View Poll Results: Which DW do/have you own/owned?
DW 28" kit 62 10.49%
DW SKUA 29 4.91%
DW 38" kit 177 29.95%
DW 48" kit 156 26.40%
DW 55" kit 71 12.01%
DW Pylon Racer 9 1.52%
Never owned one 208 35.19%
Multiple Choice Poll. Voters: 591. You may not vote on this poll
Old Sep 26, 2010, 10:22 AM
michaelJH is offline
Find More Posts by michaelJH
Team Extreme!
michaelJH's Avatar
Wa, state
Joined Oct 2009
it is bad to turn the rates down... Doing so, you lose alot of your torque and that is no good. you should put your linkege further in to prevent blow back. I like at to be between 120% and 150%.
michaelJH is offline Find More Posts by michaelJH
Old Sep 26, 2010, 11:14 AM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
I wound up test flying this morning and I think i'm going to make a little mod on the aileron linkages, kinda feels like they're flexing. I'm using digitals that have 3x more torque than this plane needs, and haven't noticed any blowback on them.
I turned the rates back up to 100% on the ailerons- elevator and rudder are fine for me.
What i'm going to do is make a carbon/piano wire pushrod like the tailfeathers. Not concerned about the weight, it's already light enough
Xpress.. is offline Find More Posts by Xpress..
Old Sep 26, 2010, 11:59 AM
Doug Cronkhite is offline
Find More Posts by Doug Cronkhite
TimeShare
Doug Cronkhite's Avatar
United States, UT, Tooele
Joined Feb 2002
For the best mechanical advantage, you want to run the shortest servo arm you can get away with. What I try to do is set my ATV to maximum (125%) and then use the servo arm hole that gets me the throw I want. I do this whether it's for a 3D airplane or a precision airplane.
You get the best mechanical advantage AND the best resolution out of your radio/servos.
Doug Cronkhite is offline Find More Posts by Doug Cronkhite
Old Sep 26, 2010, 02:26 PM
killsdeer4fun is offline
Find More Posts by killsdeer4fun
With great pwer comes great 3D
killsdeer4fun's Avatar
Globe, USA, Clemson, SC
Joined Jun 2010
Servos are rated at their power level 1 inch out from center, so you can see how the torque would increase/decrease depending on how far in/out you set the linkage.
killsdeer4fun is offline Find More Posts by killsdeer4fun
Old Sep 26, 2010, 03:02 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
I have my linkages set about 3/4" out. I find that the surface speed actually increased when I made all of my linkage geometry
correct.
In all honesty, my rudder linkage is the only surface that i've turned up to 125% EPA and set 125% D/R (max on the Optic 6) and it's just about half an inch out from the elevator, BUT, it is the slowest moving surface I have. I kinda set it up traditionally, but with the linkages, it's very tight, and doesn't get blowback very easily, even pushing on the surface.
Talking to a couple friends, they say what i have is perfect, and I can fine tune from there. Need to get some tightened up aileron linkages and such, then fine tune before I start making a video for FlopGuns freestyle contest
I might just setup dual rates on this one too, because I've found that it loves long lines too
Old Sep 26, 2010, 06:11 PM
Idoitall is offline
Find More Posts by Idoitall
United States, CA, Modesto
Joined Oct 2009
any one fly with a regular 4 ch tx? as in non computer system?
Idoitall is offline Find More Posts by Idoitall
Old Sep 26, 2010, 07:01 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
You can do it. The only problem is you won't be able to add in EXPO, unless it has an EXPO setting. The travel you should be able to control with the ATV settings.
Old Sep 26, 2010, 07:37 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Wrapped up the color scheme on my Yak55. Waiting until the heat goes down to about 80* (99 right now ) before I will go out and do some more trimming.
Gotta make a mental note to do paint before the parts get glued together..
Old Sep 26, 2010, 08:44 PM
Joethefloorman is offline
Find More Posts by Joethefloorman
Team DW Foamies (Snap)
Joethefloorman's Avatar
Cali
Joined Jun 2008
Looks sweet Ex.
Joethefloorman is offline Find More Posts by Joethefloorman
Old Sep 26, 2010, 09:00 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Originally Posted by Joethefloorman View Post
Looks sweet Ex.
Yeah, well the bottom of the nose looks less sweet now. One of my aileron servos locked up, and in she went. Was in a nice blender, then went to stop the roll and no control.
I had pulled up elevator just in time, and it settled in nice and flat. Nose took all of the damage though. Oh well, a little CA, and a zip tie..
This is the second time one of my Coronas has taken a dump on me. Looks like they're being abandoned and in go the HS65HB's
danielph is offline
Find More Posts by danielph
TEAM EXTREME!
danielph's Avatar
High Prairie, WA
Joined Nov 2007
Very nice! Have fun with it!
danielph is offline Find More Posts by danielph
Old Sep 26, 2010, 09:26 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
I think i'm going to buy a pair of HS65HB's from the HS next time. Rudder servo seems fine.
Old Sep 26, 2010, 09:33 PM
mikeruth is offline
Find More Posts by mikeruth
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
did you find out what went worng with the servo? Gear or electroncs?
Mike R
mikeruth is offline Find More Posts by mikeruth
Old Sep 26, 2010, 10:16 PM
Team Extreme!
michaelJH's Avatar
Wa, state
Joined Oct 2009
I had a POT go bad on one a while ago. Not good...
Old Sep 26, 2010, 11:12 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Mike R
Not sure, probably the motor (theyre digital, no pot). I don't believe it was my control surafce, not a chance that is was.
I'd rather run HS65HBs anyways, I can get them for 23 a piece
Also, gotta tape a nickel or something on the opposite wingtip at the lipo. Noticed that when inverted it couples to that side, and only that side- no flex in the elevator either.
Mini-HowTo DW Foamies - Colored Packing Tape Trim Scheme rpmrpm Painting and Finishing Tips 47 Feb 24, 2013 04:35 PM
Discussion DW foamies BAF 48" yak 54 build thread appleflyer 3D Flying 50 Jul 24, 2012 03:31 PM
Discussion DW Foamies Yak Junior Build Thread NumbSkull 3D Foamies 90 Feb 01, 2012 03:25 PM
Poll DW Foamies owners thread (poll) Xpress.. 3D Flying 132 Mar 26, 2010 11:10 AM
Discussion DW (Depron West) Foamies 38" Gen-X tdriedger 3D Foamies 14 Jan 12, 2010 04:13 PM
