Latest blog entry: My Low Wing plane
I had referenced these power supplies in a different thread located here: http://www.rcgroups.com/forums/showthread.php?t=1005309 where JJ604 showed how to get a different power supply to work.
If anybody is interested in the power supply mentioned in this thread there are here www.trademoon.com business has around 100 of the DL580 HP Proliant 800w power supplies in stock. These are the refurbished ones. http://www.trademoon.com/Product58670.aspx They want $10 US for each one with around $17.00 UPS ground shipping CONUS. |
As you have started a thread for these perhaps my limited data my help. See post here
http://www.rcgroups.com/forums/showt...4#post13998054 I believe that AC should be Blk. White ,Green as #3 (third from left)is earth(case) ground . Charles |
Good point, thanks.
everydayflyer numbered the pins from his message and pics here:
Control pins left to right , top to bottom 1-6 7-12 13-18 19-24 top row 4,5 ground second row 10,12 ground third row 15,17,18 ground fourth row (bottom) 20 ground Charles ![]()
Yes you are correct everydayflyer.
I wired it up like you stated, and low and behold! The green LED is blinking on and off. I assume Green would mean good, the other LED below it is probably the red error LED. So now there is only to figure out how to get it out of standby mode. ![]()
| Thread Tools | |
| Question Any info on Compaq ESP108 as a Power Supply | jj604 | DIY Electronics | 22 | Apr 17, 2012 05:00 PM |
| Pin out for Compaq PS4060 power supply? | cwdance1 | Batteries and Chargers | 5 | Oct 13, 2011 07:55 PM |
| Question Got a 12VDC 13A OP Server Power Supply, but only 5VDC OP? | LexTalionis | Batteries and Chargers | 4 | Aug 17, 2004 08:48 PM |
| F/S Compaq Proliant 800 Server--CLOSED | bankitguy | Aircraft - Electric - Airplanes (FS/W) | 1 | Dec 08, 2002 08:43 PM |
