View Poll Results: Which DW do/have you own/owned?
DW 28" kit 62 10.49%
DW SKUA 29 4.91%
DW 38" kit 177 29.95%
DW 48" kit 156 26.40%
DW 55" kit 71 12.01%
DW Pylon Racer 9 1.52%
Never owned one 208 35.19%
Multiple Choice Poll. Voters: 591. You may not vote on this poll
Old Sep 12, 2011, 11:46 AM
FlopGun is offline
Find More Posts by FlopGun
You brought two too many.
FlopGun's Avatar
United States, WA, Seattle
Joined Jul 2007
The 2650 on 4S should be fine and the 50amp on the 55. You will want to use a BEC or an ESC with a switched BEC.
I am using JR-DS3421 servos, but if I had to buy some for the 55, I'd get Hitec HS-225mgs. Good bang for buck. You could probably get away with HS-85MGs but might get some blowback.
And no doubt if the Dude did RC he'd fly a DW foamy.
FlopGun is offline Find More Posts by FlopGun
Old Sep 12, 2011, 11:51 AM
poiyt is offline
Find More Posts by poiyt
United States, GA, Newnan
Joined Aug 2010
Copy that. 'Blowback' on 85mg's??
poiyt is offline Find More Posts by poiyt
Old Sep 12, 2011, 11:56 AM
killsdeer4fun is offline
Find More Posts by killsdeer4fun
With great pwer comes great 3D
killsdeer4fun's Avatar
Globe, USA, Clemson, SC
Joined Jun 2010
When the servo isn't strong enough to hold the control surface. Think of a fast roll and when you let off the sticks it the plane will bounce back. Its kind of like momentary flutter.
killsdeer4fun is offline Find More Posts by killsdeer4fun
Old Sep 12, 2011, 12:00 PM
SpartanExec is offline
Find More Posts by SpartanExec
Extreme Flight Minion
SpartanExec's Avatar
United States, OR, Happy Valley
Joined Nov 2010
The Dude abides with DW foamies, man.
SpartanExec is offline Find More Posts by SpartanExec
Old Sep 12, 2011, 12:18 PM
poiyt is offline
Joined Aug 2010
'Rubber-band effect', eh??
From what I can see on Mike's site, HS82 is the strongest micro-class (not mini-class) that he offers:
HS82 39oz 12sec 19gr (micro)
HS225 54oz 14sec 27gr (mini)
Obviously, the 255 is far stronger...maybe I missed something on the site?
Not debating here, but just trying to learn planks (having come over from the heli side)...eg, I run 82MG's on my Carbon Yak w/ 45-deg throws going into a blender at 70+mph... and the 82's seem to do the job on ths model...?
Old Sep 12, 2011, 12:37 PM
ClydeJames86 is offline
Find More Posts by ClydeJames86
keepin it real since 1986
ClydeJames86's Avatar
slidell, louisiana
Joined Feb 2009
Stfu donnie
ClydeJames86 is offline Find More Posts by ClydeJames86
Old Sep 12, 2011, 12:39 PM
poiyt is offline
Joined Aug 2010
I'm going to run a pair of 2S 2500 in series for 4S 2500, one on each side. The reason is to keep balance on the plane.
Hey Flop I missed this part....
I could get some 2S/2200's in series...and here's the best part: two 2200's combined weight less than a single 4S/2650:
2S/2200 135gr ea
4S/2650 292gr ea
Props to u bud for the great idea....gotta look further into that
Old Sep 13, 2011, 11:41 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
SonicElectric 2820-1080 Motor Update!
Ok, so the Juka singing got so loud I had to wear ear protection to fly! I decided to try a motor from HobbyPartz so I ordered a Rocket 2220-1050 to replace the Sonic 2820-1080 (actually it too is a 2220 size). Unfortunately, this was an $18 disappointment. On my bench tester the Sonic would make 52oz of thrust @ 10600RPM on a 3 cell and this new motor would only produce 32oz @ 8600RPM. It also does not accelerate nearly as quickly. Bummer.
So, I cut a new motor shaft for the Sonic out of 4mm drill rod and replaced the stock shaft. Awesome! No more bell wobble and it runs much quieter with all the original power. The problem with the stock shaft is there is a flat cut for the set screw in the bell to lock into and this flat is cut so deep there is not enough shaft to fully support the bell.
Next I'll put a dozen packs through her and see how this fix holds up.
mark_q is online now Find More Posts by mark_q
Latest blog entry: FX-61 Phantom #2 Build Pages
Old Sep 18, 2011, 04:26 PM
DenverJayhawk is online now
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
put 8 packs through the 40 Juka today. I enjoy this model more and more each time i fly it. It's one of the cheapest models I own but probably my all around favorite.
So if the 40" is this good, is the 48" even better?
DenverJayhawk is online now Find More Posts by DenverJayhawk
Old Sep 18, 2011, 09:37 PM
Joined Jun 2010
Maybe. I put 3 packs through mine yesterday in some stiff wind and it was still amazing. The roll rate is ballistic which is awesome.
Old Sep 19, 2011, 05:17 AM
regalmat is offline
Find More Posts by regalmat
regalmat's Avatar
Ashburn VA
Joined Feb 2010
I have a 40 Juka to build up. What batteries are you using and did you have any trouble getting the CG where you wanted it?
regalmat is offline Find More Posts by regalmat
Old Sep 19, 2011, 08:32 AM
Epoxy & CA Investor
Joined May 2010
i'm using valuehobby gforce 1000 an 1300s. No trouble at all getting CG to balance. It seems very tolerant to CG changes. I'm balanced right at the wing spar.
Old Sep 19, 2011, 09:21 AM
poiyt is offline
Joined Aug 2010
Imo, absolutely. I started w/ a 40 Juka, loved it, then got a 48" Juka (dymamo power) and loved it even more. Had the landing gear on both.
To me, bigger is definately better and the 48" is the perfect blend of power, size, & performance.
Old Sep 19, 2011, 10:14 AM
Joined Jun 2010
I use 1350 3S on my 40" Juka and fly hard for 6 mins and still have some left in the battery.
Old Sep 19, 2011, 10:34 AM
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
On the 40" Juka
1000mah Blue Lipos, CG is 1/4" (6mm) behind the spar.
Mini-HowTo DW Foamies - Colored Packing Tape Trim Scheme rpmrpm Painting and Finishing Tips 47 Feb 24, 2013 04:35 PM
Discussion DW foamies BAF 48" yak 54 build thread appleflyer 3D Flying 50 Jul 24, 2012 03:31 PM
Discussion DW Foamies Yak Junior Build Thread NumbSkull 3D Foamies 90 Feb 01, 2012 03:25 PM
Poll DW Foamies owners thread (poll) Xpress.. 3D Flying 132 Mar 26, 2010 11:10 AM
Discussion DW (Depron West) Foamies 38" Gen-X tdriedger 3D Foamies 14 Jan 12, 2010 04:13 PM
