View Poll Results: Which DW do/have you own/owned?
DW 28" kit 62 10.49%
DW SKUA 29 4.91%
DW 38" kit 177 29.95%
DW 48" kit 156 26.40%
DW 55" kit 71 12.01%
DW Pylon Racer 9 1.52%
Never owned one 208 35.19%
Multiple Choice Poll. Voters: 591. You may not vote on this poll
Old Oct 21, 2011, 10:43 PM
twilkers is offline
Find More Posts by twilkers
twilkers's Avatar
Livermore, CA
Joined Jan 2007
paint question on foam
I have tried to use rattle cans on other types of foam, and it seemed that if enough of the propellant didn't flash off, then I ended up with some of the foam eaten away.
how does depron and epp hold up?
tim
twilkers is offline Find More Posts by twilkers
Old Oct 21, 2011, 10:58 PM
poiyt is offline
Find More Posts by poiyt
United States, GA, Newnan
Joined Aug 2010
tim
To get the stripes & shapes I want I tape mine up w/ masking tape (both thin & thick widths) and then just use usually flourescent krylon spray pain from walmart.
Hey it aint a pro job or nothin but the bright stripes & shapes really stand out outdoors (only place I fly).
I think the hexane in spray paint will eat foam; I just put on about 3 light coats (letting each coat dry thoroughly in front of a fan) and hold the can 18" or so away when spraying.
Turns out ok & haven't had any problems.
poiyt is offline Find More Posts by poiyt
Old Oct 21, 2011, 11:15 PM
madmikeyreturns is offline
Find More Posts by madmikeyreturns
United States, SC, Spartanburg
Joined Feb 2011
also some of the model car and planes spray paint will work on foam. i've used several before, but bcarefull of the floresent colors some of them can eat foam. or you can use the krylon spray cans called the fusions i think. they are said to be able to use on plastics and foam.
i use to hand paint, using brushes and the craft paint from wal-mart, i got into airbrushing not long ago and i love it. can do alot i couldn't before and the paint jobs look so much smoother. i'm working on being able to airbrush planes for guys that want their foamies painted. basically just need the wing assemblied and ailerons hinged, and the 2 fuse pieces assemblied and the rudder and elevator hinged. then i can do a cool airbrushed paint job. right now just working on the shipping back and forth. cause these bigger kits take biggr boxes than the 3mm indoor planes i've done before.
Mikey
madmikeyreturns is offline Find More Posts by madmikeyreturns
Old Oct 22, 2011, 01:13 AM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
tim
yep, i learned this the hard way the first time i tried it. The depron was killed by the spray paint. Make sure the paint can nozzle is held 1-2 feet away from the foam when painting and do several very light coats and you'll be fine.
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Oct 22, 2011, 09:31 AM
poiyt is offline
Joined Aug 2010
There are entire sheets of depron, just waiting for me to apply my artistry
What's a good beginner airbrush kit?
How bout this?
http://www.towerhobbies.com/products...hcar4012m.html
Old Oct 22, 2011, 09:34 AM
Epoxy & CA Investor
Joined May 2010
it takes me so long to do a build that I don't have time for a lengthy, detailed, self done paint job. I might pay someone else to do it for me though.
Old Oct 22, 2011, 10:01 AM
poiyt is offline
Joined Aug 2010
I just can't believe there's not a market for that...a pre-painted DW foamie would definately be something I'd be interested in....even if it was "pick from these three designs"
Old Oct 22, 2011, 10:23 AM
Tubbster85 is offline
Find More Posts by Tubbster85
United States, WA, Port Orchard
Joined Oct 2011
Batteries
I have been pricing out batteries for my 40" Extra, has anyone used the Gens Ace or the Blue Sky batteries from hobbypartz for their DW Foamie? I use them on my SC truck and they are great.
Tubbster85 is offline Find More Posts by Tubbster85
Old Oct 22, 2011, 10:29 AM
Chris Arena is offline
Find More Posts by Chris Arena
oldguy
Gig Harbor, WA.
Joined Jul 2010
I have had good luck with the Turniqy "Nano Paks" from HobbyKing. High output, reliable and cheap.
Chris Arena is offline Find More Posts by Chris Arena
Old Oct 22, 2011, 10:42 AM
Joined Oct 2011
What size of battery do you get from them? I was thinking of the 1300mah for my foamie with the dynamo combo.
Old Oct 22, 2011, 11:08 AM
Epoxy & CA Investor
Joined May 2010
i use 1000 and 1300 3S 30c Gforce lipos from valuehobby. They come with deans pre soldered, so almost a plug and play. That, and they are cheap batteries shipped from the US.
Old Oct 22, 2011, 11:16 AM
twilkers is offline
twilkers's Avatar
Livermore, CA
Joined Jan 2007
I just bought the 1300 nano tech from HK. I was eyeing up the blue sky, but went with nano tech as I'm still flying them. 4S2500 in 51 slick, 50 cycles each. it does take 45 min to charge though.
I did buy the cobra for the 40" extra DW foamie.
Old Oct 22, 2011, 11:33 AM
Bugbitten is offline
Find More Posts by Bugbitten
United States, KY, Madisonville
Joined Mar 2011
Charge rate?
Bugbitten is offline Find More Posts by Bugbitten
Old Oct 22, 2011, 03:10 PM
oldguy
Gig Harbor, WA.
Joined Jul 2010
I am running a variety of high output batteries from 900 to 1150 MAH. Flying for 6 minutes at a variety some floating around then some verticals, fast passes, etc with at least a minute left over on the 1150's. Keeps weight light and verticals have some punch due to the lighter weight.
Old Oct 22, 2011, 05:18 PM
twilkers is offline
twilkers's Avatar
Livermore, CA
Joined Jan 2007
Originally Posted by Bugbitten View Post
Charge rate?
3S1300 30C $9.87 each
Mini-HowTo DW Foamies - Colored Packing Tape Trim Scheme rpmrpm Painting and Finishing Tips 47 Feb 24, 2013 05:35 PM
Discussion DW foamies BAF 48" yak 54 build thread appleflyer 3D Flying 50 Jul 24, 2012 04:31 PM
Discussion DW Foamies Yak Junior Build Thread NumbSkull 3D Foamies 90 Feb 01, 2012 04:25 PM
Poll DW Foamies owners thread (poll) Xpress.. 3D Flying 132 Mar 26, 2010 12:10 PM
Discussion DW (Depron West) Foamies 38" Gen-X tdriedger 3D Foamies 14 Jan 12, 2010 05:13 PM
