View Poll Results: Which DW do/have you own/owned?
DW 28" kit 62 10.49%
DW SKUA 29 4.91%
DW 38" kit 177 29.95%
DW 48" kit 156 26.40%
DW 55" kit 71 12.01%
DW Pylon Racer 9 1.52%
Never owned one 208 35.19%
Multiple Choice Poll. Voters: 591. You may not vote on this poll
Old May 14, 2012, 07:11 PM
Bigugly is offline
Find More Posts by Bigugly
Mesquite Tx
I have a 40" Juka with the Dynamo motor that DW sells. I was wondering if anyone was having a problem with that motor being excessively loud, I don't mean vibration loud, its a very high pitched loud especially on start up, with no start up problems or shuddering, It does have excessive power and I have tried it one 3 different ESCs and its currently on a Phoenix 25. Just wondering if anyone had a solution.
Bigugly is offline Find More Posts by Bigugly
Old May 14, 2012, 07:31 PM
eranrc is offline
Find More Posts by eranrc
eranrc's Avatar
Joined Feb 2010
Originally Posted by santiago3d92095 View Post
and heres my new foavorite micro!!!!!its the micro DW cub with AS3X!!!! this little guy is a 3d cub!!!
http://www.youtube.com/watch?v=xGNXc...&feature=g-upl
That's is super cool brotha
That was a fun show and great flying again in that little cage!!
eranrc is offline Find More Posts by eranrc
Old May 14, 2012, 08:24 PM
santiago3d92095 is offline
Find More Posts by santiago3d92095
santiago3d92095's Avatar
Joined Apr 2011
Originally Posted by DenverJayhawk View Post
if you want to extend the servo arm on the hxt 900, what do you use?
I have been using zip-ties(big ones like the ones that come with the dw kits to glue on the under side of the fuse)and just screw them on that way I can drill a hole were I need it to get the amount of throw I want.
santiago3d92095 is offline Find More Posts by santiago3d92095
Old May 14, 2012, 08:26 PM
Joined Apr 2011
thanks man! you too!
Old May 15, 2012, 12:31 AM
DenverJayhawk is online now
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
my 40 juka with the dynamo has the same high pitched squeal as well. I think that's just how it is. It's definitely not lacking power, even here at 5300ft
DenverJayhawk is online now Find More Posts by DenverJayhawk
Old May 15, 2012, 09:13 AM
AndreasHeger is offline
Find More Posts by AndreasHeger
PA, WMPF & HE Team Pilot
AndreasHeger's Avatar
United States, OH, Amelia
Joined Apr 2008
My new DW 40" Yak 54
Here is my new DW - The new 40" Yak54 - depending on the CG position, it turns from a great tracking precision aerobatic airplane to a 3D Monster - Absolutely stunning! Night Photos will follow soon.
Blue Skies!
Andreas
AndreasHeger is offline Find More Posts by AndreasHeger
Old May 15, 2012, 10:46 AM
eranrc is offline
eranrc's Avatar
Joined Feb 2010
Blue Skies!
Andreas
beautiful pictures! Can't wait to see the night time ones :-)
Old May 15, 2012, 12:18 PM
Epoxy & CA Investor
Joined May 2010
great color scheme too. Did you do yourself?
Old May 15, 2012, 08:55 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
It's your bearings. Try pulling the clip, removing the bell and getting some lube in there. The front bearing is actually two bearings stacked up so you need to pull at least the front one to get them all lubed. Scorpion sells a special bearing lube kit and here is the page which includes instructions.
http://www.innov8tivedesigns.com/pro...84234ec268fc1e
If you don't want to buy this you can try good quality motor oil (Synthetic is best). Do not use WD 40 as this is a cutting oil and 3 in 1 is not much better.
If lubing them doesn't work, you can get new bearings from Rc Bearings:
http://www.rcbearings.com/categories/Bearings/Metric/
You'll have to measure them. These guys are great and have great service.
Or, just leave it noisy
mark_q is online now Find More Posts by mark_q
Latest blog entry: FX-61 Phantom #2 Build Pages
Old May 15, 2012, 10:12 PM
Joined Apr 2008
Thanks Eran!
Thanks Denver! - Yes - but I "borrowed" it from my 50cc AeroWorks Extra 300 I just like it too much - I created the artwork in Illustrator and had it cut out of oracal high performance vinyl - works great.
Here are some night shots with the new DW light stripes - Thanks a lot Mike!!
Old May 15, 2012, 10:53 PM
Bigugly is offline
Mesquite Tx
Ill check that out, I already have the scorpion lube, I didn't think it sounded like bearings but Ill definitely give it a shot. Thanks
Old May 16, 2012, 09:08 AM
Epoxy & CA Investor
Joined May 2010
Thanks Eran!
so what are these new light stripes? How are they powered?
Old May 16, 2012, 10:45 AM
Joined Apr 2008
Mike is going to add those to his inventory - they are powered by the receiver battery - connected with a simple inline Dean connector (no electronics). This connector has 6 outlets for the LED strips and it is for 12 Volt (3S Lipo)
Old May 16, 2012, 05:19 PM
Wehrdo is offline
Find More Posts by Wehrdo
Not failing=Not trying enough
Wehrdo's Avatar
United States, IA, Coralville
Joined Jun 2011
Those long exposure shots are absolutely stunning!
I will soon be the proud owner of the DW Foamies 38" Yak 54. I ordered it and matching components this afternoon. How long do these usually take to build? A couple evenings?
Wehrdo is offline Find More Posts by Wehrdo
Old May 16, 2012, 10:32 PM
Joined Apr 2008
Thanks a lot! - I was amazed as well how they turned out - those light strips are powerful!
The build is very easy and straight forward - it comes with a very detailed manual - just make sure you use pva (canopy glue /elmer glue) on the fuselage so it stays somewhat flexible - CA would break to easy on those stress points.
The rest of the airplane could be done with foam safe CA - usually it takes an evening or two to finish it. Perhaps a little longer for your first one - but soon you'll be a pro and finish those DW's up in no time at all
Let me know if you have any questions.
Enjoy your Foamie! - you're going to love it!
Mini-HowTo DW Foamies - Colored Packing Tape Trim Scheme rpmrpm Painting and Finishing Tips 47 Feb 24, 2013 04:35 PM
Discussion DW foamies BAF 48" yak 54 build thread appleflyer 3D Flying 50 Jul 24, 2012 03:31 PM
Discussion DW Foamies Yak Junior Build Thread NumbSkull 3D Foamies 90 Feb 01, 2012 03:25 PM
Poll DW Foamies owners thread (poll) Xpress.. 3D Flying 132 Mar 26, 2010 11:10 AM
Discussion DW (Depron West) Foamies 38" Gen-X tdriedger 3D Foamies 14 Jan 12, 2010 04:13 PM
