Old Jan 08, 2010, 07:59 PM
chem teacher2 is offline
Find More Posts by chem teacher2
Joined Mar 2006
how to add rudder to vapor brick
I can not find how to add the rudder port to the vapor green dot brick. I know that it is in the discussion but can not come up with the correct search. What i want to do is add the rudder channel plug to the vapor green dot reciever. then mix the throttle with the rudder and use a 1 cell esc on the rudder to drive the 2 gram brushless
can this be done?
where to I find the directions?
there are three pads on the reciever for the rudder which is the +, -, and signal?
please help
tom
chem teacher2 is offline Find More Posts by chem teacher2
Old Jan 08, 2010, 11:30 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
http://www.rcgroups.com/forums/showthread.php?t=985344
mcross is offline Find More Posts by mcross
Old Jan 08, 2010, 11:55 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
can this be done?
please help
tom
It's a little easier to use the flap channel than the rudder, unless you have a DX7 and are doing differential thrust (you need at least 3 mixes to do this).
For an external ESC you just need to solder the Signal wire to the board and then run +/- to the Bricks +/- wires. This is the easiest way if you don't have tiny solder skills.
http://www.rcgroups.com/forums/attac...mentid=2454222
Modfly's F-18 thread
or you can solder all three Like this
UNGN is offline Find More Posts by UNGN
Discussion how to mount the vapor brick ? dizzymarkus Scratchbuilt Indoor and Micro Models 12 Dec 18, 2009 04:23 PM
For Sale Parkzonce Vapor brick/fuselage, Parkzone Cessna brick, and some small motors The Don Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 7 Nov 16, 2009 04:52 PM
Discussion Vapor and Sukhoi Brick: How Reliable, Durable and Easy to Maintain? flying-llama Micro Ready-to-Fly 2 Nov 03, 2009 12:05 AM
Question how to swap rudder and aileron on vapor brick? indoor_fr Scratchbuilt Indoor and Micro Models 3 Oct 28, 2009 06:49 PM
Help! DX7 Binding to Vapor Brick --- HOW????? termite Scratchbuilt Indoor and Micro Models 7 Oct 19, 2008 11:45 PM
