Old Jan 09, 2010, 08:07 AM
vitas is online now
Find More Posts by vitas
Munich
Joined Apr 2004
New Product
F3 Timer for Android phones
Hi all,
I have made a F3K timer program for phones with Android OS.
I would like to find somebody who can test it, any ideas are welcome.
If you are interested, please send PM with results and phone model name.
the program your can download here:
http://www.f3j.net/download/f3ktimer.apk
Kind Regards, Vitali
vitas is online now Find More Posts by vitas
Old Jan 09, 2010, 09:31 AM
MattN is offline
Find More Posts by MattN
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
I just did a little research about .apk files - to install them you have to install the Android SDK on you computer
I'm personally not going to do that just to try out an early version of timing app.
Vitali - why don't you put the app on the Android Marketplace? I'd wager that you will get a lot more feedback...
-matt
MattN is offline Find More Posts by MattN
Old Jan 09, 2010, 11:49 AM
vitas is online now
Munich
Joined Apr 2004
I have put it in Android Marketplace...
name of program is F3K Timer
Regards, Vitali
Old Jan 09, 2010, 03:17 PM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
I found the flight /land button...
Works good!
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old Jan 09, 2010, 04:32 PM
vitas is online now
Munich
Joined Apr 2004
Works good!
Hi, you can push central "enter" button to take on/off..just found some phones have this button inside case beside keyboard.
Old Jan 11, 2010, 07:11 AM
vitas is online now
Munich
Joined Apr 2004
Hi, I have put a new version at Android Market
visit F3K timer site and drop some comment if you want
http://www.f3k.biz
Thank you!
Old Jan 14, 2010, 11:42 PM
guantamanera is offline
Find More Posts by guantamanera
I want to bark at the moon
guantamanera's Avatar
2 weeks in SoCal 2 weeks in WA
Joined Mar 2009
-matt
You don't need to install the SDK. Go to the market place download astro file manager to your phone. Connect the phone to the computer put the .apk in your SD card then open Astro find the file tap it and it will install. That is pirate software try before you buy.
guantamanera is offline Find More Posts by guantamanera
Old Jan 16, 2010, 06:02 AM
turn, turn, turn.
Joined Oct 2005
On the ladder task, the only way to re-set it after starting, is to kill the app., then re-start from 30 seconds.
Is there another way to start over?
Old Jan 16, 2010, 10:30 AM
vitas is online now
Munich
Joined Apr 2004
Hi, this a bug I will fix it today.
Thank you.
Old Jan 18, 2010, 05:09 AM
turn, turn, turn.
Joined Oct 2005
Nice fix.
Any way to stop the "back" key on the bottom of the Android phone from losing all the data?....or is this a function of the Android itself?
I can use the phone and get on-line without disturbing a timing sesion already in progress.....but, when I accidently hit the "back" button on the Android, the F3K file has to be re-opened, and the previous timing session is lost.
Old Jan 18, 2010, 08:58 AM
vitas is online now
Munich
Joined Apr 2004
I will fix it, I will try to disable another system buttons during flight session like for help button I did.
Thank you!
Old Jan 18, 2010, 11:43 AM
MattN is offline
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
On the Droid, the buttons are WAY too small. The start/stop button should be really big to avoid timing errors in the heat of battle...
Otherwise, it's looking better and better...
-m@
Old Jan 24, 2010, 05:59 PM
turn, turn, turn.
Joined Oct 2005
Thank you!
The new upload is unusable.
The time is accelerated when pushing the back button and nothing can restore the time to normal....it continues to be accelerated.
And now, the browser and phone buttons kill the app.
Old Jan 25, 2010, 03:16 AM
vitas is online now
Munich
Joined Apr 2004
Hi,
Could someone confirm this issue?
I do not have a real phone yet and in emulator it works as expected, only home button was not possible to disable. I think at real device it's not possible to disable hardware buttons...may be not at all devices because they are manufacture specific. So I will remove this feature.
Thank you for effort, vitali
Old Jan 25, 2010, 09:58 AM
MattN is offline
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
I do not see this on my Motorola Droid. All buttons are disabled (except the Home button) when the app is running. I can push "Back" all day and it doesn't do anything.
I decided to slide the phone open and see if any of the keyboard buttons caused a problem. No issues.
Actually, there is one issue - when I slide the phone open while the timer is running, the timer resets! Same thing when I slide the phone closed...
The flight/land button is still way too small
Discussion For iPhone users: Free timer App available for download wubbe Hand Launch 189 Feb 20, 2014 07:54 AM
Discussion F3 wing shapes Mike Seale Indoor Pattern/F3P 6 Jan 08, 2010 04:08 PM
