This thread is privately moderated by Cloud_Catcher, who may elect to delete unwanted replies.
Old Jan 08, 2010, 01:36 PM
Cloud_Catcher is offline
Find More Posts by Cloud_Catcher
Trader Rating: 1
Cloud_Catcher's Avatar
Bay Area, CA
Joined May 2009
Trader Rating: 1
Sold
HiTec Aurora 9 2.4 Ghz with two 7 ch Rx - brand new
I am selling a brand new HiTec Aurora 9, 2.4 GHz Transmitter and two (2) 7 channel Receivers. This is HiTec's new flagship Radio System, 9 Channels with state of the art Telemetry. I ordered this one, along with one for myself, for a friend in Germany, who changed his mind meanwhile, so it's for sale now. I waited more than 3 month to get this, it's still on backorder at Retailers. It has never been used or out of the box. More info at http://www.hitecaurora.com
Price is $ 360,- plus shipping.
Thanks for looking
JRo
Here is a detailed Feature Description from HiTec:
Basic Features
AFHSS 2.4GHz / PPM / PCM Compatible
Easy to Read 5.1 Inch Wide Backlit Touch Screen
Customizable Menus
One-Stop Model Type Setting
3 Multi-Tasking Digital Trims
Fully Assignable Control Switch, Knob, Stick and Digital Trims
Highly Sensitive 8 Ball-Bearing Gimbals with Adjustable Tension
Full-Sized Comfortable Hand Grips Featuring Top Quality Elastomer
Selectable Control Stick Mode / Change Hardware without Opening Case
Power Management System (Adjustable Backlight & Auto Shut-off Time)
Digital Trim Nano-Adjuster (Approx. 0.025deg per step up to 5deg)
Standard Programming Features
9 Assignable Control Channels
3 Model Types (ACRO/GLID/HELI) Programming
30 Model Memories
20 Character model name
8 Flight Conditions with 10 Characters
Throttle Lock
Fail-safe
Channel Function
EPA
Dual Rate & EXP*
Sub-Trim
Servo Reverse
Servo Speed (Up to 25 sec in Each Direction)
Servo Monitor (Monitor & Servo Test)
8 Programmable Mixes (5 x 2-Point , 3 x 7-Point Curves)**
Trainer Port
Advanced ACRO Programming
9 Wing Type (6 Main Wings, 3 Flying Wings)
5 Tail Type (Main Wing: Normal, V-Tail, Ailevator) (Flying Wing: 1 Servo Rudder, 2 Servo Rudders)
Quick Model Options Select (Dual Engine, Retracts gear, Airbrake, Fuel mixture)
7 Point Throttle Curve*
Throttle Cut
Idle Down
Fuel Mixture*
Airbrake
Airbrake to Elevator Mix**
Aileron to Rudder Mix**
Elevator to Camber Mix**
Rudder to Aileron Mix**
Aileron Differential*
Aileron to Flap Mix**
Camber Mix**
Flap Control*
3 x Gyro Sensitivity (ex: AILE/ELEV/RUDD)*
Snap-Roll (4-Way Switching Multi Direction)**
V-Tail**
Delta Mix**
Ailevator**
Advanced GLIDER Programming
9 wing Type (6 Main Wings, 3 Flying Wings)
Five Tail Type (Main Wing: Normal, V-Tail, Ailevator) (Flying Wing: 1 Servo Rudder, 2 Servo Rudders)
Quick Model Options Select (Motor, Retracts Gear, Airbrake)
Motor Control (Switch on/off)**
Airbrake
Launch (Stick Position Auto Cut Function)**
Camber Mix**
Flap Control*
Butterfly**
V-Tail**
Delta Mix**
Ailevator**
Advanced HELI Programming
6 Swash Types (90 Type: 1 Servo, 3 Servos, 4 Servos; 120 Type: 3 Servos; 140 Type: 3 Servos; 180 Type: 2 Servos
Quick Model Options Select (Governor, Needle Control, Fuel Mixture)
7 Point Pitch Curve*
Throttle Cut
Gyro Sensitivity*
Needle Control*
Swash to Throttle Mix*
Rudder to Throttle Mix*
Fuel Mixture*
Throttle Hold***
Swash Mix (Swash Rate/Calibration )***
Revolution Mix*
Governor (Three Rates)*
* Capable of a Maximum of 24 rates by 8 flight conditions and 3 switch positions
** Capable of a Maximum of 8 Rates by 8 Flight Conditions
*** Capable of a Maximum of 3 Rates Using 3-Swicth Positions
Cloud_Catcher is offline Find More Posts by Cloud_Catcher
Old Jan 08, 2010, 01:39 PM
David_the_priest is offline
Find More Posts by David_the_priest
Trader Rating: 18
Thou shall fly
David_the_priest's Avatar
Joined Apr 2006
Trader Rating: 18
do you have any other ratings at another site?
David_the_priest is offline Find More Posts by David_the_priest
Old Jan 08, 2010, 02:00 PM
Trader Rating: 1
Bay Area, CA
Joined May 2009
Trader Rating: 1
Sorry I don't trade very often and I am still fairly new to this hobby.
However I have a 100% positive feedback record on eBay from a few trades since 2001. My eBay profile name is walk_in_the_park.
I'd be glad to send you my phone and skype info or others to verify via PM, just let me know.
JRo
Old Jan 08, 2010, 02:02 PM
Greywing is offline
Find More Posts by Greywing
Trader Rating: 47
USA, CA, Pismo Beach
Joined Oct 2007
Trader Rating: 47
PM sent
I'll take it. Pm sent
Greywing is offline Find More Posts by Greywing
Old Jan 08, 2010, 10:01 PM
Greywing is offline
Trader Rating: 47
Joined Oct 2007
Trader Rating: 47
Aurora
PP sent.
Old Jan 08, 2010, 11:04 PM
Trader Rating: 1
Bay Area, CA
Joined May 2009
Trader Rating: 1
Sold to Greywing
Question Hitec Aurora 9 2.4 GHz for DLGs? Noel Robbins Hand Launch 42 Jul 20, 2010 04:06 PM
Discussion Rough guess When the hitec aurora 9 with 9ch rx firehopper Hitec/Multiplex USA 2 Dec 10, 2009 07:35 PM
Sold JR X9303 2.4 Ghz Pristine condition w/r921 9 ch RX Just flyy Aircraft - General - Radio Equipment (FS/W) 5 Aug 17, 2009 11:05 AM
Sold Brand New Futaba 10CG Dedicated 2.4 Ghz with R6014HS 14 Channel Rx $530 Shipped cbcalhoun Aircraft - General - Radio Equipment (FS/W) 6 Jun 10, 2009 06:37 AM
Sold Brand new JR R921 9 Channel DSM2 2.4 GHz Rx *Off Site* Cotoflyer Aircraft - General - Radio Equipment (FS/W) 3 Jun 04, 2009 03:31 PM
