's Avatar
Minnesota
Joined Apr 2008
If you are doing two fans, 40mm would probably do it. I'm no expert on those fan sizes, but from thrust data I've seen, two 40s should give you close to or around a 1:1 thrust to weight ratio.
all4smallrc is offline Find More Posts by all4smallrc
Old Jul 03, 2013, 03:30 PM
JimEdmiston is offline
Find More Posts by JimEdmiston
MigLovin'
Sanford, FL
Joined Dec 2008
Many of your links in early posts are dead now. Methinks it's time for an update!
JimEdmiston is offline Find More Posts by JimEdmiston
Old Jul 04, 2013, 01:33 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
I didn't know you were on the forum. I do need to update everything though. My laptop bugged out on me though so no updates till I get back home at the end of the summer.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jul 04, 2013, 07:34 PM
Minnesota
Joined Apr 2008
Yeah. Unfortunately, some of those sites don't exist any more. Sad to say, I think GBD is gone for good, meaning their custom fans will no longer be available. I updated my first post with new links. I couldn't find new links for some things, but the good news is, there are some new items added to the list now, including the 27mm and 35mm AEO fans and the eight blade rotors for the 30mm AEO fans.
Old Jul 05, 2013, 07:53 PM
Joined Nov 2007
GBD went out of business shortly after we created this thread. I left the links there in hope that the link error was only a temporary issue. I was actually communicating with the owner (forgot his name) at the time. He stated that he was going through a few of life's challenges.
Old Jul 11, 2013, 07:59 PM
MigLovin'
Sanford, FL
Joined Dec 2008
Yeah buddy I'm on here, I've been trying to follow your projects since I haven't been able to make it to any of the recent Riddle Fly-Ins. Pretty cool stuff as usual. I'm just now delving into my first 30mm EDF after seeing some promising results from NitroCharged, specifically 200 grams at 10A on 3S. I frequently do custom winds on motors for my micro prop jets, so doing the necessary re-winding on the motor used is well within reach. The only issue I'm having is how to properly cut the fan blades to precisely the right length.
Old Jul 11, 2013, 08:03 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Did you see my foto tutorial on how I trimmed my blades?
NitroCharged is offline Find More Posts by NitroCharged
Old Jul 13, 2013, 03:12 PM
MigLovin'
Sanford, FL
Joined Dec 2008
I have not. In the event that it is easy to find, I'll see it in threads started by you. If not, please post a link. Thanks
Old Jul 13, 2013, 07:08 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
http://www.rcgroups.com/forums/showt...h#post17234650
Old Nov 01, 2014, 04:31 AM
LUcaus87 is offline
Find More Posts by LUcaus87
Joined Sep 2014
looks very bigger
Originally Posted by boredom.is.me View Post
Micro EDF Power Setups
Sub-30mm Class Power Setups A WHOLE NEW EDF CLASS
The NDF22 Series is my personal EDF unit made with the input of many
RCGers including MegaTesla, Freddie B, mcross, and all4smallrc. Check
out the EDF20 experiment club!!!!!
NDF22/10 G2
Motor: TGY 1015 11500kv BL Inrunner http://www.hobbyking.com/hobbycity/s..._Motor_11500kv
ESC requirement: 4 amp
Battery: 2-3 cell capable of 2.5-* amp discharge
Thrust: 30-* grams
Watts: 15.54-*W
Weight: 6.5 grams
Rotor: GWS EDF30
NDF22/2G G2 *Still under Testing*
Motor: 2 gram Outrunner
ESC requirement:
Battery:
Thrust:
Watts:
Weight:
Rotor: GWS EDF30
NDF25/10
Battery: 2 cell capable of 4 amp discharge
Thrust: 40 grams
Watts: 21.6W
Weight: 7 grams
Rotor: GWS EDF30 3 blade
NDF25/12
Motor: TGY 1220 10300kv
ESC requirement: 5 amp
Thrust: 43 grams
Watts: 26.25W
Weight: 10.9 grams
Rotor: GWS EDF40
Airhogs E-Chargers Single Fan Setup
Motor: stock
ESC requirement: 2 amp most likely built into your receiver.
Battery: 2 cell capable of * amp discharge
Best Receiver Choice: Plantraco Micro9 Servo Receiver http://www.microflight.com/Online-Ca...Servo-Rx-w-ESC
Thrust:
Watts:
Grams per Watt:
RPM:
Weight:
Airhogs E-Chargers Dual Fan Setup
Motor: stock
ESC requirement:
Thrust:
Watts:
Grams per Watt:
RPM:
Weight:
Airhogs Jetscream/Foxfire Single Fan Setup
Motor: stock
Battery: 1 cell capable of 1.2 amp discharge
Thrust: 11 grams
Watts:
Grams per Watt:
RPM:
Weight: 4.42 grams
Airhogs Jetscream/Foxfire Dual Fan Setup
Motor: stock
ESC: 3 amp
Battery: 1 cell capable of 2.5 amp discharge
Thrust: 22 grams
Watts:
Grams per Watt:
RPM:
Weight: 8.84 grams
GWS EDF30 3-Blade Setup
ESC requirement: TGY 6amp Plush ESC http://www.hobbyking.com/hobbycity/s...eed_Controller
Battery: 2 cell capable of 5 amp discharge
Thrust: 55 grams
Watts:
Grams per Watt:
RPM:
Weight: approx. 10 grams
GWS EDF30 2-Blade Setup
ESC requirement: 2 cell capable of 5 amp discharge
Thrust: 46 grams
Watts: 24.2
Grams per Watt: 1.9
RPM: 65000
AEO EDF30 Setup
Motor: 10200kv (supplied)
ESC requirement: 10 amp
Battery: 2 cell capable of 9.5 amp discharge
Thrust:
Watts:
Grams per Watt:
RPM:
Weight: 9.5 grams
KP32 Setup
Motor: Feigao 7500kv
Battery: 2-3 cell capable of 6.5 amp discharge
Thrust: 70-145 grams
Watts:
Grams per Watt:
RPM:
Weight: 28 grams
GBD 30mm Single Fan Setup
Motor: Built-In
ESC requirement: 6 amp
Battery: 2-3 cell capable of 4.5 amp discharge
Thrust: *-68 grams
Watts:
Grams per Watt:
RPM:
Weight: 9 grams
GBD 30mm Dual Fan Setup
Motor: Built-In
ESC requirement: High Quality 10 amp, CC Phoenix ESC http://www.gbdmodelaircraft.com/desc...php?iddesc=232
Battery: 2-3 cell capable of 9 amp discharge
Thrust: *-136 grams
Watts:
Grams per Watt:
RPM:
Weight: 18 grams
40mm Class Power Setups
GWS EDF40 Brushed Setup
Motor: stock CN12-RLC
ESC requirement: 5 amp brushed
Thrust: 71 grams
Watts:
Grams per Watt:
RPM:
Weight: 27 grams
GWS EDF40H Highly Efficient Brushed Setup
Motor: stock CN12-RXC
ESC requirement: 3 amp brushed
Battery: 3 cell capable of 2.5 amp discharge
Thrust: 64 grams
Watts: 22 (10.7v/2.05A)
Grams per Watt: 2.91
RPM: 31030
Weight: 27 grams
GWS EDF40 Setup, Top of the Line Performance (hard to find)
Motor: Medusa 5300kv
ESC requirement: High Quality 6 amp with 7.5 amp or more peak
Battery: 3 cell capable of 7.5 amp discharge
Thrust: 168g
Watts: 76
Grams per Watt: 2.21
RPM: 48500
Weight:
GWS EDF40 New Brushless Stock Setup
Motor: GWS 2018 5800kv
ESC requirement: 30 amp
Battery: 3 cell capable of 30 amp discharge
Thrust: * grams
Watts:
Grams per Watt:
RPM:
Weight: 52 grams
*The motor of this unit can not handle 4s and the 320g thrust was propaganda.*
GWS EDF40 Setup, Good Performance
Motor: Feigao 5800kv http://www.bphobbies.com/view.asp?id...05&pid=U390531
Battery: 2 cell capable of 4.5 amp discharge
Thrust:
Watts:
Grams per Watt:
RPM:
Weight:
Motor: Feigao 5830kv
Thrust: 76
Watts: 27W (6.8v/3.95A)
Grams per Watt: 2.82
RPM: 34680
Weight:
Motor: Feigao 5300kv
Battery: 3 cell capable of 6 amp discharge
Thrust: 122
Watts: 57W (10.8v/5.30A)
Grams per Watt: 2.14
RPM: 45600
Weight:
Motor: AON 5000kv
Thrust: 91
Watts: 44W (10.6v/4.10A)
Grams per Watt: 2.07
RPM: 38200
Weight:
Motor: Feigao 4100kv
Thrust: 88
Watts: 35W (10.6v/3.25A)
Grams per Watt: 2.51
RPM:37650
Weight:
Motor: Medusa 4000kv
Thrust: 110
Watts: 40W (10.6v/3.75A)
Grams per Watt: 2.75
RPM:40680
Weight:
GWS EDF40 Setup
Motor: Proton 4000kv
Thrust: 112g
Watts: 38W (10.9v/3.50A)
Grams per Watt: 2.95
RPM: 40060
Weight: motor = 23 grams
AEO EDF40 Setup
Motor: 8600kv (supplied)
ESC requirement: 18amp
Battery: 2 cell capable of 18 amp discharge
Thrust:
Watts:
Grams per Watt:
RPM:
Weight:
GBD 40mm Setup
Motor: Built-In
Battery: 2-3 cell capable of 10 amp discharge
Thrust: *-180 grams
Watts:
Grams per Watt:
RPM:
Weight: 18 grams
30mm Class EDF Aircraft Part 2 of 2
LUcaus87 is offline Find More Posts by LUcaus87
Old Nov 01, 2014, 10:53 PM
Joined Nov 2007
Originally Posted by LUcaus87 View Post
looks very bigger
Thank you for the constructive input.
Old Nov 13, 2014, 10:41 AM
back2earth is offline
Find More Posts by back2earth
Joined Sep 2014
ARTR Models with seperate delivered motor and ESC.
I am looking for Tenshock ARTR Models with seperate delivered motor and ESC.
Originally Posted by all4smallrc View Post
It's a sticky! I'd like to thank and give credit to boredom.is.me for doing most of the work and SPEED-E-FLYER for helping it become a sticky!
I've started this thread so we will have a place where all the currently available 30mm to 40mm edf units, parts, and motors are. I have posted the ones I know of. If you know of others, please post links. I also want to give a special thanks to boredom.is.me for helping me with this thread.
30mm Class EDFs
GWS 30mm Case and Impeller
http://robotbirds.com/catalog/produc...oducts_id=1636
Case Only
http://www.hobbycity.com/hobbycity/s...idProduct=5131
http://www.bphobbies.com/view.asp?id...7&pid=NGWS7208
Impeller Only
http://www.hobbycity.com/hobbycity/s...idProduct=5130
http://www.bphobbies.com/view.asp?id...7&pid=NGWS7209
AEO 27mm
10000kv http://robotbirds.com/catalog/produc...oducts_id=6317
impeller only http://robotbirds.com/catalog/produc...oducts_id=6308
impeller and case http://robotbirds.com/catalog/produc...oducts_id=6303
AEO 30mm Fans with Kv
9000kv
http://www.hobbycity.com/hobbycity/s...idProduct=8686
10200kv
http://robotbirds.com/catalog/produc...oducts_id=6295
12750kv
http://www.bphobbies.com/view.asp?id...7&pid=D3875396
Replacement Rotor
six bladehttp://www.bphobbies.com/view.asp?id...7&pid=D3875397
eight blade http://robotbirds.com/catalog/produc...oducts_id=6309
Replacement Housing
http://www.bphobbies.com/view.asp?id...7&pid=D3875398
Replacement Rotor an Housing Combo
http://www.bphobbies.com/view.asp?id...7&pid=D3885405
AEO 35mm
10000kv http://robotbirds.com/catalog/produc...oducts_id=6297
impeller http://robotbirds.com/catalog/produc...oducts_id=6310
impeller and case http://robotbirds.com/catalog/produc...oducts_id=6305
40mm Class EDFs
AEO 40mm
8100kv
http://www.bphobbies.com/view.asp?id...3&pid=D3885406
8600kv
http://www.bphobbies.com/view.asp?id...3&pid=D3885407
Replacement Rotor
http://www.bphobbies.com/view.asp?id...3&pid=D3885409
http://www.allerc.com/product_info.p...oducts_id=1219
Replacement Housing
http://www.allerc.com/product_info.p...oducts_id=1218
http://www.bphobbies.com/view.asp?id...3&pid=D3885410
Replacement Rotor and Housing Combo
http://www.bphobbies.com/view.asp?id...3&pid=D3885408
GWS 40mm
Brushed units
For 2 cell lipo
http://www.bphobbies.com/view.asp?id...03&pid=T826482
For 3 cell lipo
http://www.bphobbies.com/view.asp?id...03&pid=T786626
Case only
http://www.bphobbies.com/view.asp?id...3&pid=NGWSV004
Impeller only
http://www.bphobbies.com/view.asp?id...3&pid=NGWSV005
Brushed motor options for 20-30mm edfs
6mm motors (great for scratchbuilt edf20s)
http://www.homefly.com/proddetail.asp?prod=m6-4%2E5 http://www.microflight.com/6mm-4-5-Ohm-Coreless-Motor
7mm motors
Blue SS http://www.bsdmicrorc.com/index.php?productID=621 http://www.microflight.com/Online-Ca...-nanoconnector
Walkera UFO #8 motors (VERY powerful!) http://www.chinesejade.com/walkera_ufo.htm
M20 motors
For single lipo cell: http://www.homefly.com/proddetail.asp?prod=bm-15
For two cell lipo: http://www.homefly.com/proddetail.asp?prod=bm-36
back2earth is offline Find More Posts by back2earth
Old Nov 14, 2014, 03:08 AM
gbd1 is offline
Find More Posts by gbd1
A10jockey
Joined Dec 2009
Micromodeldrome
Hi all,
I have recently resurfaced to the micro EDF scene, my old company GBD Models closed some years ago but I am pleased to say that I have now founded www.micromodeldrome.com
early days yet but having some success with Micro Models brushless and brushed set ups.
Hope to post some info on my set ups soon.
Here is a pic of my 1S Brushed F16 Weight = 24 g
gbd1 is offline Find More Posts by gbd1
Old Dec 04, 2014, 02:02 AM
straightup is offline
Find More Posts by straightup
Joined Sep 2004
motor fan setups for Guillows F16
Can I get some light and powerful motor/fan/battery/esc recommendations for this plane? It's a converted quillows static display. It currently has a GWS 40 with a feigao inrunner that requires 3 cells and a cc10 amp speed controller. I could stick with this setup but wondering if there's anything better (ie. lighter with about the same amount of thrust or same weight and more thrust). It's been a couple of years....The plane currently weighs 110grams without the battery. Lots of finishing left to do.
Thanks.
straightup is offline Find More Posts by straightup
Old Dec 07, 2014, 10:15 AM
jahel is offline
Find More Posts by jahel
United States, FL, Clearwater
Joined Jun 2011
Change the motor for a neu proton 7300kv
jahel is offline Find More Posts by jahel
Sold 2 Alfa fan units for 30 bucks shipped awayne Aircraft - Electric - Power Systems (FS/W) 7 Jan 24, 2010 10:03 AM
Data delete all4smallrc Micro EDF Jets and Power Systems 24 Jan 09, 2010 11:57 PM
For Sale EDF Brushless motors and EDF Units Dutkoski Aircraft - Electric - Power Systems (FS/W) 0 Mar 07, 2008 03:36 PM
Discussion Smallest EDF Units Available? BigG80 Foamy EDFs 8 Jan 31, 2008 02:45 AM
New Product 70mm and 90mm EDF units available for Brushless supi7 Electric Ducted Fan Jet Talk 18 Jun 14, 2006 07:21 PM
