| Thread Tools |
| This thread is privately moderated by all4smallrc, who may elect to delete unwanted replies. |
AEO 30mm Kv 10200
30mm Rotor and Housing 40mm Rotor and Housing I just made an order from AerialHobby, so lets see how long it takes to get it to Sweden. Magnus |
Micro EDF Power Setups
Sub-30mm Class Power Setups A WHOLE NEW EDF CLASS The NDF22 Series is my personal EDF unit made with the input of many RCGers including MegaTesla, Freddie B, mcross, and all4smallrc. Check out the EDF20 experiment club!!!!! NDF22/10 G2 Motor: TGY 1015 11500kv BL Inrunner http://www.hobbyking.com/hobbycity/s..._Motor_11500kv ESC requirement: 4 amp Battery: 2-3 cell capable of 2.5-* amp discharge Thrust: 30-* grams Watts: 15.54-*W Weight: 6.5 grams Rotor: GWS EDF30 NDF22/2G G2 *Still under Testing* Motor: 2 gram Outrunner ESC requirement: Battery: Thrust: Watts: Weight: Rotor: GWS EDF30 NDF25/10 Motor: TGY 1015 11500kv ESC requirement: 4 amp Battery: 2 cell capable of 4 amp discharge Thrust: 40 grams Watts: 21.6W Weight: 7 grams Rotor: GWS EDF30 3 blade NDF25/12 Motor: TGY 1220 10300kv ESC requirement: 5 amp Battery: 2 cell capable of 4 amp discharge Thrust: 43 grams Watts: 26.25W Weight: 10.9 grams Rotor: GWS EDF40 30mm Class Power Setups Airhogs E-Chargers Single Fan Setup Motor: stock ESC requirement: 2 amp most likely built into your receiver. Battery: 2 cell capable of * amp discharge Best Receiver Choice: Plantraco Micro9 Servo Receiver http://www.microflight.com/Online-Ca...Servo-Rx-w-ESC Thrust: Watts: Grams per Watt: RPM: Weight: Airhogs E-Chargers Dual Fan Setup Motor: stock ESC requirement: Battery: 2 cell capable of * amp discharge Thrust: Watts: Grams per Watt: RPM: Weight: Airhogs Jetscream/Foxfire Single Fan Setup Motor: stock ESC requirement: 2 amp most likely built into your receiver. Battery: 1 cell capable of 1.2 amp discharge Thrust: 11 grams Watts: Grams per Watt: RPM: Weight: 4.42 grams Airhogs Jetscream/Foxfire Dual Fan Setup Motor: stock ESC: 3 amp Battery: 1 cell capable of 2.5 amp discharge Thrust: 22 grams Watts: Grams per Watt: RPM: Weight: 8.84 grams GWS EDF30 3-Blade Setup Motor: TGY 1015 11500kv BL Inrunner http://www.hobbyking.com/hobbycity/s..._Motor_11500kv ESC requirement: TGY 6amp Plush ESC http://www.hobbyking.com/hobbycity/s...eed_Controller Battery: 2 cell capable of 5 amp discharge Thrust: 55 grams Watts: Grams per Watt: RPM: Weight: approx. 10 grams GWS EDF30 2-Blade Setup Motor: TGY 1015 11500kv BL Inrunner http://www.hobbyking.com/hobbycity/s..._Motor_11500kv ESC requirement: 2 cell capable of 5 amp discharge Battery: 2 cell capable of 5 amp discharge Thrust: 46 grams Watts: 24.2 Grams per Watt: 1.9 RPM: 65000 Weight: approx. 10 grams AEO EDF30 Setup Motor: 10200kv (supplied) ESC requirement: 10 amp Battery: 2 cell capable of 9.5 amp discharge Thrust: Watts: Grams per Watt: RPM: Weight: 9.5 grams KP32 Setup Motor: Feigao 7500kv ESC requirement: 10 amp Battery: 2-3 cell capable of 6.5 amp discharge Thrust: 70-145 grams Watts: Grams per Watt: RPM: Weight: 28 grams GBD 30mm Single Fan Setup Motor: Built-In ESC requirement: 6 amp Battery: 2-3 cell capable of 4.5 amp discharge Thrust: *-68 grams Watts: Grams per Watt: RPM: Weight: 9 grams GBD 30mm Dual Fan Setup Motor: Built-In ESC requirement: High Quality 10 amp, CC Phoenix ESC http://www.gbdmodelaircraft.com/desc...php?iddesc=232 Battery: 2-3 cell capable of 9 amp discharge Thrust: *-136 grams Watts: Grams per Watt: RPM: Weight: 18 grams 40mm Class Power Setups GWS EDF40 Brushed Setup Motor: stock CN12-RLC ESC requirement: 5 amp brushed Battery: 2 cell capable of 5 amp discharge Thrust: 71 grams Watts: Grams per Watt: RPM: Weight: 27 grams GWS EDF40H Highly Efficient Brushed Setup Motor: stock CN12-RXC ESC requirement: 3 amp brushed Battery: 3 cell capable of 2.5 amp discharge Thrust: 64 grams Watts: 22 (10.7v/2.05A) Grams per Watt: 2.91 RPM: 31030 Weight: 27 grams GWS EDF40 Setup, Top of the Line Performance (hard to find) Motor: Medusa 5300kv ESC requirement: High Quality 6 amp with 7.5 amp or more peak Battery: 3 cell capable of 7.5 amp discharge Thrust: 168g Watts: 76 Grams per Watt: 2.21 RPM: 48500 Weight: GWS EDF40 New Brushless Stock Setup Motor: GWS 2018 5800kv ESC requirement: 30 amp Battery: 3 cell capable of 30 amp discharge Thrust: * grams Watts: Grams per Watt: RPM: Weight: 52 grams *The motor of this unit can not handle 4s and the 320g thrust was propaganda.* GWS EDF40 Setup, Good Performance Motor: Feigao 5800kv http://www.bphobbies.com/view.asp?id...05&pid=U390531 ESC requirement: 6 amp Battery: 2 cell capable of 4.5 amp discharge Thrust: Watts: Grams per Watt: RPM: Weight: GWS EDF40 Setup, Good Performance Motor: Feigao 5830kv ESC requirement: 6 amp Battery: 2 cell capable of 4.5 amp discharge Thrust: 76 Watts: 27W (6.8v/3.95A) Grams per Watt: 2.82 RPM: 34680 Weight: GWS EDF40 Setup, Good Performance Motor: Feigao 5300kv ESC requirement: 6 amp Battery: 3 cell capable of 6 amp discharge Thrust: 122 Watts: 57W (10.8v/5.30A) Grams per Watt: 2.14 RPM: 45600 Weight: GWS EDF40 Setup, Good Performance Motor: AON 5000kv ESC requirement: 6 amp Battery: 3 cell capable of 6 amp discharge Thrust: 91 Watts: 44W (10.6v/4.10A) Grams per Watt: 2.07 RPM: 38200 Weight: GWS EDF40 Setup, Good Performance Motor: Feigao 4100kv ESC requirement: 6 amp Battery: 3 cell capable of 6 amp discharge Thrust: 88 Watts: 35W (10.6v/3.25A) Grams per Watt: 2.51 RPM:37650 Weight: GWS EDF40 Setup, Good Performance Motor: Medusa 4000kv ESC requirement: 6 amp Battery: 3 cell capable of 6 amp discharge Thrust: 110 Watts: 40W (10.6v/3.75A) Grams per Watt: 2.75 RPM:40680 Weight: GWS EDF40 Setup Motor: Proton 4000kv ESC requirement: 6 amp Battery: 3 cell capable of 6 amp discharge Thrust: 112g Watts: 38W (10.9v/3.50A) Grams per Watt: 2.95 RPM: 40060 Weight: motor = 23 grams AEO EDF40 Setup Motor: 8600kv (supplied) ESC requirement: 18amp Battery: 2 cell capable of 18 amp discharge Thrust: Watts: Grams per Watt: RPM: Weight: GBD 40mm Setup Motor: Built-In ESC requirement: High Quality 10 amp, CC Phoenix ESC http://www.gbdmodelaircraft.com/desc...php?iddesc=232 Battery: 2-3 cell capable of 10 amp discharge Thrust: *-180 grams Watts: Grams per Watt: RPM: Weight: 18 grams 30mm Class EDF Aircraft Part 2 of 2
Available Micro EDF Kits, ARFs, and PNPs
I'll be back... EDF30 Kits GBD Model Aircraft Kits A10 (EPP) for Twin EDF30 A10 EDF30/Pusher Eurofighter EDF30/Pusher F86 Sabre for EDF30 Micro F9F for EDF30 SU27 for Twin EDF30 EDF40 Kits GBD Model Aircraft Kits Fun Jet 40 North American F86 Sabre Kit only Fun Jet 40 F86 Sabre Fun Jet 40 BAC Lightning Kit Only Fun Jet 40 BAC Lightning Fun Jet 40 BAe Hawk Kit Only Fun Jet 40 Hawk Fun JetME163 Comet A10 (EPP) Park Fly/Indoor for Twin EDF BAC TSR2 for Twin EDF Gloster Meteor (EPP) for Twin EDF Sizzler EDF 40 Kit Only Sizzler C/W EDF 40 pmpjohn KISS Series Kits Homepage: http://www.drjohnslaser.com/ F15 Mini Twin EDF and 40/50mm A7 "Pirate II" 2DogRC and Axon Axon Micro 14" F4 Phantom EDF Jet AEO RC AEO Micro Mig29 with Single 40mm EDF TechOne Models (a.k.a. Thieves) Mini F-22 Jet EPO Kit with EDF and brushless motor 1 2 Mini F4 Jet EPP Kit with EDF and brushless motor 1 |
Kevon I guess this thread is officially open for questions. |
| Thread Tools | |
| Sold 2 Alfa fan units for 30 bucks shipped | awayne | Aircraft - Electric - Power Systems (FS/W) | 7 | Jan 24, 2010 10:03 AM |
| Data delete | all4smallrc | Micro EDF Jets and Power Systems | 24 | Jan 09, 2010 11:57 PM |
| For Sale EDF Brushless motors and EDF Units | Dutkoski | Aircraft - Electric - Power Systems (FS/W) | 0 | Mar 07, 2008 03:36 PM |
| Discussion Smallest EDF Units Available? | BigG80 | Foamy EDFs | 8 | Jan 31, 2008 02:45 AM |
| New Product 70mm and 90mm EDF units available for Brushless | supi7 | Electric Ducted Fan Jet Talk | 18 | Jun 14, 2006 07:21 PM |
