Old Jun 10, 2010, 11:37 AM
Bas B is offline
Find More Posts by Bas B
Joined Jul 2007
Originally Posted by Teo View Post
Is there some one how can post picture of servo installation of v2 fuselage. It's very tight place
Greetings
Teo
Hello Teo,
indeed bit of a challange to get the equipment in the fuse. Here some pictures of the installation of my Twister 2.
Battery: 4 * GP 35AAAH (can be easily removed from the fuse).
Receiver: Jeti Duplex R6.
Servo's: 2 * D47 (sorry Greg and Steve).
Upgraded ballast system (maximum 120 grams).
Hope this helps,
Bas Breijer
Bas B is offline Find More Posts by Bas B
Old Jun 10, 2010, 01:11 PM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
Is that the ballast system that comes with it or is it something of your own design.
Do the brass tubes have lead in them? Do they come filled or do you have to do this yourself?
how long are the brass and carbon ballast tubes?
Looks cool.
Enjoy flying (and winning) with it!
Frank
Fly2High is offline Find More Posts by Fly2High
Old Jun 10, 2010, 01:55 PM
Bas B is offline
Joined Jul 2007
Looks cool.
Frank
Frank,
The ballast system is my own design.
The two ballast rooms are made from carbon hose (EMC-VEGA SC1032) and have an inside diameter of about 5.2 mm. At the forward 2.5 cm, one layer is added to give additional strength at the point where the ballast is locked. The total weight of the rooms is about 2.5 grams. The end of the tubes is about at the location of the trailing edge of the wing.
The ballast consist of brass 5 mm outside/ 4 mm inside diameter with a length of 23.5 cm. A double 0.4 mm steel spring is soldered on the front part. The shape of the spring is such that the front is bent inside the brass, so if the solder fails the ballast is still locked.
I use ballast of 60, 30 and 15 gram. For the 60 grams ballast Tungsten (18 kg/dm3) is glued inside the brass and for the 17 and 30 grams ballast steel is glued inside the brass with 5 minute epoxy. The center of gravity matches with the center of gravity of the plane.
Regards,
Bas
Old Jun 10, 2010, 03:57 PM
mpodder is offline
Find More Posts by mpodder
Maurice
mpodder's Avatar
Bakersfield, Cal.
Joined Jul 2004
Looks like there is plenty of room to put just about what ever you want in there (188s or 281/285 ).
Maurice
mpodder is offline Find More Posts by mpodder
Old Jun 10, 2010, 04:26 PM
atlav8r is offline
Find More Posts by atlav8r
atlav8r's Avatar
Cumming Ga
Joined Apr 2002
Maurice
I was hoping to use the DS285s in my new T2 because they are real good but by brother (who is building the plane) said he did not see any way of them fitting. The inside height where the servos reside is 25mm MAX. Looks like the D47 is the ticket.
Cliff
atlav8r is offline Find More Posts by atlav8r
Old Jun 10, 2010, 04:52 PM
Peter Aanen is offline
Find More Posts by Peter Aanen
Joined Sep 2007
Greetings
Teo
Other possibility. Aft D47 flat on bottom, front D47 tilted to give clearance for single pull strings. Ballast on right hand side, steering strings on left.
Peter
Peter Aanen is offline Find More Posts by Peter Aanen
Old Jun 10, 2010, 04:58 PM
atlav8r is offline
atlav8r's Avatar
Cumming Ga
Joined Apr 2002
Peter
I like the looks of the green!
Old Jun 10, 2010, 05:21 PM
SOAR-Steve is offline
Find More Posts by SOAR-Steve
Steve Meyer
SOAR-Steve's Avatar
Mt Pleasant, WI
Joined Jun 2005
Cliff
I do not have exact measurements of that fuselage but it looks quite similar to a Sirius. You will have to lay the DS285 on it's side. But to each his own. I have D47 in the Vandal and Light Hawk wings.
SOAR-Steve is offline Find More Posts by SOAR-Steve
Old Jun 10, 2010, 06:14 PM
mpodder is offline
Maurice
mpodder's Avatar
Bakersfield, Cal.
Joined Jul 2004
>The inside height where the servos reside is 25mm MAX.<
Just checked and the DS188/185 is exactly 25mm from bottom to the top of the screw. You could also probably grind the output gear down 1 to 2mm and be down to 24 to 23mm which is very close to the D47 at 22.7mm.
What do you think
Maurice
Old Jun 10, 2010, 07:58 PM
G Norsworthy is offline
Find More Posts by G Norsworthy
Master of the Wind
G Norsworthy's Avatar
United States, AZ, Tempe
Joined Sep 2008
I intend to try to stuff DS188 in mine but I will have to look at it first. I got two in my Twister 1 with no problem.
G Norsworthy is offline Find More Posts by G Norsworthy
Old Jun 11, 2010, 12:23 AM
arrowho is offline
Find More Posts by arrowho
Joined Jun 2010
Twister 2
[報價 = Ğ諾斯沃; 15290147]我打算嘗試的東西 DS188排雷,但我會看它。我有兩個在我的難題一沒有問題。[/報價]
Hello everybody I share my Twister 2
[IMG公司] http://i95.photobucket.com/albums/l1...o/RIMG0026.jpg [/ IMG公司]
[IMG公司] http://i95.photobucket.com/albums/l1...RIMG0002-1.jpg [/ IMG公司]
[IMG公司] http://i95.photobucket.com/albums/l1...o/RIMG0005.jpg [/ IMG公司]
[IMG公司] http://i95.photobucket.com/albums/l1...RIMG0004-1.jpg [/ IMG公司]
arrowho is offline Find More Posts by arrowho
Old Jun 11, 2010, 05:48 AM
maikoflyer is offline
Find More Posts by maikoflyer
Joined Sep 2004
C261/DS281/DS285 does not fit in that fuse. No go.
One S3154 may fit as far forward as possible but two never. At least not without grinding heavily the case down.
I would also say that d4.7 is the way to go. For the others that try to fit at least one digital servo for elevator in that fuse, the fuse is a bit asymmetric so it is possible that the servo fits in one direction and not in the other.
lg
maikoflyer is offline Find More Posts by maikoflyer
Old Jun 12, 2010, 01:17 PM
ROOSWH is offline
Find More Posts by ROOSWH
Walter Roos
ROOSWH's Avatar
Canton, Ga.
Joined Aug 2004
For the Elevator, the HS-50 which is suppose to have very good centering, may be of use. They are a bit tall, small otherwise. They were once in favor, for DLG elevators. Sides flat to the bottom perhaps.
Just trying to help. No dog in this hunt.------yet.
walt
ROOSWH is offline Find More Posts by ROOSWH
Old Jun 13, 2010, 02:12 AM
f5mmx is offline
Find More Posts by f5mmx
Glasson Master
f5mmx's Avatar
France, IdF, Breuillet
Joined Sep 2004
The fuse setup on my twister 2 can be seen here: http://picasaweb.google.com/jmb91650/F3KTWISTER2
2 x D47 side by side
Jean-Michel
f5mmx is offline Find More Posts by f5mmx
Old Jun 13, 2010, 12:02 PM
tigroot is offline
Find More Posts by tigroot
Bob W
Rock Hill, SC
Joined Jul 2003
I finished assembly on my T2 a few days ago, and have about 5hrs flying time with it. I've been going out in the morning and in evening to sample flying different conditions. Although I just started getting used to my T1 I can feel the improvements Alex has implemented in the T2!! Hard to describe but I will say overall stiffness, turning, float and range are better :-) The fuseboom design is sweet! The boom is oval for what I can tell all the way back to the tail set which gives an exquisitely solid feel at launch. Complete sickness! I'm not too obsessive about weight but mine is like 267g up with 20g in nose for balance at fwd most point of recmd CG with my gear. I have a 2cell Lipo, PD regulator and a couple D47 for R/E. Standard stuff..I also fly old school 72 so your gear arrangement may vary on 2.4. I want to thank Alex and Cliff for working togethor to bring this for all to enjoy.
Bob
tigroot is offline Find More Posts by tigroot
