Old Jan 08, 2010, 06:37 PM
North Carolina
Joined Nov 2008
How to mount a 4mm prop on a 3mm shaft?
I would like to adapt a boat prop (probably a Gaupner 40mm diameter intended for a 4mm shaft) to an aircraft 3mm shaft, any suggestions on an easy / cheap way to do this? I was thinking along the lines of a very thin brass shim, but I don't know where I might find .5mm thick brass cheaply/easily. Any other ideas?
gobigkahuna is offline Find More Posts by gobigkahuna
Old Jan 08, 2010, 07:12 PM
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
gobs it wont work. time for a new shaft, they're not that expencive $10 for a 12" shaft
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Jan 09, 2010, 02:58 AM
North Carolina
Joined Nov 2008
No, the shaft of the motor is 3mm and all the props I've found are for 4mm shafts and I want to mount the boat prop directly on the motor's shaft (or use as short an adapter as possible, this is going to be used in an ROV project BTW).
Old Jan 10, 2010, 01:52 AM
Joined Nov 2009
Shaft adapters
Try www.wmberg.com
in their on line catalog/products click on couplings then shaft adapters,choose metric first then under"type" choose shaft adapter the pdf file shows an adapter with a female 3.0mm i.d. and 4.0 male or o.d with a 11.0mm length stock 3SAM-10 If you don't go to the pdf file it shows 3mm X 3mm I don't know why. Is this what you need? It will also need clamps. they got them too. Good helpful people, products a little pricey not too bad.
Ted
Grauen Wolf is offline Find More Posts by Grauen Wolf
Old Jan 10, 2010, 07:15 AM
North Carolina
Joined Nov 2008
Thanks, that's a great resource. You wouldn't happen to know where I can get plastic Graupner 3 or 4 blade 60mm props for a straight (no thread) shaft, would you? I used them in another project and would like to use them again in this one (so the parts would be compatible) but can't find them anywhere.
Sold 12" Folding Prop w/4mm shaft hole $8 Mini Buzzard Aircraft - General - Miscellaneous (FS/W) 1 Dec 04, 2009 11:53 PM
Discussion how can i make a 3/16" prop fit on a 1/8" prop shaft ? mortonj69 Racing Boats - Electric 3 Nov 07, 2009 05:56 AM
Help! 4mm prop on a 3mm shaft? Rex A Lott Electric Motor Design and Construction 12 Apr 24, 2007 06:48 PM
3mm Shaft how to mount prop spinner? Tommy D Parkflyers 18 Apr 24, 2005 01:41 PM
Folding Prop On A 3mm Shaft,How? winwash Power Systems 3 Dec 23, 2004 10:21 PM
