View Poll Results: Which DW do/have you own/owned?
DW 28" kit 62 10.49%
DW SKUA 29 4.91%
DW 38" kit 177 29.95%
DW 48" kit 156 26.40%
DW 55" kit 71 12.01%
DW Pylon Racer 9 1.52%
Never owned one 208 35.19%
Multiple Choice Poll. Voters: 591. You may not vote on this poll
Old Sep 27, 2010, 07:41 AM
mikeruth is offline
Find More Posts by mikeruth
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
Originally Posted by Xpress.. View Post
Not sure, probably the motor (theyre digital, no pot). I don't believe it was my control surafce, not a chance that is was.
I'd rather run HS65HBs anyways, I can get them for 23 a piece
Also, gotta tape a nickel or something on the opposite wingtip at the lipo. Noticed that when inverted it couples to that side, and only that side- no flex in the elevator either.
If you have the chance, could you open it up and take a further look? PC board, bad solder joint, or connection, etc.
If not I understand, I tend to toss some, but I have been running these Corona Digitals in a 100mph FunJet and that has me concerned.
Thanks.
mikeruth is offline Find More Posts by mikeruth
Old Sep 27, 2010, 05:41 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Yeah, i'll pop them open and do a little digging. Someone suggested that there might be a bad solder connection on the inside from all of the installation/removal work.
Anyways, I DOUBT I will fly today, which means I gotta wait to maiden my 48" Extra 330. The power system runs hot in 90*F weather- it will go nuclear in this 108*F heat (the easterly winds probably aren't helping)
Stay inside guys, no need to burn up a power system today
Xpress.. is offline Find More Posts by Xpress..
Old Sep 27, 2010, 05:57 PM
michaelJH is offline
Find More Posts by michaelJH
Team Extreme!
michaelJH's Avatar
Wa, state
Joined Oct 2009
108* f! ! ! ! ! It has been pretty cold here...
michaelJH is offline Find More Posts by michaelJH
Old Sep 27, 2010, 07:56 PM
Doug Cronkhite is offline
Find More Posts by Doug Cronkhite
TimeShare
Doug Cronkhite's Avatar
United States, UT, Tooele
Joined Feb 2002
111 where I was today. Actually it was 113, but I wasn't able to take a pic until it 'cooled' to 111.
Doug Cronkhite is offline Find More Posts by Doug Cronkhite
Old Sep 27, 2010, 10:10 PM
Team Extreme!
michaelJH's Avatar
Wa, state
Joined Oct 2009
Wow. That is just too hot for me... I can handle the cold but when it gets to around 80* I just have a hard time! I guess it is just what we are used to.
I have been beating the _ out of my 40" Juka! I have been figuring some things out with it that I didn't know planes could do These things are just way to much fun I will post a video in a few days.
Description: Name: DSC09765.jpg
Description:
Description: Name: DSC09772.jpg
Description:
Old Sep 27, 2010, 10:15 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Nice nose
Old Sep 28, 2010, 09:26 AM
Team Extreme!
michaelJH's Avatar
Wa, state
Joined Oct 2009
THanks! Daniel did that for me He is very artistic and designs the coolest paint schemes
Old Sep 28, 2010, 11:12 AM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Yeah, he seems to know the right amount of color to put on your guys' planes. They always seem to have the right touch of it
Old Sep 28, 2010, 11:44 AM
straightedge_ is offline
Find More Posts by straightedge_
click here
straightedge_'s Avatar
San Diego, CA
Joined Feb 2008
...Stay inside guys, no need to burn up a power system today
But don't build anything either. I found out that foam safe CA stops being foam safe once my garage gets over 100.
straightedge_ is offline Find More Posts by straightedge_
Old Sep 28, 2010, 12:07 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Uh oh.....
Old Sep 28, 2010, 12:16 PM
Team Extreme!
michaelJH's Avatar
Wa, state
Joined Oct 2009
That's no good! So what does it do? Does it just melt the foam like non-foam safe? Being that my shop is all concreat and half underground I don't think that I will have to worry about that
Old Sep 28, 2010, 01:46 PM
click here
San Diego, CA
Joined Feb 2008
Originally Posted by michaelJH View Post
... So what does it do? Does it just melt the foam like non-foam safe? ...
Yes, just like ordinary CA. It took me awhile to figure this out since I'd start building in the morning, cutting, painting, fuselage assembling etc. everything looking fine. Then, as the day wears on and it's time for the finishing touches (control horns, CA hinges, etc.) the foam around new glue points turns glassy and useless. Finally after 2 unsuccessful aileron horn installations, requiring cutting out the bad section around the horn and reinstalling the CA hinge and G10 horns, I waited until 8:00PM for a 3rd attempt in the much more comfortable 90 degree night air and that worked.
Old Sep 28, 2010, 04:20 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Interesting.. It seems like CA reacts differently in high temperatures (above 100*F) then it does below. Does this mean regular CA will become foam safe at those temperatures?
I don't think I'll have to worry about that problem though, my basement workshop tends to stay cool, even in the 110* heat of yesterday. The thermometer said about 82 inside, which felt like AC
Old Sep 28, 2010, 07:33 PM
Team Extreme!
michaelJH's Avatar
Wa, state
Joined Oct 2009
I have glued a foamy down at the runway in -8* F It seem'ed to work fine!
Old Sep 28, 2010, 09:06 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Yipeeee!!!!!!!!!!!! Got my 48" back in the air
Couple things that I need to work on tomorrow:
1. Need to take the elevator servo off, clean the POT off, and put it back together. It doesn't want to return to center until a second or two after, so I'm betting on that being the POT.
2. Going to switch to using the precision wings without the counterbalances. I have a feeling those will keep my downline speeds in check
3. GET MORE BATTERIES!!!!
Mini-HowTo DW Foamies - Colored Packing Tape Trim Scheme rpmrpm Painting and Finishing Tips 47 Feb 24, 2013 04:35 PM
Discussion DW foamies BAF 48" yak 54 build thread appleflyer 3D Flying 50 Jul 24, 2012 03:31 PM
Discussion DW Foamies Yak Junior Build Thread NumbSkull 3D Foamies 90 Feb 01, 2012 03:25 PM
Poll DW Foamies owners thread (poll) Xpress.. 3D Flying 132 Mar 26, 2010 11:10 AM
Discussion DW (Depron West) Foamies 38" Gen-X tdriedger 3D Foamies 14 Jan 12, 2010 04:13 PM
