View Poll Results: Which DW do/have you own/owned?
DW 28" kit 62 10.49%
DW SKUA 29 4.91%
DW 38" kit 177 29.95%
DW 48" kit 156 26.40%
DW 55" kit 71 12.01%
DW Pylon Racer 9 1.52%
Never owned one 208 35.19%
Multiple Choice Poll. Voters: 591. You may not vote on this poll
Old Jun 25, 2012, 01:28 AM
santiago3d92095 is online now
Find More Posts by santiago3d92095
santiago3d92095's Avatar
Joined Apr 2011
Originally Posted by 3dRCrazy View Post
Is there any alternative prop than the 8x6 slowfly for the 28in models. One with a little less power?
or you could program it on your radio(for example for 100% to 80%) that way your set up would run cooler and you would pull less amps,not to mention longer flight time
santiago3d92095 is online now Find More Posts by santiago3d92095
Old Jun 25, 2012, 10:03 AM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Why would you want less power?
BryanEW710 is offline Find More Posts by BryanEW710
Old Jun 27, 2012, 06:55 PM
Doug Cronkhite is offline
Find More Posts by Doug Cronkhite
2015 USA F3K Team Manager
Doug Cronkhite's Avatar
San Diego
Joined Feb 2002
Less power often makes the powerband easier to manage finite adjustments. So it's easier to get just a 'little bit' more throttle when you want it.
It IS possible to have too much power in these airplanes.
Doug Cronkhite is offline Find More Posts by Doug Cronkhite
Old Jun 27, 2012, 07:09 PM
rcnxs is offline
Find More Posts by rcnxs
Alabaster AL
Joined Aug 2006
I would agree to a point. I have a BAF Juka with the recommended Scorpian motor. It has insane power, as do most of my foamies but it is easy to control with the left stick. If you have trouble with the left stick, then you probably have the same issue with the rudder. If you can't control both, your in trouble.
Now that being said, the power needs to be linear, so be sure and set you end points correctly on the ESC.
I would rather have the extra power by pushing up the left stick then go to the stops and not have enough. It just takes burning milliamps to learn and get the technique down.
RCNXS
rcnxs is offline Find More Posts by rcnxs
Old Jun 27, 2012, 07:43 PM
BryanEW710's Avatar
Joined Sep 2010
I can understand that to an extent. My 38" Yak has almost trainer-like power levels, and I feel like flying 3D at such low power made me a better pilot.
Old Jun 30, 2012, 08:18 AM
AJsToyz is offline
Find More Posts by AJsToyz
United States, MI, Saline
Joined Feb 2010
Ok, I finished the Juka but its tail heavy. Is the C.G. From D.W. pretty close? I moved the ESC all the way up and the battery (1300mah) right to the motor mount and I'm very close to 1/2" behind the spar. It came with a Turnigy ESC, but I don't care for it. It does not seem to have very smooth throttle response . If I want to have some real fun later , it will need longer servo arms also.
Andy
AJsToyz is offline Find More Posts by AJsToyz
Old Jun 30, 2012, 08:37 AM
foamyflyerr is offline
Find More Posts by foamyflyerr
Joined Jun 2012
"trainer like power levels" I agree. I just got a 39 inch DW Foamy YAK 54 two weeks ago. I have already over 20 flights on it and have been able to do most every 3D stunt with it right out of the chute that I have been practicing on the Real Flight Sim. Last Sunday when I re-launched my Radian Pro Glider for the first time in almost a year it seemed so much less daunting to fly. The Foamy has taught me so much in just this short amount of time that I would agree that it is almost like a trainer plane.
foamyflyerr is offline Find More Posts by foamyflyerr
Old Jun 30, 2012, 09:22 AM
BryanEW710's Avatar
Joined Sep 2010
FWIW, I fly my 38" Yak on a Park 370 (might be a 400...don't have the plane in the same state to have a look at, lol). Either way, it's less power than the plane is spec'ed for. It can hover, but just barely--and don't even think of trying to punch it out.
Old Jun 30, 2012, 11:22 AM
Mugen4Lfe is offline
Find More Posts by Mugen4Lfe
Mugen4Lfe's Avatar
Joined Sep 2011
Andy
The CG on my Juka is set for level flight both upright and inverted. I think I read that in the manual somewhere. Just remember CG is kind of a personal preference. Some like it more forward and others more to the rear.
Mugen4Lfe is offline Find More Posts by Mugen4Lfe
Old Jun 30, 2012, 11:39 AM
AJsToyz is offline
Joined Feb 2010
I totally understand that ( have quite a few planes ) the question is, "is the CG in the manual pretty close or accurate for starts?" If I don't have the battery and esc all the way at the motor the plane is extremely tail heavy.
Old Jun 30, 2012, 02:21 PM
jlremr is offline
Find More Posts by jlremr
Johninarky
Rogers,Arkansas
Joined Jul 2005
I have 3 DW 40" planes and all are neutral if I balance 1/2 behind spar as the manual calls for. The 40" Yak has a Hacker 2020L, The Extra has a Hacker 3028S or a Rocket 3010 and all fly with 1000 mah Sky lipo's.
John
jlremr is offline Find More Posts by jlremr
Old Jun 30, 2012, 08:37 PM
mikeruth is offline
Find More Posts by mikeruth
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
Yes the CG that Mike has called out is definetly OK, to go with as a starting point.
Mike R
mikeruth is offline Find More Posts by mikeruth
Old Jun 30, 2012, 08:55 PM
AtomicFlyer is online now
Find More Posts by AtomicFlyer
Close enough
AtomicFlyer's Avatar
United States, AZ, Prescott
Joined Jun 2008
Just a thought, but maybe you can look at the placement of the rudder and elevator servos. Moving them forward gives a pretty big bang for the buck because of the long moment arm back at the tail.
Marc
AtomicFlyer is online now Find More Posts by AtomicFlyer
Old Jul 03, 2012, 12:35 PM
mark_q is online now
Find More Posts by mark_q
Seattle, WA & Las Vegas, NV
mark_q's Avatar
Joined Sep 2003
Killer Auroras for your foamy
If you have seen the Aurora lights, you know what I'm talking about. They are pricey, so I made my own version which I show on this thread:
http://www.rcgroups.com/forums/showp...postcount=7994
The end result (the picture doesn't do the brightness justice!)
Happy 24hr flying!
mark_q is online now Find More Posts by mark_q
Old Jul 15, 2012, 05:37 PM
DenverJayhawk is online now
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
crashed my beloved 40 Juka into a chain link fence at a soccer turf field this morning trying to come out of a low roller. Ripped off the nose section again including firewall. I think it might be time to retire it and build the back up 40 Juka kit that's been patiently waiting in the garage. It had been rebuilt about 4 or 5 times with nearly two bottles of CA in it. It will be missed.
DenverJayhawk is online now Find More Posts by DenverJayhawk
Mini-HowTo DW Foamies - Colored Packing Tape Trim Scheme rpmrpm Painting and Finishing Tips 47 Feb 24, 2013 05:35 PM
Discussion DW foamies BAF 48" yak 54 build thread appleflyer 3D Flying 50 Jul 24, 2012 04:31 PM
Discussion DW Foamies Yak Junior Build Thread NumbSkull 3D Foamies 90 Feb 01, 2012 04:25 PM
Poll DW Foamies owners thread (poll) Xpress.. 3D Flying 132 Mar 26, 2010 12:10 PM
Discussion DW (Depron West) Foamies 38" Gen-X tdriedger 3D Foamies 14 Jan 12, 2010 05:13 PM
