View Poll Results: Which DW do/have you own/owned?
DW 28" kit 62 10.49%
DW SKUA 29 4.91%
DW 38" kit 177 29.95%
DW 48" kit 156 26.40%
DW 55" kit 71 12.01%
DW Pylon Racer 9 1.52%
Never owned one 208 35.19%
Multiple Choice Poll. Voters: 591. You may not vote on this poll
Old Oct 02, 2011, 11:39 AM
SpartanExec is offline
Find More Posts by SpartanExec
Extreme Flight Minion
SpartanExec's Avatar
United States, OR, Happy Valley
Joined Nov 2010
Very sorry to hear about your Wife rcnxs, flying has been my therapy and is always good to get the mind off the troubles of life. I had a lot of wing rock on my 40" Juka and finally figured out that I had the ailerons both trimmed down a little so they were acting like flaps, put a little reflex in them, (both going up from straight on the wing) and took all the wing rock away and was rock solid from then on. I would try that with a neutral CG and see how that works.
Sam
SpartanExec is offline Find More Posts by SpartanExec
Old Oct 02, 2011, 01:10 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
It's not just about CG in one direction (axis)! (there are actually 3)
The one balance parameter often missed and critical on super light foamies is lateral. With all the controls centered and battery installed, set the plane on the ground, put a straight edge under the prop shaft and lift the nose up. The plane should balance sided to side, if it doesn't, this will affect wing rock, knife edge, harrier, etc. because both the airframe and the pilot are constantly battling the force this creates.
Give it a try!
rcnsx - very sorry to hear about your wife, please accept my condolences.
mark_q
mark_q is online now Find More Posts by mark_q
Latest blog entry: FX-61 Phantom #2 Build Pages
Old Oct 04, 2011, 11:24 AM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
United States, CO, Denver
Joined May 2010
really sorry about your wife, rcnsx. Keep flying, it's therapeutic.
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Oct 04, 2011, 01:36 PM
madmikeyreturns is offline
Find More Posts by madmikeyreturns
United States, SC, Spartanburg
Joined Feb 2011
Hey Guys, here's a little teaser. this is the wing of my new project i'm working on. it's the new version of the 40" Extra 300L. what makes it new is there is no longer any 6mm foam, it's all 9mm foam!!! this was my first time airbrushing lighting bolts and i feel they came out pretty good formy first time!!
i have a build thread on here and you can follow the building of the plane from start t finish.
Keep Your Dw's in the Air!!
Mikey
madmikeyreturns is offline Find More Posts by madmikeyreturns
Old Oct 05, 2011, 01:46 PM
RedStarArmy is offline
Find More Posts by RedStarArmy
RedStarArmy's Avatar
United States, NJ, Middlesex
Joined Feb 2008
New motor
I'm moving over the dynamo motor/esc over to a new DW foamie. I want to buy a cheap motor/esc to put in the old one. Its the 40" Yak Fusion. Would this motor be appropriate? http://www.hobbyking.com/hobbyking/s...ess_Motor.html
Is there another one that would be better suited from HK?
RedStarArmy is offline Find More Posts by RedStarArmy
Old Oct 05, 2011, 03:37 PM
FlopGun is offline
Find More Posts by FlopGun
You brought two too many.
FlopGun's Avatar
United States, WA, Seattle
Joined Jul 2007
I don't think you'll be happy with that one, not enough power. It's only 52 grams.
I would be looking for something from 65-90 grams. The Dynamo is 72 grams.
This one I've used on a 10x6 and is pretty good but out of stock.
http://www.hobbyking.com/hobbyking/s...idproduct=5112
There's always another Dynamo.
FlopGun is offline Find More Posts by FlopGun
Old Oct 05, 2011, 04:26 PM
blueapplepaste is offline
Find More Posts by blueapplepaste
blueapplepaste's Avatar
United States, TX, Keller
Joined Jul 2009
Another option: http://www.hobbyking.com/hobbyking/s...r%5FMotor.html
blueapplepaste is offline Find More Posts by blueapplepaste
Old Oct 05, 2011, 05:14 PM
Joined Feb 2008
I've never really picked out a motor before. How does weight of the motor factor in? I thought it was about the watts and kv and which props the motor is made for? From what I've read, the 40" need about 200 watts no?
Old Oct 05, 2011, 05:35 PM
FlopGun is offline
FlopGun's Avatar
Joined Jul 2007
I am not that knowledgeable about motors and haven't tried that many in the 40.
I don't pay much attention to the published watt numbers. I look at kv and weight. Depending on kv I will try out props. 10x4.7 11x4.7 or 10x6 are good to try, and kv from 900-1100. Just make sure things aren't getting too hot. Or try what others recommend.
Mark Q or others can maybe chime in, Mark takes measurements on his motors.
Old Oct 05, 2011, 08:27 PM
Joined Feb 2008
Ok, will stay tuned for a few more opinions before I choose a motor.
Old Oct 05, 2011, 09:46 PM
killsdeer4fun is offline
Find More Posts by killsdeer4fun
With great pwer comes great 3D
killsdeer4fun's Avatar
Globe, USA, Clemson, SC
Joined Jun 2010
Check out hobbypartz for motors. They are in the US and you will get better shipping and probably customer service from them. I have the motor below on my 40" Juka and it has some serious speed on the park zone T-28 prop, as well as a nice punch on the low end. Its a pretty perfect match as far as I'm concerned for a 40" DW. It will hover just below half throttle on a fresh 1350mah 3S pack that I run which is kind of old.
http://www.hobbypartz.com/alpha-480-...ess-motor.html
killsdeer4fun is offline Find More Posts by killsdeer4fun
Old Oct 06, 2011, 08:22 AM
Joined Feb 2008
I'm really looking for a motor from hk as I have to order from there anyways. Thanks for the suggestion though
Old Oct 06, 2011, 10:03 AM
Low_N_Slow is offline
Find More Posts by Low_N_Slow
The Yak Daddy
Low_N_Slow's Avatar
United States, TX, Liberty Hill
Joined Sep 2008
Hey guys! I'm trying to select my 1st DW Foamy. I tried to e-mail DW through the website & haven't heard back after a couple of days...so I thought I would try here.
I primarily fly GS gas and usually fly a good mix of low & slow 3D and precision "stuff". I am looking for something to play around with in the back yard, so floaty super low & close3D, slow HAKE, tight radius rolling harriers, etc. is what I'm looking for.
I have a Hacker A20-20l, CC Thunderbird 18 ESC, plenty of the tiny blue servos (both hitec & HK) and a pile of 3S 1000mah 20C & 3S 1350mah 15C packs. I really want something that can use my existing gear. I'm retiring my 3rd Charger RC foamy, all of which have served me very well...but I keep hearing great things about DW and want to give one a shot.
I'm a "Yak-a-holic", so naturally my 1st choice would be a Yak 55...but I read SO MUCH good stuff about the Juka, that I would definitely consider that as well. My main concern is selecting the right size plane for my gear & making sure that I am getting best performing foamy I can.
Any help and/or suggestions would be appreciated!
-Jeff
Low_N_Slow is offline Find More Posts by Low_N_Slow
Old Oct 06, 2011, 10:25 AM
Bugbitten is offline
Find More Posts by Bugbitten
United States, KY, Madisonville
Joined Mar 2011
Mike is good about returning info , but if he is away, it may take a few. I called him and got good advice.
Bugbitten is offline Find More Posts by Bugbitten
Old Oct 06, 2011, 10:54 AM
The Yak Daddy
Low_N_Slow's Avatar
Joined Sep 2008
Thanks for that. I have not tried calling, but I will if I don't hear back in a few more days. I am really interested in hearing you guys' opinions on the perfect DW match for my gear.
BTW - I'm really liking the 9mm 40" Yak 55. Just not sure if I have enough motor???
Mini-HowTo DW Foamies - Colored Packing Tape Trim Scheme rpmrpm Painting and Finishing Tips 47 Feb 24, 2013 04:35 PM
Discussion DW foamies BAF 48" yak 54 build thread appleflyer 3D Flying 50 Jul 24, 2012 03:31 PM
Discussion DW Foamies Yak Junior Build Thread NumbSkull 3D Foamies 90 Feb 01, 2012 03:25 PM
Poll DW Foamies owners thread (poll) Xpress.. 3D Flying 132 Mar 26, 2010 11:10 AM
Discussion DW (Depron West) Foamies 38" Gen-X tdriedger 3D Foamies 14 Jan 12, 2010 04:13 PM
