Old Jan 06, 2010, 07:41 AM
Thanos is offline
Find More Posts by Thanos
Athens, Greece
Joined Apr 2009
Spectrum dx6i delete model
Hi to all. How could I remove / delete a model from my Tx's list?
thanks
Thanos is offline Find More Posts by Thanos
Old Jan 06, 2010, 08:13 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Read the manual, if you do not have it then download it from the manufacturer website.
http://spektrumrc.com/ProdInfo/Files/SPM6600Manual.pdf
If you can not do either then power on the TX and go threw the menu screen in the particular model memory you wish to delete or reset.
TO PERFORM A RESET
Press the ROLLER and hold while turning on the transmitter to enter the SETUP LIST. When SETUP LIST appears on screen release the roller.
Alternatively the setup list can be accessed from the main screen by pressing the roller to access the ADJUST LIST then scrolling through the ADJUST LIST by rolling the roller to highlight SETUP LIST then press the roller.
SETUP LIST SCREEN
Rotate the roller to highlight COPY/RESET then press the roller to access the COPY/RESET function.
TO ACCESS THE RESET FUNCTION
Rotate the roller to highlight RESET then press the roller to enter the RESET function.
RESET SCREEN Rotate the roller to YES, next to SURE, and then press the roller to reset the model to factory default settings.
freechip is offline Find More Posts by freechip
Old Jan 06, 2010, 09:26 AM
Thanos is offline
Athens, Greece
Joined Apr 2009
Appreciate the answer. I do have the manual, only I thought that reseting to default settings had to do with the whole Tx (all models to be removed).
Thanks again freechip!!
Old Jan 06, 2010, 10:25 AM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
Thanos, you could simply re-name the model, and set all parameters to zero exponential, 100%epa all channels,
Ghost 2501 is offline Find More Posts by Ghost 2501
Discussion Spectrum dx6i-broken trim switch lightspeeddud Radios 13 Dec 25, 2009 03:02 PM
Discussion Lookin for Spectrum Dx6i nkdurrett Radios 1 Dec 15, 2009 10:31 AM
Wanted Spectrum DX6i DukeStarHopper Aircraft - General - Radio Equipment (FS/W) 2 Dec 05, 2009 08:29 AM
Sold Spectrum DX6i Transmitter w/AR6200 jccflyer Aircraft - General - Radio Equipment (FS/W) 1 Sep 30, 2009 07:47 AM
Discussion spectrum dx6i keeps saving settings problems!!! Retrogrifter Radios 14 Sep 23, 2009 07:16 AM
