The big difference is that the heli version has the three position switch on the upper left of the transmitter and the aircraft has that as a two position only switch. The aircraft three position switch is where the gyro switch is. In other words, to have three mode heli (Normal, Idle 1, Idle 2), you need to assign the switch to the flap switch and then the gyro to the gear switch. Of course, you can still assign all mode, gyro, D/R, and expo to a single switch of your choice but it will take a bit of getting used to, that's all. Take care.
Don |
Pittsburgh
Joined Jan 2011
I just flew out a battery in the bedroom... I'm getting 8" hover at 2.5 hash marks past center stick.. I did try at just barely on the ground a switch to ST and other than higher motor speed there was no sign of down or up movement of heli or blades.. Speaking of blades I'm getting some head wobble.. think I'll pull them off and balance then again.. also will check main shaft if bent I'll go through everything when the new swash gets here.. Going to replace the dampers also with some T Rex ones if they fit.. Anyone else wish that the flybar was under the blades and the blades where that extra inch above the boom?
if you are a visual learner to setup a DX7 heres a start from you tube
I have a dx7 airplane model setup for my SR. It works great. The Pilot.....not so much. |
If you haven't done so, check for vertical play in the mainshaft. And definitely replace the swash. You don't want to have a swash separate in flight. From what I've heard, it can get pretty ugly (and expensive). Let me know what you think of the CNC main gear. I've been thinking about getting one. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Bob, The ones from the newer TR 450 won't work, but the ones from the original TR 450 will. B400 dampers also work, but they're lower-durometer than the TR dampers. I'm using CPP dampers, which are a higher durometer than the stock parts, but not as high as the B400 dampers. And yes - I also wish the flybar was under the mains. Not sure why they designed the CP head that way in the first place. However, the EFlite c/f CPP blades pretty much eliminate the possibility of a boom-strike - even with the stock dampers. Well...unless one lands @ -20 fps... ![]() Joel |
Joel |
That should be here by the end of the week. My tracking was pretty far off last night when I put the new blades on. So I brought one blade up and seems when things went crazy. But it could be the swash. I am going to change that first..........and i'll put on the Delrin main gear and let you know how that goes. Life is weird, then you try RC Heli's and it just gets weirder....... I'll figure this out if it kills me. I didn't go to bed until 8 am this morning. I need my head examined.
| Thread Tools | |
| New Product Blade SR RTF Electric Micro Heli by E-flite | ghost2212 | Micro RTF | 2 | Jan 07, 2010 09:36 AM |
| Sold SOLD Blade CP RTF Electric Micro Heli by E-flite | Lakepilot | Aircraft - Electric - Helis (FS/W) | 3 | Nov 26, 2007 05:40 PM |
| Sold Used E-Flite Blade CP RTF Electric Micro Heli | tallflyer | Aircraft - Electric - Helis (FS/W) | 3 | Apr 13, 2006 03:28 AM |
| For Sale 4 sale E-Flite Blade CP RTF Electric Micro Heli | tallflyer | Aircraft - Electric - Helis (FS/W) | 0 | Feb 06, 2006 12:09 PM |
| E-Flite Blade CP RTF Electric Micro Heli | tallflyer | Product Announcements | 0 | Nov 17, 2005 02:42 PM |
