View Poll Results: Which DW do/have you own/owned?
DW 28" kit 62 10.49%
DW SKUA 29 4.91%
DW 38" kit 177 29.95%
DW 48" kit 156 26.40%
DW 55" kit 71 12.01%
DW Pylon Racer 9 1.52%
Never owned one 208 35.19%
Multiple Choice Poll. Voters: 591. You may not vote on this poll
Old Mar 20, 2011, 07:33 PM
mikeruth is offline
Find More Posts by mikeruth
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
Originally Posted by sodbuster 1 View Post
anybody on the landing gear questions?
Really appreciate some input
Here's a pic from a stock build.
http://www.rcgroups.com/forums/attac...mentid=2541840
Which is in this thread http://www.rcgroups.com/forums/showt...ng+gear&page=4
As for performance your adding some weight which will have some small effect on the wing loading. If you need the gear, don;t worry about the performance hit. It's minor.
MIke R
mikeruth is offline Find More Posts by mikeruth
Old Mar 20, 2011, 07:35 PM
mikeruth is offline
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
Originally Posted by regalmat View Post
I will try and post pics. Is there an easy way to separate the keel from the wing?
Depends on the glue used, but in essence...NO
If you have to I'd try cutting it so the reglue is easier to do.
MIke R
Old Mar 20, 2011, 07:36 PM
michaelJH is offline
Find More Posts by michaelJH
Team Extreme!
michaelJH's Avatar
Wa, state
Joined Oct 2009
Sodbusted, you will definantly notice the gear and personally, I am not a fan of them. You will have a bit more coupling in KE and it won't roll quite as axle. Some guys like them, but the answer is yes, they will affect it.
As for the mounting, the plastic piece should be sort of a triangle shape. The wide end should go twords the wing. Make sure that both the plates, (on the right, and left of the foam) and aligned correctly and then punch a hole for the zip ties. You will glue the plastic pieces to the foam and then put the landing gear legsbetween the line of holes for the zip ties. Now you can put the zip ties through the first hole and out the other side, over the gear leg, and in and out the other side and then close the zip tie over the other leg. I no longer have the plane I put them on so I cannot tell you exactly, but this is what I remmember. I hope it helps.
michaelJH is offline Find More Posts by michaelJH
Team Extreme!
michaelJH's Avatar
Wa, state
Joined Oct 2009
Beat me to it Mike!
Old Mar 20, 2011, 07:38 PM
mikeruth is offline
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
I love building these DW kits
Working on the GenX Horizonatal stab is done, hinging is done and taping is done, all amongist almost 3 inches of rain in 4 hours. Had to stop and setup a bilge pump for the garage
got most of the taping done, about ready for final airframe assembly now
Mike R
Old Mar 22, 2011, 09:34 AM
RedStarArmy is offline
Find More Posts by RedStarArmy
RedStarArmy's Avatar
United States, NJ, Middlesex
Joined Feb 2008
When I put together my Yak Fusion, I accidentally used the larger carbon rods for the supports, and the smaller ones as push rods. It was only after I finished that I realized it should have been the other way around. Well because of that I think my rudder and elevator rods are flexing a bit too much so I wanted to replace them. I don't have the manual on me currently, can someone tell me the size of the larger carbon rod used in the Yak Fusion kit?
RedStarArmy is offline Find More Posts by RedStarArmy
Old Mar 22, 2011, 10:28 AM
Team Extreme!
michaelJH's Avatar
Wa, state
Joined Oct 2009
IDK exactly what he uses on that kit, but probably 1/1.5 mm for the bracing and 2mm for pushrods. As long as 2mm will fit into your easy connector, I'd go with that.
Old Mar 22, 2011, 10:30 AM
mikeruth is offline
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
48" GenX
final airframe assembly is complete and WOW, I'm liking this one a ton.
Airframe glued up, control horns on and firewall ready for a motor
Pictures to follow soon.
Mike R
Old Mar 22, 2011, 12:47 PM
Team Extreme!
michaelJH's Avatar
Wa, state
Joined Oct 2009
I just started a 28" Juka as well as a dEEPron fusion su-29 and regular 40" yak 55. The two 40"ers I will be taking to SEFF. The hardest thing for me, is to decide what to paint them. Any idea's for the Juka? I would like it to be light wieght and a bright coler that reflects light well, being that it will be a night flyer.
Old Mar 22, 2011, 01:14 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Grab a couple of small zip ties and wrap them around the carbon pushrods about halfway inbetween, then push the long section of zip tie through the foam to act as a pushrod keeper. Drop a small bit of CA over it to keep it in the foam, then snip off the excess on the other side.
Xpress.. is offline Find More Posts by Xpress..
Old Mar 22, 2011, 01:44 PM
Joined Feb 2008
Actually I received a PM from Mike himself saying to email him for a couple of push rods that he actually already sent out to me! I've heard great stories of him and his company, but this is just excellent! Way to go DWFoamie!
Old Mar 23, 2011, 03:29 AM
Coonak is offline
Find More Posts by Coonak
pǝʇɹǝʌuı
Coonak's Avatar
Perth, Western Australia
Joined Aug 2006
Hi Sodbuster,
I used Dubro Micro L/G on my 48" Juka.
http://shop.dubro.com/products/produ...2.0.0.0?pp=12&
It worked well, however I added a rubber band to stop the legs 'splaying' apart and allowing the prop to mow the grass!
These are the only pics I could find of it.
Cheers
Mick
Coonak is offline Find More Posts by Coonak
Old Mar 23, 2011, 05:35 AM
sodbuster 1 is offline
Find More Posts by sodbuster 1
Jersey City,NJ
Joined Feb 2008
Mick,
Are those lighter than the DW Foamy gear?
sodbuster 1 is offline Find More Posts by sodbuster 1
Old Mar 23, 2011, 09:44 AM
Coonak is offline
pǝʇɹǝʌuı
Coonak's Avatar
Joined Aug 2006
Weight including hardware: 34.0 grams
Not sure what the DW kit weighs.
Old Mar 23, 2011, 02:22 PM
FlopGun is offline
Find More Posts by FlopGun
You brought two too many.
FlopGun's Avatar
United States, WA, Seattle
Joined Jul 2007
That gear looks nice on the 48". Michael, after experimenting with paint jobs I like red on top and blue stripes on bottom, I can see the model very well like that.
I think it helps to have some solid colors in some pattern on both top and bottom. If the color is too light (say yellow), the sun can shine through and you will see bottom and who knows what happens next lol. The same could be said for those bright lights you use.
I use water-thinned acrylics with a foam brush, usually two coats. It's easy and adds very little weight.
FlopGun is offline Find More Posts by FlopGun
Mini-HowTo DW Foamies - Colored Packing Tape Trim Scheme rpmrpm Painting and Finishing Tips 47 Feb 24, 2013 04:35 PM
Discussion DW foamies BAF 48" yak 54 build thread appleflyer 3D Flying 50 Jul 24, 2012 03:31 PM
Discussion DW Foamies Yak Junior Build Thread NumbSkull 3D Foamies 90 Feb 01, 2012 03:25 PM
Poll DW Foamies owners thread (poll) Xpress.. 3D Flying 132 Mar 26, 2010 11:10 AM
Discussion DW (Depron West) Foamies 38" Gen-X tdriedger 3D Foamies 14 Jan 12, 2010 04:13 PM
