View Poll Results: Which DW do/have you own/owned?
DW 28" kit 62 10.49%
DW SKUA 29 4.91%
DW 38" kit 177 29.95%
DW 48" kit 156 26.40%
DW 55" kit 71 12.01%
DW Pylon Racer 9 1.52%
Never owned one 208 35.19%
Multiple Choice Poll. Voters: 591. You may not vote on this poll
Old Sep 19, 2010, 12:24 AM
michaelJH is offline
Find More Posts by michaelJH
Team Extreme!
michaelJH's Avatar
Wa, state
Joined Oct 2009
That is the bueaty of foamies! A little glue and you can fix almost anything and be flying in 15 minuets!
michaelJH is offline Find More Posts by michaelJH
Old Sep 19, 2010, 02:42 AM
Doug Cronkhite is offline
Find More Posts by Doug Cronkhite
TimeShare
Doug Cronkhite's Avatar
United States, UT, Tooele
Joined Feb 2002
Yeah.. I really whacked my Juka today.. took about 5 minutes and it was ready to go again.
Doug Cronkhite is offline Find More Posts by Doug Cronkhite
Old Sep 23, 2010, 01:18 PM
B.RICHARDS is offline
Find More Posts by B.RICHARDS
Joined Sep 2010
Hey guys I just purchased a 40" Extra and was wondering what the best glue to use to assemble and fix would be? Should I just use tape for hinging or is there some great hinge I should also be using? I also like Deans plugs but they seem a little bulky for the 3s 1200mah batteries I will be using. What is the preferable plug mini deans, jst, regular size deans, bullets etc... Thanks for your help this is my first plane getting a little burnt out on the racing scene!
B.RICHARDS is offline Find More Posts by B.RICHARDS
Old Sep 23, 2010, 01:28 PM
watchingcarpet is offline
Find More Posts by watchingcarpet
watchingcarpet's Avatar
Joined Dec 2008
For glue, I use BSI Foam Safe CA (WITH ACCELERATOR!), and DW PVA. THe Foam Safe CA is good for glueing the wings on, glueing in the firewall. You can also use it to tack in the fuse, then finish glueing the fuse with PVA. Also, this is on a side note but you would be best taping on the carbon spar on the wing. Don't try to glue it, just use 1" blenderm.
On the topic of the battery connector, you would be best off using Deans Ultra plugs. That's what I use, and it's what at least 95% of other people use. Deans have proved themselves as top-of-the-line connectors, and in my opinion are much better than JST or other connector types.
watchingcarpet is offline Find More Posts by watchingcarpet
Old Sep 23, 2010, 01:36 PM
FlopGun is offline
Find More Posts by FlopGun
You brought two too many.
FlopGun's Avatar
United States, WA, Seattle
Joined Jul 2007
I like to use BSI CA for most of the build, with white gorilla glue on key spots like the motor mount area, the fuse at the end of the tail, the fuse under the wing, also where the top and bottom fuse join, and for the carbon reinforcements. Basically anywhere you need gap filling or flex use the gorilla glue.
I barely glue the spar on the wing at first, I like to wait until the end of the build to really lock down the spar to the wing as it might crack while you are building. I don't like blenderm on the spar because the wing can flop around.
And Anderson power poles work very well and are light and can be connected and disconnected with one hand.
FlopGun is offline Find More Posts by FlopGun
Old Sep 23, 2010, 07:54 PM
Xpress.. is online now
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Use Deans Ultra for anything 10 amps and over. JST and mini Deans are okay for the small stuff, under 10 amps
Xpress.. is online now Find More Posts by Xpress..
Old Sep 24, 2010, 01:13 PM
Xpress..'s Avatar
Joined Oct 2007
Woohoo, I finally got mine
Ran out of CA
Gotta make a trip to the hobby shop today. Need more Medium and Thin..
Old Sep 24, 2010, 01:14 PM
TimeShare
Joined Feb 2002
Bah.. another 55M.. LOL. Am I the only person who likes the SP-55 better?
Old Sep 24, 2010, 01:26 PM
danielph is offline
Find More Posts by danielph
TEAM EXTREME!
danielph's Avatar
High Prairie, WA
Joined Nov 2007
Where's the paint XP? Have fun with it!
danielph is offline Find More Posts by danielph
Old Sep 24, 2010, 02:10 PM
Xpress..'s Avatar
Joined Oct 2007
I gotta grap a couple cans and some CA next time I'm at the hobby shop. I got a cool idea...
Old Sep 24, 2010, 10:47 PM
Joethefloorman is offline
Find More Posts by Joethefloorman
Team DW Foamies (Snap)
Joethefloorman's Avatar
Cali
Joined Jun 2008
I changed my build to an SP.
Joethefloorman is offline Find More Posts by Joethefloorman
Old Sep 25, 2010, 01:13 PM
Xpress..'s Avatar
Joined Oct 2007
I was just down in my basement putting a fuse together for a 48" 330, and I realized how well the parts fit together on their own! Nice and tight too
This is just a testament to how well designed these kits are! No CA has been used yet.
Old Sep 25, 2010, 10:26 PM
Xpress..'s Avatar
Joined Oct 2007
Little bump..
Finally finished my Yak 55M (for the most part) and it came out to a whopping 15.4oz!
I also played with my linkages a bit, tried something I've never tried before.
Still have to finish painting it, and apply the vinyls. Oh yeah, and fly it
Old Sep 25, 2010, 10:46 PM
jholen is offline
Find More Posts by jholen
Ride Blue
jholen's Avatar
United States, WA, Sammamish
Joined Aug 2006
Nice Xpress! What power setup did you decide to go with? and servos?
jholen is offline Find More Posts by jholen
Old Sep 26, 2010, 12:39 AM
Xpress..'s Avatar
Joined Oct 2007
The usual. Himax HC2812-1080 outrunner, APC 10x4.7SF prop, Castle Creations Thunderbird 18 ESC, and an assortment of lipos, nothing bigger than 3s 1330.
Servos are all Corona DS939MG digitals, and one Hitec HS65HB on the elevator. With the control rods mounted in the farthest hole out on everything (except HS65HB- 1 hole in on the long arm), everything I had to turn the rates DOWN instead of up like I usually do
Mini-HowTo DW Foamies - Colored Packing Tape Trim Scheme rpmrpm Painting and Finishing Tips 47 Feb 24, 2013 04:35 PM
Discussion DW foamies BAF 48" yak 54 build thread appleflyer 3D Flying 50 Jul 24, 2012 03:31 PM
Discussion DW Foamies Yak Junior Build Thread NumbSkull 3D Foamies 90 Feb 01, 2012 03:25 PM
Poll DW Foamies owners thread (poll) Xpress.. 3D Flying 132 Mar 26, 2010 11:10 AM
Discussion DW (Depron West) Foamies 38" Gen-X tdriedger 3D Foamies 14 Jan 12, 2010 04:13 PM
