Old Jan 05, 2010, 12:23 PM
brutuz is offline
Find More Posts by brutuz
Joined Jan 2010
Question
Antenna replacement
I have a 2 remote controls for 2 RC cars and both transmitter antenna are broken.. is their a DIY way to replace it? or I need to buy a new controller?
if DIY is possible what are the things to consider?
the RC are "New Bright" RC cars
thanks,
brutuz is offline Find More Posts by brutuz
Old Jan 05, 2010, 02:14 PM
TueLe is offline
Find More Posts by TueLe
United States
Joined Dec 2004
You could use any solid metal wire (for example a clothe hanger) as a substitute and it will work the same. Just measure the right length (about 2.5 ft should do it) and make sure it is connected to the base of the antenna.
TueLe is offline Find More Posts by TueLe
Old Mar 18, 2010, 06:57 PM
brutuz is offline
Joined Jan 2010
how about if the antenna is the flexible thing wire..?
Old Mar 18, 2010, 07:33 PM
mredzadventure is offline
Find More Posts by mredzadventure
Kowalski !.....Options
mredzadventure's Avatar
USA, MI, Hastings
Joined Jan 2007
Well I don't know about the coat hanger trick it works for the old TV sets but ideally the antenna is tuned to the specific frequency. I would try to replace it with an original.
http://www3.towerhobbies.com/cgi-bin...C%2Fb%3Etennas
They are cheap 2 should set you back less then $20.00
If you are bent on making one Look here http://forums.qrz.com/index.php This is an Ham radio forum Look in the antenna page Some of the people know more about making antenna's then I could ever know. I think a coaxial cable with the correct length would do it. You just need the inside wire not the whole black cable.
mredzadventure is offline Find More Posts by mredzadventure
Old Mar 18, 2010, 09:45 PM
mini-Rob is offline
Find More Posts by mini-Rob
Joined Mar 2010
you guys are aware you're replying to a 72-day-OLD thread
rofl
mini-Rob is offline Find More Posts by mini-Rob
Old Mar 18, 2010, 09:51 PM
USA, MI, Hastings
Joined Jan 2007
Looks like the starter bumped his tread looks like he's looking for an answer.
Old Mar 18, 2010, 09:56 PM
mini-Rob is offline
Joined Mar 2010
It appears he already got one, 72 days ago.
Old Mar 18, 2010, 10:04 PM
USA, MI, Hastings
Joined Jan 2007
He must not of liked the answer if he posted again.
Old Mar 18, 2010, 10:59 PM
mini-Rob is offline
Joined Mar 2010
When it takes somebody two and a half months to come back and check the replies, it tells me they're not that interested.
Old Mar 19, 2010, 10:32 AM
brutuz is offline
Joined Jan 2010
no i was busy doing things.. plus its snowing and there's flood.. CAR doesn't like water.. heheh
Old Mar 19, 2010, 10:35 AM
brutuz is offline
Joined Jan 2010
btw, the old antenna is a screw type (it has thread) .. and i was able to find an antenna in radioshack but the thing is it has a hole with a screw and washer.. can i just solder it in??
Old Mar 19, 2010, 10:46 AM
mini-Rob is offline
Joined Mar 2010
Of course, soldering a connection would be better (better coductivity) than one that is snap-fitted or screwed on.
Idea Replacement carbon antenna spektrum la528it Hand Launch 21 Feb 12, 2011 05:05 PM
Question Antenna Replacement rimshotcopter DIY Electronics 3 Jan 06, 2010 03:19 AM
Mini-HowTo Futaba 2.4Ghz antenna fix replacement r606, r607, r617, etc. jesolins DIY Electronics 0 Aug 29, 2009 03:29 PM
