Here is mine (thanks to RPMRPM for the tape checkers hints!). Hope to finish the gluing and power systems later this week.
So I had my first flights in calm weather today, virtually no wind and once I'd put a few clicks of elevator in the plane, everything went soo smoothly. My 38" Juka has unlimited vertical and can do everything I can throw at it, which isn't much, but it makes me look like I know what I'm doing.
My only question is, how do you guys land in the grass? I'm not using landing gear and just cut the throttle to let the plane just drop to the ground. However, on the last landing attempt, I dropped the plane w/ a bit of nose down attitude and broke the vertical fuse a bit. Any suggestions? |
Thanks for the tips. Cullen |
I have a quick question about repair procedures for a 48" juka. I managed to snag a wingtip in the grass on a low roller, and as I had used steel wing bolts, the wings did not pop off, and instead snapped the fuselage around and cracked it in half right behind the wings. It was a nice clean break, and I have since glued the tail back on, but was curious if reinforcement is needed along the break seam? I could potentially glue some carbon rods along the fuselage over the crack, but I'm not sure if it's even necessary.
Thanks in advance! |
Thanks! |
| Thread Tools | |
| Mini-HowTo DW Foamies - Colored Packing Tape Trim Scheme | rpmrpm | Painting and Finishing Tips | 47 | Feb 24, 2013 04:35 PM |
| Discussion DW foamies BAF 48" yak 54 build thread | appleflyer | 3D Flying | 50 | Jul 24, 2012 03:31 PM |
| Discussion DW Foamies Yak Junior Build Thread | NumbSkull | 3D Foamies | 90 | Feb 01, 2012 03:25 PM |
| Poll DW Foamies owners thread (poll) | Xpress.. | 3D Flying | 132 | Mar 26, 2010 11:10 AM |
| Discussion DW (Depron West) Foamies 38" Gen-X | tdriedger | 3D Foamies | 14 | Jan 12, 2010 04:13 PM |
