View Poll Results: Which DW do/have you own/owned?
DW 28" kit 62 10.49%
DW SKUA 29 4.91%
DW 38" kit 177 29.95%
DW 48" kit 156 26.40%
DW 55" kit 71 12.01%
DW Pylon Racer 9 1.52%
Never owned one 208 35.19%
Multiple Choice Poll. Voters: 591. You may not vote on this poll
Old Sep 29, 2010, 11:07 PM
FlopGun is offline
Find More Posts by FlopGun
You brought two too many.
FlopGun's Avatar
United States, WA, Seattle
Joined Jul 2007
That's about what I get.
I like to keep them down at 17 oz or lighter, but it depends on your style. I just re-weighed my Yak55 and Juka. The lighter you can get them the slower and easier they are going to 3D.
With 1000mah 88 gram lipo *and* gear
Juka 16.9 oz
Yak 55 15.75 oz
FlopGun is offline Find More Posts by FlopGun
Old Sep 29, 2010, 11:19 PM
Xpress.. is online now
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
My yak 55 is light at 15.4oz. So, to me, a 19oz bird is like a flying brick, by comparison
Xpress.. is online now Find More Posts by Xpress..
Old Sep 30, 2010, 05:20 AM
Ekir is online now
Find More Posts by Ekir
United States, FL, Boynton Beach
Joined Jul 2007
My weight was with a Digital Postage Scale, so it should be right on. My weight is what it is, now how much I can remove is ?????
You should never have to add weight to get a foamy to balance. Was the weight added to get it to "balance neutral" per spec CG or "balance neutral" in flight.
Yes, it was balanced for "Balance neutral in Flight".
Guessing it is a battery is a good bet, but. My answer to all these questions is always the same. Get it on a Watt meter and see what the system is actually doing.
150 Watts
Ok guys, this is what I can do.
Change from Hitec 555 receiver to lightweight Berg and save .5 oz. This will allow another .5 oz saving since I will be able to remove .5 oz of shot from nose.
Save a Total of 1 oz.
Remove landing gear plates and gear and save close to 1 oz.
Here is the real problem, without the landing gear, need to add about .5 oz weight to nose to balance.
Is .5 oz savings worth it? Will it fly better without wheels?
I could go with a smaller battery pack than the 1320, but again, nose weight.
Ed
Ekir is online now Find More Posts by Ekir
Old Sep 30, 2010, 07:36 AM
rpmrpm is offline
Find More Posts by rpmrpm
I'm going flying..........
rpmrpm's Avatar
Ramona,CA
Joined Feb 2008
150watts, do you have the individual #s at full throttle IE; amps and volts.
I've not built a 40" Edge yet, maybe this is a good excuse. Post a pic of the gear placement. Can you move your elev and rudder servos forward.
Ya'll are worse than a bunch of chicks, "Oh no, a plane is over weight!?!? And the sky is falling...."
rpmrpm is offline Find More Posts by rpmrpm
Old Sep 30, 2010, 08:55 AM
Ekir is online now
Joined Jul 2007
TP old 1320 3S Pro-Lite LIPO, fully charged
At full throttle
16A
160W
10.35V
I am going to purchase a new battery at the hobby shop. Probably the TP 1350, which is about the same weight as the old one I have
Old Sep 30, 2010, 09:06 AM
rpmrpm is offline
rpmrpm's Avatar
Ramona,CA
Joined Feb 2008
There ya go 10.3v at a 16 amp load indicating a week battery. The guess was write, but it is always nice to actually diagnose the issue. You will probably be closer to 190W on a new 30C+ pack. Let us know how it feels after the new pack.
Old Sep 30, 2010, 10:53 AM
FlopGun is offline
FlopGun's Avatar
Joined Jul 2007
Ekir, it's possible the postal scale is off. You could use a pint of water=448 grams to check it.
There's a few things I do to keep them light.
For scheme, I've found that the acrylic paints thinned with water and applied in two coats is very light, certainly a lot lighter than the packing tape
1) go easy on the glue! I think CA works well, a little white gorilla glue in the tail and nose. I've seen DWs with so much glue down the joints looks like someone used a caulk gun lol.
2) don't use the provided servo trays and screws. just glue the servo right to the foam. Even better cut a little foam out and pop the servo in.
3) use Z-bends in the servo arms, those ez connectors DW provides are nice but they are heavy, this cuts that weight down 50 %
4) don't use servo extensions, those are heavier than they look. I just cut, splice and tape with blenderm, nothing longer than necessary
5) if you are using gear, don't use metal collars to keep wheel on, just rough up the axle, then use some insulation stripped from wire and a dab of ca.
6) get your esc, battery and motor wires as short as you can and directly solder, ditching the bullet connectors
7) Do *not* skimp on the CF reinforcements, they are very light and are key for a good flying plane
Put all those together and you will be 1.5 oz lighter than the next lady!
Old Sep 30, 2010, 11:40 AM
Xpress..'s Avatar
Joined Oct 2007
Wow Flop, most of that stuff seems pretty obsessive...
My 40" Juka WITH colored tape applied weighed in at about 17.5oz flying with my heaviest pack. That had all of the do-dads too, which included the servo mounts, carbon tail supports, bullet connectors, casing on the receiver, and even a set of 6" extensions..
There's nothing much wrong with the servo mounts, and they keep glue off of your servos
Old Sep 30, 2010, 11:49 AM
FlopGun is offline
FlopGun's Avatar
Joined Jul 2007
Well just saying, you could get to 16 oz if you did that. Not hard things at all. I take pride in the AUW.
Old Sep 30, 2010, 12:18 PM
Xpress..'s Avatar
Joined Oct 2007
I got a 15.4 oz Yak 55M by just losing the servo mounts
That still has all of the bullet connectors, and casing around the Rx- I could lose even more weight going that route....
Old Sep 30, 2010, 12:25 PM
FlopGun is offline
FlopGun's Avatar
Joined Jul 2007
OK, now just do the rest of the lightening, and you can add landing gear and be about the same. A proper model has landing gear!
Old Sep 30, 2010, 12:26 PM
Xpress..'s Avatar
Joined Oct 2007
A proper foamie hover lands
Old Sep 30, 2010, 02:11 PM
killsdeer4fun is offline
Find More Posts by killsdeer4fun
With great pwer comes great 3D
killsdeer4fun's Avatar
Globe, USA, Clemson, SC
Joined Jun 2010
A proper model looks something like this Mine flies just fine and I have never weighed it. So there
killsdeer4fun is offline Find More Posts by killsdeer4fun
Old Sep 30, 2010, 02:21 PM
FlopGun is offline
FlopGun's Avatar
Joined Jul 2007
Wow! I could belly land that one. but the problem with that model is the high maintenance costs!
Old Sep 30, 2010, 02:38 PM
Xpress..'s Avatar
Joined Oct 2007
Hey san diego peeps!!!
STAY INSIDE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I am trapped inside right now from massive lightning bolts. There have been about 2 dozen that have hit so close that their crack caused my entire house to shake like crazy!!!!!!
If I get a photo, I'm posting it here..
Mini-HowTo DW Foamies - Colored Packing Tape Trim Scheme rpmrpm Painting and Finishing Tips 47 Feb 24, 2013 04:35 PM
Discussion DW foamies BAF 48" yak 54 build thread appleflyer 3D Flying 50 Jul 24, 2012 03:31 PM
Discussion DW Foamies Yak Junior Build Thread NumbSkull 3D Foamies 90 Feb 01, 2012 03:25 PM
Poll DW Foamies owners thread (poll) Xpress.. 3D Flying 132 Mar 26, 2010 11:10 AM
Discussion DW (Depron West) Foamies 38" Gen-X tdriedger 3D Foamies 14 Jan 12, 2010 04:13 PM
