Redstar, I would definitely get the thrust angle fixed, a washer should work fine.
As far as CG goes I really think the Yak it should be in front of the spar. Even blueapple, I would try it up there and trim her and see how she flies. I have mine up 1/4 inch in front and I think Michael Holman's latest DW he's got it 3/4 in front. |
And as best as I can tell, my thrust lines look good - so I don't think motor is pulling it down. |
Taft, also check your ailerons,make sure they are level with the wing. If level with the wing the top edge of the aileron should line up with the bottom edge of the fuselage. Having a bit of up or down can cause the nose to pitch inverted or on knife edge. This can also affect your tail trim. All parts of each wing surface works together having the rudder slightly askew or a slight twist in the fuse can also cause pitch and roll coupling.Small adjustments make big changes on a 3d foamy. I normally spend a good amount of time making sure everything is true. And after a few months or if I don't fly the plane for 5or6weeks I will re-true it,because foam can distort over time ,or how it's stored.
USA, CA, Encinitas
Joined Jun 2009
You should be able to burn off the insulation with a good hot soldering iron with a large drop of solder on the tip. Just put the end of the wire into the liquid solder and the coating should burn off. At least this works with magnet wire I have used in the passed.
Mark Quote:
Joined Aug 2010
Cheers |
i got so pissed off about it, because the scorpion is such a good motor...but a new one is $50. the motor is fine, just can't get solder to stick to the wires. so i ordered the 1000kv dynamo motor from dw. about half the price of the scorpion, and it seems to pull just as good. i haven't flown it yet, but bench tests are promising. if anyone wants a scorpion 2215-18 pm me lol. |
Bad day at the Basin...
Beautiful morning at the Sepulveda Basin yesterday, sun shining, air dead calm! My kinda weather for kicking around with my 48" Yak54.
I got in probably 5 flights and getting ready to head out to the ranch. At the Basin there are 55 gallon trash cans along the pits. Quite frequently I place my plane upside down on the can to pull the battery, even leave it there for periods of time. No big deal in many years. Always have three or more freinds at that table and have a good ol' time. I walked off to talk with someone for a time, have no idea how long but another flyer/friend comes up and says "hey what happend to your Yak?" I'm like what? I saw it the trash can and another guy is pulling the Electroncs I'm like ![]() I go down and start verbaly pounding on this guy and he's like whoa I'm just pulling this stuff I didn't touch the plane, looking around I see the park service guys that pick up the trash and stop them. After much foul verbage I find that a punk kid picking up the trash decides my plane is trash and rips it appart I appoloigized to the first guy as he wasn't doing anything wrong and I got the name of the bozo that made the decision to call my plane trash. I'll send the city a bill, but man what a way to end the day at the basin. Had a good time at the ranch, 1:20hr flight on my Cularis with get this another heart starter, lost visual at roughly 2000' for at least 30 seconds if not more..fortunetly I had the calmness to walk over 30 yards and ask another person to scan the sky for my plane. after what seemed like another excruciating 30 seconds or so it was found, with the nerves a bit rattled I called it a day. Be ordering another 48" Yak this monirng. I cannot survive without one ![]() Mike R |
| Thread Tools | |
| Mini-HowTo DW Foamies - Colored Packing Tape Trim Scheme | rpmrpm | Painting and Finishing Tips | 47 | Feb 24, 2013 04:35 PM |
| Discussion DW foamies BAF 48" yak 54 build thread | appleflyer | 3D Flying | 50 | Jul 24, 2012 03:31 PM |
| Discussion DW Foamies Yak Junior Build Thread | NumbSkull | 3D Foamies | 90 | Feb 01, 2012 03:25 PM |
| Poll DW Foamies owners thread (poll) | Xpress.. | 3D Flying | 132 | Mar 26, 2010 11:10 AM |
| Discussion DW (Depron West) Foamies 38" Gen-X | tdriedger | 3D Foamies | 14 | Jan 12, 2010 04:13 PM |
