View Poll Results: Which DW do/have you own/owned?
DW 28" kit 62 10.49%
DW SKUA 29 4.91%
DW 38" kit 177 29.95%
DW 48" kit 156 26.40%
DW 55" kit 71 12.01%
DW Pylon Racer 9 1.52%
Never owned one 208 35.19%
Multiple Choice Poll. Voters: 591. You may not vote on this poll
Old Feb 08, 2010, 11:02 AM
mikeruth is offline
Find More Posts by mikeruth
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
Hmmm, hope this is not a duplicate....
Need some advice...I'm loving the 48" Yak but....
I mounted a Eflight 480-910KV motor and run a 2200 30C pack, that I know deleivers the goods!
Now in a hover @ about 60% throtle and stationary if I go WOT it bearly pulls it's self out. I treid everything from a 10 X 3.8 to a 12 X 3.8 SF APC props.
Now get this, nothing and I mean nothing gets even warm! Motor, ESC and battery.
Soooo am I under propped here? 13"? I find this strange.
Just considering Mike's Scorpion motor, the 3014-1040 yet it is 1.5 oz's heavier than the e flight 480.
Thanks.
mikeruth is offline Find More Posts by mikeruth
Old Feb 08, 2010, 11:11 AM
Jhondra is offline
Find More Posts by Jhondra
KF7JBN
Jhondra's Avatar
United States, ID, Nampa
Joined Nov 2008
Thanks.
Hum...seems strange that it would hover at 60% and not pull out WOT. But that motor is certainly only rated for anything over 30oz for 3D. Certainly not the 48". Do you have a wattmeter you can check it on? Either way, at that kv rating, I would recommend going to at least a 12x6 and maybe even try a 13x4. How does an 11x5.5 work on it?
Jhondra is offline Find More Posts by Jhondra
Old Feb 08, 2010, 11:50 AM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
A 12x6 sounds like what you should be spinning on there. I'd try a 12x6 and a 12x8 prop to see what power it delivers
Xpress.. is offline Find More Posts by Xpress..
Old Feb 08, 2010, 12:35 PM
mikeruth is offline
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
Thanks for the replies and tips,. I'll run a watt meter test on a few props later today and post the results.
Old Feb 08, 2010, 06:41 PM
J.Douglas is offline
Find More Posts by J.Douglas
Old Skool
J.Douglas's Avatar
Joined Dec 2003
I had my 48" Extra 330 out last weekend, what a great foamie. I have a power 10 on that I had laying around and a 12x6 apc running 2200's.
I got some video with my hat cam not the best as it was the maiden so I was not down low. But not bad for the maiden. I put more throw in the aileron's cant wait to get it out and ring it out.
JD
BAF_0001.wmv (5 min 43 sec)
J.Douglas is offline Find More Posts by J.Douglas
Old Feb 08, 2010, 08:45 PM
Jhondra is offline
KF7JBN
Jhondra's Avatar
Joined Nov 2008
JD
http://www.youtube.com/watch?v=BPoLxkVncwg
Nice video, JD. I despise you folks that taxi out, throttle up, and snap roll on the take off for a maiden flight.
Seriously, nice flying though. I'd be embarassed to show you guys my maidens. Normally, the first 60 seconds are me clicking trims at least a couple tics getting it to fly straight and level.
Old Feb 08, 2010, 10:31 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
JD
Looks like you need a tail skid. Just take the end of one of those heavy duty zip ties, cut a slot slightly thinner than the skid, and make it about 2" deep about 1" in front of the rudder, then cut about 4" off the end of the zip tie, and stick it in. You can glue it in if you want using either medium foam safe CA (no kicker) or a dab of epoxy on both sides, then slide it in
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
We profilers call it a "Yak-off"
Old Feb 08, 2010, 10:35 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
Yah I need a better skid then what I have I'll try that thanks.
Old Feb 08, 2010, 10:37 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
I like to do it as soon as I have wing clearance
Old Feb 13, 2010, 10:54 PM
mikeruth is offline
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
Well guys here's my verdict on a Eflight Park 480-920KV motor on 3C 2200 30C packs. for the 48" YAK
DON'T
Ok seriously, I am not crazy about the setup , yet is doable if that's all ya got.
I went with a 12 X 6E APC prop today and found that it would pull it out OK but that is seriously over taxing this motor. Static it pulls 29 amps and the motor is only rated for 20 Amps continuios. I did fly it that way a couple times using some seriuos throtle management, but the motor still comes down to hot.
So I picked up a Scorpion 3014-1040 V2 and just mounted it. Need to go out and do some bench test but....I need to adapt to the extra 1.7 Oz Had my CG spot on the 1/4" behind spar and liked it. At least for now.
I'll post my static numbers in a little bit here.
Old Feb 13, 2010, 11:13 PM
mikeruth is offline
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
Well now, with the Scorpion 3014-1040 KV run by a Phoenix 35 Amp esc and a 11 X 4.7 prop were pulling down about 42 Amps and over 400 Watts.
Didn;t even get all the numbers on the 12 X 6E as the Wattage was over 600 and I knew the ESC was thinking about showing me some magic smoke!
Looks like I may have to go up on the ESC here.
Old Feb 13, 2010, 11:15 PM
mikeruth is offline
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
Just took a look at Mike's package on the web site, same motor and a 35 esc, so what prop are u guys running on this setup?
Are my batteries just plain giving me to much? LMAO. Such a problem to have, haha
Old Feb 13, 2010, 11:16 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
You might want to go with an 11x8E prop. It should give similar thrust results, but draw less amps because the blade isn't as wide as the SF ones
Old Feb 13, 2010, 11:38 PM
mikeruth is offline
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
Xpress thanks for the tip. I have just about evey prop I need and then some but no E props on hand. I'll pick a few up.
Just did some wing loading numbers and set the CG.
Mike specs this plane with 644 Sq in and a weight of 28 to 32 oz.
With that said the lightest wing loading is 5.8 and the heaviest of 6.6. (rounded of a tad)
Well with the 3014 mounted and Turnigy 2200 3C I'm at 33.5 Oz's
Which puts me at 7.47 (DAMN)
So I am out fiited with the above mention motor and battery, HS 65 HB servos
and a 6110E receiver and the shortest extensions I could get on.
Don;t see how I could have trimmed the fat any more.
Test flights tomorrow with this new setup, I'm sure it is gonna pull hard but little concerned about how floaty it will be in comparison to my 30oz setup.
Mini-HowTo DW Foamies - Colored Packing Tape Trim Scheme rpmrpm Painting and Finishing Tips 47 Feb 24, 2013 04:35 PM
Discussion DW foamies BAF 48" yak 54 build thread appleflyer 3D Flying 50 Jul 24, 2012 03:31 PM
Discussion DW Foamies Yak Junior Build Thread NumbSkull 3D Foamies 90 Feb 01, 2012 03:25 PM
Poll DW Foamies owners thread (poll) Xpress.. 3D Flying 132 Mar 26, 2010 11:10 AM
Discussion DW (Depron West) Foamies 38" Gen-X tdriedger 3D Foamies 14 Jan 12, 2010 04:13 PM
